EGM Audio
The Best Value Power Cable on the Aussie Market !!!
EGM Audio Grey Series V2 - Our Entry Level Power Cable
EGM offers the best entry level Power Cable (1.5 M length) available on the Australian market under AUD$100 (RRP). We have done extensive testing, both in Australia and overseas with HiFi Specialists, Designers, and Focused Listing Groups. Our product is comparable to competitors’ cables that retail for over AUD $400!
As always, we are so confident in our products that we offer a 100% money back guarantee.
PC grey S2
Features of our High Grade audiophile power cable:
  • Improves sound and picture quality of audio and AV products
  • EMI/ RFI protective screening
  • 16AWG 3 core, 99.999% OFC pure electrolytic copper
  • Designed and Made in Australia—230v AS/NZ Standard with IEC C13 or IEC C7 Plug Top
  • 5 Year Warranty
EGM Audio Hi-Fi Audio Power Cable: Grey Series V2
This Hi-Fi Audio Power Cable is part of EGM Audio's Grey series and it is the perfect entry level power cable. Handmade to offer high quality performance at an affordable price, the tinned copper braid/screen provides superb protection from any external interference from other audio equipment.
Available in a variety of lengths, our sturdy handcrafted cables are a great investment if you’re looking for a long-lasting and efficient power cable! Perfect for home audio set up, our audio power cables are ideal for replacing all your basic power leads with a more adequate cable.
This cable not only delivers excellent performance, it also represents outstanding value for money.
EGM Audio’s Power Cable Construction:
Construction
  • Layer 6: Nylon Sheath – Outer jacket gives extra protection to the cable.
  • Layer 5: PVC Clear Jacket – This outer PVC jacket helps give the cable axial mechanical strength and resistance, while providing a high degree of flexibility to the cable.
  • Layer 4: EMI/ RFI Screen – Copper Tinned Braided Screening will protect your cable/ audio equipment from external and internal EMI. It is the best level of protection for Audiophile Systems.
  • Layer 3: Inner PVC Layer – This resistance PVC barrier protects the inner cores of the cable from any interference on the EMI screen.
  • Layer 2: Conductor’s PVC Jacket – This special compound electronically extruded evenly around the copper conductors are exclusive to EGM Audio’s Power Cables. It has a very low dielectric, and this remains constant over wide frequency ranges making this the best available on today’s market for Hi-End audio systems.
  • Layer 1: Conductors – 3 core, 99.999% OFC multi strand pure electrolytic copper. Highest purity of copper available for any Audio Equipment on the market.
Available for purchase at Retailers and at http://www.egmaudio.com.au
Can you tell us more about the Blue Series cable?
I’m interested in the testing. Are you able to share the results ?
The Grey Series V2 Cable was tested on several systems within HiFi Shops, Audio Clubs, Audio Manufacturers and Audio enthusiasts.
Systems/ Equipment we tested against were single source and amps within a price range between $500-$3,500 and complete systems of up to $10,000. We tested our cable against several cables ranging from the standard manufacturers supplied power cable to leading popular manufacturers (RRP $129-$650) cable.
When tested against standard manufacturer supplied power cable, we had a notable difference with improved sound quality 100% of the time.
When tested against power cables RRP $129-$400 price range we had a notable difference to slightly notable better sound quality with our cable being the preferred cable 100%.
When tested against a series of cable in the RRP $400-$650 price range we were the preferred cable-  our cable was either slightly better sounding or on par but a $550 difference in price.
Notable difference feedback received  ranged from lifting the mid-range woofer to notable difference in the back ground sound. It is important to note depending on the equipment/ systems used there will always be different results.
@EGM Audio
If I may ask. During these tests, were the people informed of the cable changes?
Thanks.
EGM Audio Blue Series V2 Power Cables is currently our most premium cable. (Grey Series is our entry level and our Red Series is Mid-Tier).
It is a heavier gauge cable (12 AWG). During our testing we proved that the cable is suited best on Audio equipment that draws high current e.g. Power Amp & Mono Blocks to get optimal performance.
4 hours ago, rantan said:
@EGM Audio
Thanks.
The Grey Series V2 Power Cable was not blind tested as it over preformed and exceeded expectations over the other power cable. It was designed for a price point of what we believe an entry level power cable should be and what is extremely affordable to all audiophiles.
OK. My question was made in good faith with no hidden intent. Honestly.
I am not, in any way, deriding your product and I have never sought to do so. My question was/is, on what basis was the cable tested and were people made aware at the testing that cables were named as they were changed?
Thank you😀
Thank you😀
And he's answered you.
The cable was not blind tested.
End of story, thanks.
More questions should be directed to the Sponsor, by PM, where I'm sure they'll be happy to discuss with you.
yay
Would you do these in custom lengths? When I get set back up somewhat properly later this year (hopefully this year anyway) I was planning to build a handful of leads ranging from 50cm to 1.5m, as I don't want a pile of excess lead hanging around behind the gear.
They have 0.5m, 1m, 1.5m.
I actually spotted that after I posted and I went looking. Probably want a bit more custom when I'm ready, but will see. Can always make my own if I have to, but for under $100 a lead its easier just to buy them lol
Does that money back guarantee apply to all your products, including your speaker cables? Just wanted to ask because I've never seen anyone offering that in audio.
