simbot82 Posted March 16, 2019 Share Posted March 16, 2019 Hello ALl I have the chance to pick up a pair of krix neuphonix mk1's. My home theatre currently has a pair of Bower and wilkins 683's MK1. It looks like I could almost swap the krix and sell the 683's for around the same price. Will this be a significant upgrade in sound quality (I know everything is relative but will I notice) Thanks very much Link to comment Share on other sites More sharing options...
warweary Posted March 16, 2019 Share Posted March 16, 2019 You'll notice a difference... but only you'll know if it's an upgrade or not - in room. 2 Link to comment Share on other sites More sharing options...
simbot82 Posted March 16, 2019 Author Share Posted March 16, 2019 For home theatre use Im looking for big sound. I have some linn Isobariks for stereo applications. Link to comment Share on other sites More sharing options...
Al.M Posted March 16, 2019 Share Posted March 16, 2019 Hard to say until you compare them side by side in same room. Krix is valued more rrp, perhaps bigger bass, whereas the BW has a bigger midrange driver and metal dome tweeter so maybe sound balance is more that pronounced, just guessing. Overall the Krix on paper should be better but the personally I’m not a big fan of the ring radiator Vifa tweeter sound, very dry and uninviting. 1 Link to comment Share on other sites More sharing options...
Peter_F Posted March 16, 2019 Share Posted March 16, 2019 5 hours ago, simbot82 said: Will this be a significant upgrade in sound quality (I know everything is relative but will I notice) In HT it most likely will not be a significant upgrade. Also will the Krix match the centre speaker? And I think the Krix is a 4ohm load? 1 Link to comment Share on other sites More sharing options...
simbot82 Posted March 17, 2019 Author Share Posted March 17, 2019 Thanks all The centre that is with the krix here is just the smaller centrix but I have a b&W HTM61 which is a bigger centre. I will hold out for a more significant upgrade rather than a sidegrade Link to comment Share on other sites More sharing options...
