mpearce38
50" 4K for sub $500 recommendations
Hi All,
Looking for a 50" -55" UHD to for the bedroom
Happy to look at 2nd hand and non name brands any recommendations
Must haves are
4K
Needs to be thin as hanging on the wall
Looking at 2nd hand Hisense is there anything else I should consider as good bang for buck
On 04/03/2019 at 8:55 PM, mpearce38 said:
Hi All,
Must haves are
4K
I don't know if you are still interested but Kogan have a 50" Smart TV currently for for $439 + delivery.
JJ
TCL edge lit TVs usually come with an extreemly thin panel but may cost a bit more than the Kogan. TCL generally use VA panels which will give decent contrast and "pop" for a budget LCD.
