Danhifi
HEOS Link 2 - is quality ok as DAC+Streamer?
Not very experienced with audio and want to add streaming to a second hand hi-fi system:
Rega Elex-R + Elac 244.3
I’d like to do it as cheaply as possible without completely killing the audio quality of the system I have.
 I’ll use Tidal or Deezer as advised (or Spotify) for my music source.
Ive been told the HEOS 2 ($599) is a good enough system. Next step up I think is blue sound (?) and then Cambridge CXN (v1 is on sale) but the Cambridge is double the price ($1100 + $150 for blueetooth).
Has anyone got experience with the quality of using HEOS Link as a DAC?
(Or or should I sell the Rega and get something all in one? I’m told this is not a good path generally.)
Many many thanks in advance!
Edited by Danhifi
Add tags
The Heos Link is a nice sounding unit, and its internal DAC is not bad for the price, however the Cambridge would wipe the floor with it (v1 or v2).
Not a fan of the Heos app though, its Ok but could be a LOT better.
Keep the Elex-R, its a great amp
Hi Hydrology,
thanks!
I spoke to these guys and they said the better unit to the HEOS at my budget would be the Arcam Airdac - half price.
https://www.apollohifi.com.au/arcam-airdac-airplay-digital-to-analog-convertor.html
anyone have any thoughts? I know I’ll loose Bluetooth but not a big deal. And with AirPlay ( I use Apple) I don’t need a great app. May be a way to get CXN type quality at a good price?
The Bluesound and CA CXN are rightly popular here because they provide good sound quality and usability.  Do not under estimate the latter and what a good App can do to the music experience. Have yet to use the CA App but can attest to BluOS which is easy to use and looks very good, especially on a tablet.
Have no doubt that the Arcam Airdac is better than Heos. If all you want is a bridging device, it will do a good job. But if you are looking to improve the streaming experience and allow for future connectivity, then Bluesound or CA is probably a better way.
Ideally, listen to the boxes and compare but I suspect this is all done online.
The air dac will sound better but it’s a dac not a source as such, plus it’s an old model.
it will receive music via airplay but the that means your phone or iPad is still the source and the streaming is only as good as the wifi signal you have between the two.
the denon or bluesound are the source so there no issues with wifi cut outs etc between your controller and the device.
if you can squeeze the extra money I’d go bluesound mode 2, there’s one ex demo  online for around $650 which isn’t bad price wise.
you won’t regret it.
Edited by Hi-Fi Whipped
Thanks very much. It’s pretty complicated once you get into it!
Knowing that Bluesound and HEOS link are the source (ie files play from them) is helpful vs Airdac where the phone is the source.
This leads to a further question about Airplay. It seems to me that using something like Tidal or Deezer at highest quality over AirPlay will lead to a loss of quality as AirPlay needs to encode at a slightly lower quality than is available from those services (?).
Finally it seems hard to know whether one or the other system (Airdac, Bluesound, CXA (rdac?)) will sound best with my set up (which has been described as a bit bright). I suppose it’s a matter of paying what you can...? So CXA if I can manage the budget, then Bluesound and so on?
With volume control is it acceptable practice to use the streamers app volume control instead of The Rega?
Also is the sub woofer out on something like the HEOS a meaningful feature for my set up if I want to add bass in the future for music listening or this sort of ‘active’ sub a lower quality option than is suitable for a proper hifi?
Sorry for so many more questions..any insights appreciated.
I have the CXN V2 and I can't complain. I play from the Android Tidal app via Google Cast. Only minor complaint would be no gapless play back via Google Cast.
I am not an Apple person but I understand Airplay is CD quality 16/44.1 which is the same as Tidal Hifi, their lossless service.  So no loss of quality as far I know.
The assume CXA = Cambridge Audio CXN?  Have a look at both the CXN and Bluesound and see what other features you want.  The CXN has more connectivity options, BluOS more useable etc..
Volume control on streamer is digital, Rega analogue.  In theory, Rega is better, but more convenient to use streamer volume control.  But do a test when you get unit.
I was hoping we have convinced you out of Heos?  Not sure of Bluesound but you can use the spare pair of analogue outputs on the CXN to drive a sub.  Having a sub for stereo is a "No No" for some here, does require some work to set up properly  but suggest you start a new thread when you consider a sub.
On 16/03/2019 at 12:00 PM, Danhifi said:
There’s a bluesound node 2 in the classifieds if you are quick
Thanks! Have made contact.
For others interested they are selling around $675 new now.
