alessiman
Benq W2700 / W5700
15 minutes ago, jmone said:
FYI - I've already bumped into the HDMI limits even with 18Gbps on my JVC x7500 driven from an HTPC!  Thankfully, madVR's HDR --> SDR mapping is making it all work well on my main HT setup without having to go above 8-bit.  I have the one and only HFR HDR UHD (Billy Lynn) and I'm thankfully, I'm unlikely to watch it again!  The other issue is I also shoot UHD 50fps Video from my video cam (Canon XF400 and GoPro5) and while these are also 4:2:0 I'm using madVR for the Chroma scaling so this would be out with the Epson.  I've already spent many many hours on my X7500 setup working around the 18Gbps limit and as this is just a secondary setup it is PITA I'd prefer to avoid if possible.
If we have one in the office tomorrow would you like to come to Newington (during business hours) to test it out before they go on sale?
@Matt_Walker I get the limits with Pixel Shift, but was more pointing out the issue with what signals the Epson can even accept on it's 10.2Gbps chip and this can be a PITA auto switching settings based on media type to fit under this limit.
The Epson was just slow to game but so were Sony, only jvc at start if uhd had the full bandwidth chip set. If lower bandwidth epson issue for you rule it out. But then will be looking at current gen machines rather than refurbs and run outs and such :)
@Matt_Walker  I could take you up on that offer on Friday if that works (I'm in CBR with work at present)!  I warn you though, I may try to leave $2.5k on the table and just do a runner with the PJ!! :)
lol - I wish you luck - Dirk (our resident "big guy") tackles with Rugby like force!
I will try and tee that up for you tomorrow if they are not on their way out to Media already...
As long as he only runs like a Front Rower I should be fine... if I make the first 10m!!!
Seriously thanks for the offer if the timing works.
Also.... being new to single chip & colour wheels + Pixel Shift, don't you have an issue where each individual pixel is only lit something like only 1/8th to 1/16th of the time? eg 4 Colours on the Wheel x 2 (or 4?) wobbles?
If the time on Friday works out, I'll can bring out my HTPC setup for the x7500 with a couple of samples if you like with:
- UHD BD (std and Billy Lynn)
- UHD Camcorder
- 3D BD
Edited by jmone
I suck at Maths and NO ;)
I don't understand the complete way the solution works but I know that at any given point in time there is 4 pixels on the screen, all well lit, all the right colour and all being addressed individually.
Someone much smarter than me figured out how to do it and it works the best today it ever has!
We have a UHD203 in the office too if that helps?
Edited by Matt_Walker
As you say, its about how it looks not how it works :)
The HTPC (it is a SFF) and will allow a quick test of this media both with HDR processed by madVR and with HDR Passthrough.  A fair few of us use HTPCs.  If anyone has anything in particular to test suggestions are welcome!
Just curious jmone on the hdmi cables used . The 2700's specs are the latest hdmi iteration so should handle uhd @ 60hz ;  their even got the "b" suffix so can handle HLG HDR as well .
Quote
X2 HDMI (2.0b/HDCP2.2)
Just for interest I came across dpl labs certification programme yesterday that has heaps of info on the best true 18gbps cables and the lengths they can pass ; notable how some active cables don't cut it :whistle:   http://www.dpllabs.com/page/dpl-approved-products
If you can bring any of these cables that takes an important factor into a/c if your lucky enough to have any of them..   My wireworld chroma 6's like the chroma7s tested have no problem with 30 feet of 60hz uhd so they are accurate ..
Edited by cwt
Thanks CWT - good point - we have some Bluestream gear that we used for the launch that may come in handy for this!
@cwt I only use certified cables, though for this test I'll just bring a short one ....
2 hours ago, EZYHD said:
Can send a Ruipro for the test view:)
Hi Keith - nice cable!  Not sure it would make it in time if we are looking of Friday but Matt may be interested.
On 11/03/2019 at 2:05 PM, jeffpr said:
for those needing hdmi cables to go with a new projector the comsol hd pr 100..... 10 mt cable which gets a lot of love here is $35 at cpl online
I need 10m to work with my Yamaha 2080.
Hey jmone..  can you come into the office tomorrow around 3pm please??
