Dhillon
FS: ISOTEK SIGMAS GII + ISOTEK PA POWER CABLE [price reduced]
Item: Isotek Sigmas G2 (US Plug) + original Isotek PA power cable (US Plug)
Price: $1200 price reduced
Item Condition: 8/10 due to age only, function well
Reason for selling: selling for a friend
6 x US plugs for your premium US plug cables
Product reviews for your reference:
https://www.techradar.com/au/reviews/audio-visual/av-accessories/isotek-sigmas-1059908/review
(Please note, preference to local buyers for cash / pickup)
    • By campo007
      Item: Timestep Technics SL-1200, SL1210 New Precision Bearing
      Price: $450
      Item Condition: NEW - UNOPENED (JUST GOT IT)
      Reason for selling: NEW DIRECTION
      Payment Method: Pickup - Cash, Paypal, Bank Deposit
      Extra Info: Will ship Australia wide at buyers expense.
      This is a brand new unused Timestep bearing for the Technics SL-1200 & SL1210. I just received it from Dave at Timestep, but decided to go in a new direction while in transit. The price i've proposed is the price i paid less GST and shipping from the UK. So saving around $80.
      Technics SL-1200 SL-1210 New Precision Audiophile Bearing
      The standard bearing cannot keep the oil in place.  Instead a high viscosity "anti-fling" oil must be used.  "Other" bearings can only be "topped up" and the oil not actually replaced.  Imagine not being able to change the oil in your car, only adding a bit now and again
      Why would you want to change the oil ?  Well we found a fairly heavy oil works best with the Funk Platter and thinner oil for very heavy platters.  But you have the choice, you can take our advice, or change the oil to whatever, whenever !  BTW, unlike others, our bearing fits the Funk platter perfectly, as it should !
      The Timestep bearing has the spindle as a solid single piece of polished 303 Stainless Steel with a much larger base diameter and the bearing is polished PB102 Phosphor Bronze. A silicon nitride ball and PTFE thrust pad are fitted. The whole assembly is in a captive oil bath so that you can use more suitable thin oil, or any oil of your choice.
      One image shows the Timestep bearing shaft on the left and the Technics on the right. The Technics bearing shaft has a cut out just below the brass part, resulting in a diameter of just 5.9 mm, the Timestep bearing shaft at this point is 10.4mm. This gives the Technics a critical bending moment around the reduced diameter.
      The main part of the Technics shaft bearing surface is 7.1mm diameter and the Timestep one is 11.1mm which results in a bearing surface increase of nearly 2.5 times more (actually 2.445). And that's a lot!  The other image is looking down into the captive shaft bearing. At the bottom would normally be the P.T.F.E. thrust pad and the silicon nitride ball bearing, and a lot of very nice oil.
      So with 1.76 times diameter at the weakest point and 2.5 times more bearing surface area, you can see why we get such great performance.
      We deliberately use the existing Technics bearing housing because it fits properly and being cast has great strength and rigidity, also it does not ring like a brass bell.  It keeps the cost down too !
      You don't need any special tools, you don't need to modify the PCB and you don't need to remove parts to get it to fit.  A simple Philips screwdriver is all you need and less than 15 minutes of your time.
      This is the best selling Technics bearing, users have reported more solid bass, considerably better timing, greater soundstage and a general "feel good" sensation.
    • By bzr
      Item: Siltech Royal Signature Princess XLR 1.5m interconnects
      Price: $3500 includes postage.
      Item Condition: Very good
      Reason for selling: Same as the dog with nuts, upgrading.
      Payment Method: Pickup - Cash, Paypal, EFT
      Extra Info: These need no introduction. Siltech cables have been in more best of systems than any other. Bought from the only importer, Uncle Boris.
    • By caleb
      Item: Mad Scientist Audio BlackPod Mini Tungsten Carbide Audio Footers 3pcs set
      Price: $120 posted
      Item Condition:7/10(has some scratches and wears on one of the tc ball)
      Reason for selling:no longer required
      Mad blackpod mini tungsten Carbide for sale in great working condition.I found it great  under sources.
      Exactly the same quality built compared to the standard tc version but in smaller fraction.
      Here's more info and reviews
      http://www.madscientist-audio.com/blackpodmini.html
      http://www.hifi-advice.com/blog/review/accessories-reviews/mad-scientist-audio-blackpods/
    • By caminperth
      Item: PrimaLuna DiaLogue Premium HP Integrated Amplifier
      Price: $4,500 with EL34 valves, $5,200 including EL34 and KT150 valves
      Item Condition: As new - barely 50 hours on the KT150 valves, nothing on the EL34 valves
      Reason for selling: Sticking with separates
      Payment Method: Pickup - Cash, Bank Transfer
      This unit is basically brand new. The EL34 valves were removed and replaced with brand new KT150s prior to initial turn on. It has been used for around 50 hours on the KT150 valves and performed very well.
      It has been fed with clean power from a PS Audio P10 only.
      New the amp is $6,285 and the KT150 valve set is $1,100.
      Comes with remote, valve cage and all packaging. Input valves will be supplied as standard PrimaLuna - however I do have some others I could throw in as part of negotiations for the right buyer.
      Treated with care in a dust-free installation as can be seen in the photos.
      Note - unit for sale is the PrimaLuna DiaLogue Premium HP Integrated Amplifier only. Other gear pictured not for sale.
    • By Angelomatthews
      Item: Philips HUE Portable Light and Bridge (Comes with original packaging and receipt)
      Price: $135 for both (Originally purchased light and bridge for $238)
      Item Condition: Very good. Some very minor scratches from normal use.
      Reason for selling: Don't use anymore. Still Under Warranty
      Extra Info: Philip HUE LED Portable Light and Bridge. Works with Apple HomeKit.
      Here some information about this awesome light.
      Go Portable Light: https://www2.meethue.com/en-au/p/hue-white-and-color-ambiance-go-portable-light/7146060N6
      Smart control, home and away
      Sync lights with music and movies
      16 million colours
      Full control from smart device with HUE Bridge
      Set times etc...
      Bridge: https://www2.meethue.com/en-au/p/hue-bridge/8718696555057
      Control with your voice
      Add up to 50 lights
      Pick up from North Epping (Near Ryde) or can post for $20.