We offer the following Lengths: 0.5metre, 1.0 metre, 1.5 metre, 2.0 metre, 2.5 metre, 3.0 metre, 4.0 metre & 5.0 metre.
Longer custom lengths are available please email us sales@egmaudio.com.au
Yes, we offer 100% money back on all our products.
That's great, hope to try your products one of these days!
Which cable would you recommend for a network streamer and DAC? I'm assuming the blue series is best for pre/power amp?
We would recommend our Red Series V2 Power Cable for DAC/ Streamers.
Pre/Power we would recommend our Blue Series V2. (Note: Being a heavier gauge cable we recommend purchasing the next size/length (0.5 metre) to accommodate for bends ect.)
http://www.egmaudio.com.au/product-category/hi-fi-audio-power-cables/
Free delivery Australia wide?
free delivery to melbourne?
G'day all. About 6 months ago, Mike Lenehan [the speaker and  speaker cable magician] introduced me to the world of HiFi power cables via EGM Audio. He lent me some red series cables to try on my system. I went home and with skepticism plugged them in from my Nordost QB4 to my Prima Luma HP valve amp. I noticed a difference straight away. More definition and clarity, and this power cables was brand new out of the packet, not run in at all. I have since thrown all my cheap little power cables [ that always come with pricey components] away and replaced them all with EGM red series power cables. A huge improvement for such a small financial outlay. To me, It,s a no brainer.
That was until last week, when I called in on Mike again. He showed me the brand new brown cable made by EGM audio. He asked me to take the sample cable home, give it a go and tell him what I thought. Well, after playing Earl Klugh, Janis Ian and Dire Straits, I phoned Mike up and to quote Darren 69, I said," Mike Lenehan, you're a bastard". Just when I thought that my system was about as good as it could get. Yes, the red series cables are fantastic, but the new brown ones [that I believe will be introduced at the HiFi show in Melbourne in October] are at another level again. Much more detail and clarity. If you're going to the Melbourne HiFi show, check these beauties out as well as Mike Lenehan's ML2 speakers and foilflex cables. You won't be sorry.
BTW, my system consists of Rega P8 tt with the Aphita 2 mc cart, Rega aria phono stage, Prima Luma Dialogue Premium HP amp, with the Lenehan caps and resister upgrade, Rell T9 sub, Lenehan ML2 ref speakers and stands, Nordost power filter/powerboard, foilflex speaker cables and interconnects, EGM power cables and Quadraspire Evo4 HiFi rack.
Do I love my system? Bloody oath I do. Cheers Warwick.
PS. Sorry for the long winded rant!!!!
Well, that's interesting. Might give one a try.
I highly recommend that you do. I can't believe the difference that it has made. Cheers Warwick.
I snapped one up at the show. Will find out for myself soon enough.
    • By EricL
      Item Condition: Brand new Shipping Options: Pickup available but audition is not available.,Shipping is included in price. Suburb or Town: Greensborough State: Victoria Payment Method: PayPal + fees, Cash on Pickup Reason for selling: NLR Further information:
      Bought this from Melbourne Hi Fi in April end for my system set up. Decided not to go ahead.
      Plug is Aus specs and it is fitted with IEC C13 end.
      Shipping cost is included within Aus.
      PLEASE READ
    • By Diatone
      Item Condition: 9/10 Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Smithfield State: New South Wales Payment Method: Cash Reason for selling: Need fund 2 cables of Voodoo Thunder Phoenix Series , gold copper, bought from SNA member. Price per Cable
    • By Exxie
      Item Condition: Excellent used condition Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Carnegie State: Victoria Payment Method: Cash, PayPal, EFT Reason for selling: Too good for my ears Further information:
      2m (190cm not including plugs) with US plug and IEC C15 connector. Asking price includes free shipping. Also selling 1m (see other post).
      Purchased from another SNA member a few years ago but never got around to using them. Apparently excellent cables but I've never been one to notice any difference with power cables. I'd like to move them onto a new home where they can be better appreciated.
      Reviews here:
      - http://www.hifipart.com/news/admin/edittext/my_documents/my_files/TAS2006.pdf
      - http://www.audioasylum.com/reviews/Cable/Richard-Gray-s-Power-Company/RGPC-High-Tension-Wire/cables/115694.html
    • By Exxie
      1m (not including plugs) with US plug and IEC C15 connector. Asking price includes free shipping. Also selling 2m (see other post).
      Reviews here:
    • By bb6152
      Item Condition: Good Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Salter Point, Perth State: Western Australia Payment Method: Cash, Bank Transfer Reason for selling: No longer required Further information:
      This is a US wall plug, 1.5m long high end power cable, which seems to have been pretty expensive back in the early 2000's
      I purchased this power cable privately, a couple of months ago, for $700, from another SNA member in Perth. I used it as my main wall to power board connector (with an Aus adapter), for a while.
      Good power cable but no longer required, because, in search of bigger and better, I have since upgraded to a late model Transparent Audio Reference power cable, after I upgraded my amplifiers. The power cable upgrade was double the price, but not sure whether it is actually double the improvement 😳
      Anyway, as many would understand, I am under home orders to sell anything I am not using.
      Can easily ship by Express Post at purchaser's expense.