    • By Bill125812
      Item: SOtM-200 streamer and Gieseler kraftwerk power supply
      Price:  $600 inc postage  ( RR for both $950 )
      Item Condition: as New   ( inc original box and accessories)
      Reason for selling: Change of direction
      Extra Info:  This little beauty streams anything from nas drives to Roon and tidal.  And with the Geiseler power supply takes it to the next level
    • By Glockers
      Item: Bluesound Node 2 Black
      Price: $419 PRICE DROP! (New price dropped to $719)
      Item Condition: As new
      This Node 2 is about 18 months old but was only in use for 6 months. 2 reasons. I bought it mainly to hear how MQA files played but ended up cancelling my Tidal account as I preferred my long held Qobuz streaming app and they hadn't embraced MQA.
      There are many online reviews available but Johnnie Darko seems to be most comprehensive.
      "This single box and an accompanying app does it all: Tidal, Spotify, Qobuz, Deezer, Slacker and Napster with support for up to 24bit/192kHz for anyone enjoying a Qobuz Sublime+ account or streaming hi-res audio from a NAS device."
      https://darko.audio/2018/01/further-travels-with-the-bluesound-node-2/
    • By mmu16
      Item: Yamaha WXAD10 Network Streamer
      Price: $150 + pp
      Item Condition: Excellent/Brand New
      Reason for selling:Surplus
      Brand new Yamaha Network Streamer for sale. Great little unit that can stream Spotify, tidal etc. Uses Yamaha's Music Cast system which is very flexible and can do multi room too. Full DLNA and UPnP compatible. Ethernet and wifi built in. Tiny and unobtrusive. Has a great on board Burr Brown dac and is very musical. Controlled via Yamaha Music Cast smart phone app. Bought Oct 2018 and was plugged in only once. Selling because I have invested too much with sonos and it doesn't make sense to start again with a new platform.
      Can meet Melb CBD
      $150+pp
    • By Sirmorebeer
      Item: Cambridge Audio Stream Magic V2
      Price:  Sold
      Item Condition: Good, a surface mark at the top see pic
      Extra Info:Have original box, therefore can buyer to pay postage
      This is a very versatile network streamer/DAC. Latest firmware enable this player to stream Tidal. This unit is around 3.5 years old. Works flawlessly with my NAS, fetching flac files from UPNP server using its native App from mobile phone or tablet.
      Specs:
      DIGITAL TO ANALOGUE CONVERTER Dual Wolfson WM8740 24-bit DACs
      DIGITAL FILTER 2nd Generation ATF2 up-sampling to 24-bit/384kHz. Linear Phase, Minimum phase or Steep modes.
      ANALOGUE FILTER 2-Pole Dual Differential Bessel Double Virtual Earth Balanced
      DIGITAL INPUTS S/PDIF 75 ohms and TOSLink optical
      USB AUDIO INPUT USB Type B conforming to USB Audio profile 1.0 or 2.0 (user selectable)
      ANALOGUE AUDIO OUTPUTS Balanced XLR and unbalanced RCA analogue audio outputs
      COMPATIBILITY UPnP 16-24 bit, 32-192kHz Local USB media 16-24 bit, 32-192kHz USB Audio1.0 16-24 bit, 32-96kHz USB Audio 2.0 16-24 bit, 32-192kHz Toslink 16-24 bit, 32-192kHz (using high quality Toslink optical cable) S/PDIF 16-24 bit, 32-192kHz BT100 Bluetooth receiver: A2DP plus aptX
      AUDIO FORMATS ALAC, WAV, FLAC, AIFF, WMA, MP3, AAC, HE AAC, AAC+, OGG
      STANDBY POWER CONSUMPTION<0.5W   DIMENSIONS (H X W X D) 85 x 430 x 305mm (3.4 x 16.9 x 12.2”)
      WEIGHT 4 kg (8.8lbs)
       Reviews:
      https://www.whathifi.com/cambridge-audio/stream-magic-6-v2/review
      https://www.crutchfield.com/S-LBsFZcrFXKk/learn/cambridge-audio-stream-magic-6-v2-review.html
    • By Turtle Rustler
      Item: Simaudio Moon Mind 180 HD Network Streamer + Swagman Labs 12v linear Power Supply
      Price:  $700 ONO  price drop
      Reason for selling: NLR upgraded
      Payment Method: Pickup or Post - Cash, Paypal, COD Only
      Up for sale is my Simaudio Moon Mind 180 HD network streamer with the Swagman Labs 12v Linear Power supply.
      The MoonMind 180HD has the latest firmware and can stream local files as well as Tidal, Deezer and Internet Radio.  The unit is well reviewed online and Simaudio is a high end manufacturer, this is a quality audio streamer/renderer. I have had both the microRendu streamer and the MoonMind in my set up for a few years and both are very good, but the MoonMind just shades the microRendu for SQ.
      Input is via Ethernet or WiFi, but Ethernet of course gives the best operation. The 180MiND outputs signal via the following digital connections (Toslink, SPDIF on RCA, AES/EBU on XLR)
