Exposure 2010S2D.
After hearing the 3010S2D, and having owned a 2010S and a 1010 I have maintained a passing interest in the Exposure line up of integrated amps.  I have very fond memories of the 2010S, but those are fairly old memories now, and of an amp used in a different room with different speakers.  So I don’t know for sure how well those memories will hold up.
As with the 3010S2D this unit was supplied by Andrew from Audiofix.
My memories of the 2010S are more about an amp with character than they are about technical capabilities or performance.  The 2010, being a power amp with a passive volume control, comes across as a laid back, calm and comfortable piece of gear.  The music has no sharp edges, no hardness or harshness, in fact if you were to describe it as “a bit soft sounding” they you would be pretty close.  It isn’t an amp that excels at fast drum solos (although it isn’t half bad at those), it really specializes in slower passages.
It is fairly phlegmatic in its approach to musical reproduction, and that is just fine by me.
This review started out with me being fairly sure I knew what to expect, I’ve heard this amp before and while I hadn’t heard it in my current room or on my current system I have heard several other amps on both old and new systems and I knew where the 2010 lay within those other amps presentations.  Lucky for me I was correct and the 2010 does sound very much as I expected it would, but as with any audio story there is so much more to it than that.
In the beginning I was listening to the 2010S2D using my traditional set up.  YBA Heritage cd100 as source, Aurealis Dragon interconnects, generic old 10AWG speaker wire and Lenehan S2R speakers.  And it was sounding pretty good.  A bit soft in the top end (which I expected, and will explain shortly) but the mid range was very nice with possibly a little more resolution and detail on display than I recalled.   Bass was nice and deep but for the most part it was kept on a short leash, very deep but very broad.  Bass is used to set the mood and to back up the mid range, it isn’t the main feature so not punchy, and more polite than tight.
Then I tried the little Exposure out with my newly modded Sansui SP-300S stand mounts (with new crossovers) and found that they combined so much better with the amp than my Lenehans did.  The Sansuis have a hard tweeter that gives more energy to the top end and that works in this case to counter the relaxed top end of the Exposure where as when the relaxed top end of the Exposure combined with the slightly softer top end of the Lenehans some of the top end details only came through when the volume was turned up higher than usual.  So the Sansuis worked far better at low listening levels, better at normal listening levels and only just better at high listening levels.
However, in the past I’ve always used the Lenehans for my reviewing.  Consistency is key in this game after all, so even though I was really enjoying the Sansuis I took them out of the system and put the Lenehans back in.  Things went back to the way they were and I had an additional piece of info to offer up when it came time to write my review.  All good there.
Then Terry stuck his nose into the review (to be fair to Terry, he didn’t do so deliberately, but he did ask me to do him a favour and that had a pretty serious impact on the review) and complicated matters further.  Terry had just bought a cd player from Dan, Dan and I know each other and both live out in the Kingaroy-ish area.  Since I’m meant to be heading down to Terry’s place in a week or two I’ve been asked to take the cd player along for the ride and deliver it.  All well and good, no problems there.
But!
Then Terry asks me for my opinion on the cd player (again to be fair to Terry, I don’t think he knew I was trying my damndest to get this 2010S2D review started this weekend) and I agreed because playing with new toys is what this hobby is all about.  And because I’ve always wanted to hear this Consonance Droplet that people are talking about.
So earlier this morning I pull the Droplet out of its box and set it up on my vibration platform.  Within 20 seconds I’m hearing that this puppy is clearly superior to my YBA and not just in a small way.  It completely transformed the performance of the system and it really raised the performance of the Exposure as well.  Instruments and vocals were clearer and the bass tightened up and deepened just a little further.
I believe a big part of this improvement comes from the Droplet having a very low output impedance.  Remember my mention of that passive pre/volume control above?  Well it shares that particular design with the ME240 and I’ve already found that the ME240 behaves far better when paired with a low output source (or when used with an impedance  buffer in between it and the source).  I believe that the YBA has a fairly high output impedance (read weak signal if you aren’t up to date on the whole impedance matching game) and the Droplet has a much lower one (read strong signal, so it can push through the passive volume pot without losing any strength or detail).
So, give the 2010 a stronger signal and it sounds like it has more resolution and detail.  No real surprise there I guess but it is nice to know from experience rather than deduction.
The problem now is going to be going back to my YBA for all the nitty-gritty evaluating and awarding numbers to each category.  That will not be an easy thing.
