robbyvikram
FS: Sonus Faber Minima FM2 Bookshelf Speakers
Item: Sonus Faber Minima FM2 Bookshelf Speakers
Price: $1600
Item Condition: New Never Used
Reason for selling: NLR
Extra Info: I have had these speakers for a while now. Never got a chance to set them up. I have collected a lot of Songs Faber stuff over the years. Time to downsize my collection.
Does sonus faber knows that ur selling their merchandise under a diffrent brand name (songs faber)😛lol
GLWTS nice speakers 👍
Edited by Phil sydney
    • By Famo
      Item: jamo sub for repair or spares
      Price: $25
      Item Condition: Jamo sub needs a new plate amp
      Reason for selling:
      Extra Info: jamo sub, box in very god condition. Plate amp needs repair or replacement
      Photos
    • By caleb
      Item: Mad Scientist Audio BlackPod Mini Tungsten Carbide Audio Footers 3pcs set
      Price: $100 plus $10 post
      Item Condition:7/10(has some scratches and wears on one of the tc ball but works fine)
      Reason for selling:no longer required
      Mad blackpod mini tungsten Carbide for sale in great working condition.I found it great  under sources.
      Exactly the same quality built compared to the standard tc version but in smaller fraction.
      Here's more info and reviews
      http://www.madscientist-audio.com/blackpodmini.html
      http://www.hifi-advice.com/blog/review/accessories-reviews/mad-scientist-audio-blackpods/
    • By SoundGuy
      Price: $12,000 $10,500 $9700
      Main Features
      Gain 26.8dB
      Power Consumption 300W
      Width 17.75" (45.1cm)
      Depth 19.83" (50.4cm)
    • By mtan002
      Item: Music Appreciation Appreciation 8th Edition + Multimedia Companion V4.5
      Price: $40 + Actual postage
      Item Condition: Used
      Payment Method: Paypal or cash on pickup
      This book is in fair condition with cover and all pages intact.
      The Multimedia Companion is in good condition.
      You pay actual postage based on your location.
    • By Sarenda
      Item:Dali Speakers
      Price: $250
      Item Condition: Working and in OK condition.
      Reason for selling: Too many speakers!!
      Extra Info: I believe these Dali speakers along with magnificent sounding centre channel speaker  were selling for around $1500 plus in it's day.
      A bargain at $250
      Pick up only.
      Cheers.