Ash, Dan and Dirk will be there to help you!
Perfect!  Just landed back in Sydney (a Dash8 in that storm was "fun"!).  I assume it is 6/2 Holker St, Newington?
Also let Dirk know he will not be needed...only small and slow members of the team thanks :)
Thanks Keith - would be good to have a cable we can recommend - might take you up on that offer!
Yep spot on - I will let Dirk know to disappear at the appropriate time ;)
All ready to go - HTPC, test files and cables.  Thanks!
Sure sent PM.
Firstly, Matt - thank you for your invitation to have a look at the W2700 and please also pass on my thanks to the team at Benq.  They were very accommodating with the initial setup and even offered me a Lamington many times!
Now onto the W2700 (and keep in mind this is a $2,500 unit and they one I was looking at was a pre-prod unit with older firmware),
The Positives:
- It is Bright and it is Sharp.  Much more so than my JVC x7500 or the Epson TW9000.
- I noticed no issue from the DLP / Colour Wheel tech at all.  Looked solid as a rock
- It had no issues accepting my tested signals formats such as UHD 23.976/50fps @ 8-Bit in RGB and 4:2:0 @ 12-Bit.
- Signal Sync time when changing signal format was pretty good (well much better than the JVC anyway) but not as quick as a TV.
- No Issue with HDR and SDR activation.
- Frame Packed 3D worked out of the box (but I had to keep enabling 3D Auto as it keep changing to OFF in the menu - it was suggested this could be due to the Pre-Prod unit and the older firmware).
- It is light and portable
- The price is very appealing for all of the above!
Areas to Note:
- The team at Benq spend about 30min trying to get (including the with a test pattern) a perpendicular (not trapezoidal) image with straight (not curved) edges... and we got close but no cigar.  I'm used to plonking down the PJ and adjusting the image using 4 options (Zoom, Focus, Lense Shift Up/Down, and Lense Shift Left / Right).  On the W2700 there was a lot of minute shuffling the PJ left, right, tilt, etc.  Alot of this This would be hidden by a bit of overscan on a felt boarder but if you are a perfectionist it will drive you around the bend.  They team also wondered if it was an issue with the unit itself and while they looked for a 2nd unit we ran out of time.
- There is also noticeable but steady fan noise and plenty of heat exhaust but it was on a table and I was only 50cm away from it.  There was was an occasional noise that sounded like a HDD seeking from the unit.  I did not notice the noise as I moved around the room
Summary:  I did not try to run away with the Pre-Prod unit at the end of the demo.  The electronics are great and the image it beams works really really well for what I want.  What is holding me back is simply the lack of install flexibility.  It's relatively short throw and it wants to be dead centred and even then you have to make mm adjustments.  In short, you are going to need to bend your room to fit the PJ (not the other way around).  For me I really want a PJ that can be on a shelf at the back of the room most of the time, then be able to take it outside for a party and then put it back.  If you are happy with a ceiling mount pole where the projector is at the same height (or lower) than the top of the screen and dead centre then you will be fine (with a screen with felt boarders).  That said..... it's 1/3rd of the price of my JVC... 1/3rd!  I've some thinking to do.  If I can live with the placement issues then it will be a no brainer at this price point!
Edited by jmone
...and here I go.  Working out how to accommodate the W2700 already.  Get a bigger screen (120" instead of the 100" I've got so I'm not maxed out on the wide end of the Zoom).  Raising the screen height and mounting the W2700 "under" the shelf.  I really want the W2700 but I just don't know if I can live with it.  Sounds like my first Girlfriend!
I work up this morning and I'm still torn.... Any advice for a $2.5K budget TW9000 replacement, should I get:
- BenQ W2700 : and live with the finicky placement issue, or
- TW9300 : and live with running it at 4:2:0 in UHD (or even RGB @ 1080p at which point it is exactly like my dead TW9000)
id grab the 9300 personally it comes with all shift necessary to adequately setup and configure without looking to change your screen and revolve your room to fit in :D not sure you'd find anything else at $2.5 with full warranty (which is very decent on the epson) and like new basically :)
ps I remember also inflexible epsons in the past (6600?) would never touch one of them either.