This promises to be a bit of a long and rambling review ladies and gents.  Best settle in for a multiple post review put up over several weeks.  I will do my best to make it thorough but it could turn out a bit on the long winded side.  Just letting everyone know ahead of time.
This section of the site is sadly under-utilised.
Thanks for kicking off another promising review.
I'll be moving suitable material into this section from now on (it tends to stay in more General areas where it probably doesn't belong).  🙏
Sorry for inadvertently making the Droplet a part of your review Jeff and I’m glad to hear how much you like it ... please tell me this though, you are going to bring it down with you when you next visit aren’t you?  ... pleeeease 🙄
cheers Terry
Edited by TerryO
cheers Terry
Oh all right then...
Probably.
Sunday seems to be fast becoming my review writing day.
OK, time to get down and detail-y.  As per usual the source in use was my YBA Heritage cd100, joined to the 2010S2D via Aurealis Dragon interconnects.  Speaker cables were stock standard Ugly cable, 10AWG stranded copper and my speakers were my trusted (and much loved) Lenehan S2R stand mounts.  I decided on generic speaker cables due to the massive disparity between the amplifier RRP of $2K and my other, more fancy, cables.  I doubt anyone is likely to use $700 plus speaker cables with a $2K amp.  However I like the Aurealis Dragons so much I just didn’t want to use anything else.  As always with this hobby, sometimes practicality wins and sometimes emotion wins, and predicting beforehand is not an easy thing.
Highs:
Trumpets come across as more raspy and less brassy, very easy on the ear but I can’t help thinking it is at the cost of sounding the way brass should.  Brass should be at least a little hard and sharp, but not with the 2010S2D (or at least, not until you turn the volume up, more on that a little later).  Triangles sound less metallic and more crystalline and sparkly and they actually seem to gain a little zing that is usually only heard on strings in the mids.  On my Lenehans it rates a 7.0, I could see brighter speakers as a better match.
Mids:
Slow strings have extra zing in spades, sweet and seductive.  There is also a sort of “soft Poise” present on slow, plucked strings that is just so gorgeous to hear that it sends little shivers down my spine (the shivers that I usually get when hearing hard played electric guitar).  Piano is very good but not quite as special as strings.  8.25
Bass:
The 2010S2D has no trouble sounding big and deep but it doesn’t really do hard or punchy.  The bass doesn’t hit you, it just looms large from across the room.  That doesn’t mean that there isn’t plenty of it of course, it is full and smooth and almost creamy.  This is best suited to slower music but it also does surprisingly well with small to mid-sized drums.
7.5
I should note here that I surprised myself about half way through my test disc as a phone call forced me to stop and start again a bit later.  For some reason it took me a few minutes to get back in the right mood and once that happened I skipped back over the song I had just not-really listened to so I could listen to it again.  Then when it still didn’t grab me I turned the volume up.  Well, the difference between 9 o’clock on the volume dial and 9:30 was completely unexpected.  Harder and sharper sounds pushed through that relaxed overall feel to make themselves heard, for harder rock the difference was quite marked.  I have to go back and listen to the first few songs again but I’m pretty sure that 7.0 that I gave the top end will go up to a 7.5 by tomorrow morning.  (This is what happens when you don’t listen loud enough folks, you miss things.  Learn from my mistakes, don’t follow them, listen loud, not soft!)
Vocals:
Now this is interesting.  That relaxed, laid back overall character has an unexpected effect on male vocals, it makes them sound a bit more lively and a bit more energetic.  I really don’t understand the why but it really felt like I was listening to a younger Freddie Mercury and a younger Mark Knopfler.  The girls don’t seem to gain anything extra, but then they sound pretty good as is.   8.0 for both Male and Female vocals.
Soundstage:
2D and 3D sound stages are just fine, stereo effects are present and accounted for but they feel a little ghostly as the sounds aren’t fixed into a particular spot so much as they are coming from a particular direction.   You just don’t get razor sharp separation and distinct placement from a relaxed presentation, that shouldn’t really be a surprise.  The 2010S2D is more about the song than the details when it comes to sound staging, and in this case that works quite well.  7.0
Overall Performance integration:
What can I say, it is relaxed and laid back and that’s what it wants it’s listener to be as well.  Raising that volume will definitely allow it to rock but at heart it is more interested in taking things is a less rushed and more leisurely manner.  I personally think it sounds more tube like than many tube amps.
Ability to Emote:
8.5 on slower, softer styles.  7.5 on faster and harder stuff below 9:30 on the volume dial, 8.0 on the faster and harder stuff above 9:30 on the volume dial.
Electric Guitar Test:
7.0 at 9 o’clock, I had to go up to 10 o’clock to get the score up to 8.0.  I could probably live with it but I’m not sure my neighbours could.
80’s Rock Test:
Again, volume is key, only 7.5 below 9:30, 8.25 above.
So in summary, if you like slower, more relaxed styles of music then the 2010S2D should definitely be on your list of amps to try.  If you like to venture into the harder styles every now and then that’s just fine, but if you want to live in the harder styles long term I’d be recommending the Exposure 3010S2 over the 2010S2.
While I was listening and taking notes I wrote the following line on the bottom of my test sheet.  It doesn’t really fit into the review anywhere in particular so I thought I’d end with it.
“If you have enough stress in your life that you don’t want any in your music then the 2010 is for you.”
And what review would be complete without delving into the past of the 2010 model and comparing the latest 2010S2D with the older 2010 (prior to the "S")?
SNA's own @wen has kindly lent me his 2010 for just such a comparison.  He even included the manual, with additional notes added.  The 2010 we have here is the 2000 model which, according to printing on the PCB is the 2010R.  So we are comparing across about 18 years and with 2 models in between.
The earlier model has a significantly different sound signature.
There are some distinct similarities in the bass region but it is a little more forward and a little faster than the latest incarnation.
There also appears to be more gain, 8 o’clock on the volume dial gives the same volume as 9 o’clock on the 2010S2D.
Highs:
The top end is nowhere near as relaxed, it sounds very similar to the 3010 but just a little on the thinner side.  So it sounds harder and brighter than the 2010S2D does, not hard or bright enough to offend, just enough to lightly annoy on every third or fourth song.
It has a more dynamic presentation, more leading edge and more slap and tap to it.  Trumpets are more brassy and triangles more metallic but that special zing is conspicuous by its absence.
Mids:
The slow strings that were so seductive on the 2010S2D sound almost rushed.  There is definitely more detail on display but it isn’t as engaging to listen to.
Bass:   Quite similar but faster with more of a sense of attack to it.  Still quite broad.
Vocals:  A little more gain-y, not as engaging.  Male vocals don’t have that “fountain of youth” effect to them.
Soundstage:
Tighter and more pronounced, with that extra detail sound stage placement is much easier to pick.  Not quite as much fun to listen to but definitely easier to notice stereo and 3D effects.
Overall Performance Integration:
A much better amp for faster music but it can come across a bit on the hard side.  Nowhere near as relaxed as the newer version.
Ability to Emote:
Doesn’t resonate with me anywhere near as well as the later model, that extra harder, brighter presentation annoys me and that makes it hard to find an emotional anchor.
The bright side to that extra hard, bright detail is that electric guitar loves it, far superior to the 2010S2D, at least 0.5 higher.
80’s Rock Test:
Also a better score, 0.25 higher, maybe 0.5 if the song has some stereo and 3D effects mixed into it.
I was going to launch into a comparison of the technical details and differences between the two 2010s, how the earlier version is a MOSFET amp and the later uses bipolar transistors, how the earlier version has a higher input impedance (>25K) and the later a lower figure (>14K)  but I’m not sure any of those technical details are as important as I first thought they would be.
It seems fairly obvious to me that Exposure altered their vision for the 2010 as they went.  The earlier model sounds very much like a smaller version of the 3010 where as the later model has a sound that is very much it’s own.
This makes The Exposure integrated line up somewhat unique in that you don’t just get a house sound with more power and/or features as you move up in price you actually have a choice of two amplifiers that sound quite different.  It’s not very often that happens.
I'd like to thank, once again, Andrew and David for lending me their amplifiers to listen to.  It has been most interesting for me, and I hope a worthwhile read for the rest of SNA.
Cheers Everybody!
interesting review, reading from your previous post it seem component matching needs to be considered
i would say the technical difference relates to the sound being produced , and as said before, which component is connected
Edited by wen
And that has me wondering as to how it is meant to sound.  I can't say for certain as I haven't heard it paired with the 2010 series cd player.  I guess I'll have to talk to Andrew and see if we can make that happen.
rereading the reviews,
would this be tamed by
i had a Rega Apollo CD player, to use your words, the resolution and detail,was incredible but became fatiguing, only being resolved  by using CHORD Cobra 3 cables, this seemed to settle it and make it enjoyable to listen to again?
On my next CD player, Creek Destiny, the Chord cables were unsuitable, now using MIT CVT terminator2 cables, these match well.
Thanks Cafad for a highly detailed and careful study of the Exposure 2010S2D and its much older forbear.
I can only agree with your thoughts on how it sounds.
On the CD front you are more than welcome to give the matching CDP a go but it will unfortunately disappear from the range sometime in the next 12 months like many UK built CD players already have....
It has a sweet character and is a worthy player for 2k but alas Exposure cannot obtain anymore of the CD drawer parts.
Thanks again for your time taken to listen to the Exposure.
Andrew.
Hi Cafad ,
In a earlier review do I remember you
using a Burson Line Buffer , or am I mistaken , sounds as though this is
what the YBA / Exposure "coupling" may need to really hit it off...
3 hours ago, rudihaas said:
Hi Cafad ,
Good call mate, I do have one of those (don't know how I managed to forget about it).  I'll have to drag it out and see what difference it makes.
I have a Redgum SG 5500 , and I think its a passive pre , always thought the Burson might be a good addition , they are not the too expensive 2nd hand if you find one.......(one day , yes ,one day)
 Having Exposure 3010s2d for a few months now I thought I add 2c. I would say with my speakers that amp is really good at "prat" (Pace, Rythm And Timing) and dynamics. It's very addictive. With Focal aria 936 mids and heights are rather smooth but bass is strong and punchy.
    • By Darkstar
      Item: Melody H34 Signature Integrated Amplifier
      Price: $1800
      Item Condition: 9/10
      Reason for selling: Surplus
       This is my very first amplifier into the world of tubes and valves. A lot of time and money was invested in tube rolling to get the right synergy out of the amplifier with the right tubes. Original valves have been replaced with Mullard reissue El34, Mullard 5AR4, Brimar 6SL7 and Ken Rad 6SN7. Over $600 worth of tubes there alone. Amplifier is in excellent condition for its age and presents itself beautifully in its deep piano black chassis. Will come with its original double boxes and manuals. Inspection and sound will not disappoint.
      Extract from the internet
      MELODY H34s ASTRO BLACK Favorite tube of many music lovers is the EL34 which excels at tone. The tonality of the EL34 makes it also popular with musicians using stringed instruments, especially guitars. The most popular amplifier in the Melody range and winner of many awards the Melody H34 Signature offers fantastic sound quality at a price that seems unbelievable. With a full size chassis in piano black finish and retro styling it is a statement product in quality and style. The 25mm thick front panel contains three large solid aluminum knobs which control power on/off, volume and four RCA inputs. The volume knob controls a stepped resistor array with 24 positions. This ensures precise channel matching and maximum sound fidelity. The power tubes are four EL34 which deliver 40 watts of effortless power. This allows it to drive a wide range of loudspeakers with ease. The input and driver tubes are 6SN7/6SL7 and the amplifier has full tube rectification provided by the 5AR4 tubes. All the internal wiring is done by hand point to point with no circuit boards at all. This is the traditional way to build a long lasting amplifier with maximum sound qualities. It permits easy servicing and parts replacement or upgrading which modern solid state circuits with surface mount devices to not allow. At the rear are three oversized and shielded transformers with a power transformer in the centre and an output transformer either side for the left and right channels. Melody’s know how has delivered an amplifier that is powerful, delicate and with a depth of tone that makes it very beguiling. This amplifier can be muscular at one minute yet delicate the next, extracting minute details from the music. The sound stage is wide and deep and the bass is extremely realistic. The bass however is not dry or truncated, like many transistor amplifiers. It delivers information in the bass registers with plenty of feeling. The H34 Signature is an amplifier that music lovers will enjoy, not only for its sound but for the unbeatable value it offers.
      Power Output: 2 x 45W
      Tubes: EL34 x 4, 6SN7 x 2, 6SL7 x 2, 5AR4 x 2
      Frequency Response: 20Hz–20kHz
      Input Impedance: 250 kOhms
      Output Impedance: 4 Ohms, 8 Ohms
      Input Sensitivity: 480mV
      Signal to noise: 90dB
      Harmonic Distortion: 1%
      Dimensions: 430 W x 215 H x 410 D mm
      Weight: 24 kg
    • By LyallJ
      Item: Luxman 505u Integrated Amp
      Price: 3000
      Item Condition: Excellent, mint condition
      Reason for selling: Purchased a Devialet 220
      Payment Method: Pickup - Cash, Paypal, COD Only.
      Two things to note:
      The remote is dodgy with its Volume control; over the years I have either changed volume manually or use a DAC/preamp.
      I imported the 505u direct from Japan so it was assembled for the Japanese market and set to 100volt mains electricity. Therefore it comes with a Kashimura TI-20 step-up transformer (photos attached). There has never been any issue playing it here in Adelaide.
      The Luxman has been in daily use since July 2010. It has always worked well and given me great listening pleasure.
      I have attached a User Manual and Brochure.
      The 505u has a phono input with both MM & MC selections.
      The amp can be used as a pre-amp only or power amp only.
      The 505u weighs 21kg. The transformer weighs 4.5kg and its dimensions are 170x135x100mm.
      I will post both items if there is no buyer in Adelaide for pickup - postage costs would have to be checked and agreed to.
      I still have the original box available for transportation.
      Luxman L-505u manual.pdf Luxman L-505u Brochure.pdf
    • By Goatboy
      Item: Exposure 3010 Stereo Power Amplifier
      Price: $680   $500
      Item Condition: Very Good - functions perfectly / minor cosmetic wear
      Reason for selling: NLR
      Having one last crack at moving this on. I think this is a great amp for the asking price.
      I bought this power amplifier from the forums in 2017. Its main use is HT duties, as well as spinning 10 hours or so of vinyl each week. The amp has performed flawlessly and presents as warm and emotive, ie. the Exposure house sound. The amp is rated at 100w / channel into 8 Ohms, and has the capability to run as a mono amp, as well as the option to biwire.
      Note: the amp only takes banana plugs.
      Cosmetically, there are minor blemishes and some light scratches on the top of the unit.
      I have the original box, and happy to post.
      https://www.exposurehifi.com/images/quickstart/3010_Power_Amplifier_QS_Manual_web.pdf
      Specs:
      Power Output (Stereo): 100 Watts per channel at 1KHz into 8 Ohms
      Power output (bridged mono): 110 Watts at 1KHz into 8 Ohms
      Input Impedance: 18K ohms
      Frequency Response: 20Hz - 20 KHz ±0.5dB
      Total Harmonic Distortion: <0.015% at rated output ref 1 KHz
      Signal to noise: >100 dB ref rated output
      Channel Separation: >60dB, 20Hz - 20KHz
      Mains Supply: 110/120V or 220/240V, 50/60Hz (factory set)
      Power Consumption: <350VA, 8 ohm load both channels driven
      Dimensions (H x W x D): 115mmx440mmx300mm
      Net Weight (unpacked): 11kg
      Gross Weight (packed): 13kg
    • By olegau
      Item: Luxman L-509U Integrated Amplifier
      Price: $5900
      Item Condition: as new
      Reason for selling: need money
      The highest-class model of LUXMAN  Integrated Amplifier.
      I am one only owner. Bought new for $8000 in 2012
      The amp has never been repaired, works very well. No issues, can give a week warranty.
      The unit has never been loud more then 9am because I live in a flat and I like my neighbors.
      Continuous effective output: 120W + 120W -8ohm   240W + 240W  4 ohm
      reproduction frequency: PHONO: 20Hz ~ 20,000Hz  0.5dB) LINE: 20Hz ~ 100kHz (+ 0, -3.0dB)
      SN ratio: PHONO (MM): 91dB or more PHONO (MC): 75dB or more LINE: 107dB or more
      Dimension: W 467 x H 179 x D 435 mm
      Weight:  28 kg
      Preferably Pickup
      Also look  another my amp Sansui AU-a607DR amp for sale on this site.
    • By Cnnnnc
      Item: Rogue Audio Cronus Magnum integrated amp.
      Price: $1700 (now $1600)
      Item Condition: excellent
      Reason for selling: Upgrade
      Payment Method: Pickup - Cash, Paypal (+3%), Bank Transfer
      Rogue Audio Cronus Magnum, with tube cage,
      The amp is a few years old, has been flawless...with amazing sound.
      The tube cage is a seperate add-on, and will have to be shipped seperately, so prefer pickup.
      I have used this amp to drive the Wilson Sashas with beautiful sound.
      Any questions, please ask lots of great reviews available for reading on the net for the awards, reviews on the Cronus Magnum...
      It comes with remote and original boxes. If shipping is required it can be discussed.
      Specifications
      - 100WPC Magnum
      - Remote volume control included
      - 20Hz-30Khz bandwidth
      - Phono section gain 35dB (before preamp)
      - (3) line level inputs, (1) phono input
      - (1) variable output, (1) fixed output
      - Headphone amplifier
      - 4 and 8 ohm taps
      - Optional tube cage
      - 25kg shipping weight
