h2oxide
FS: Hi Fi Racks 2 Tier Podium Reference
Price: $600 non-negotiable, pickup only (Over $1000 RRP)
Item Condition: Immaculate, used for one month
Reason for selling: Moved to a desktop setup a while ago
Payment Method: Cash
This is a modular system; the legs dividing the tiers can be bought separately to extend height between tiers, and more tiers can be added.
Includes original packaging
Width 612mm Depth 500mm
Tier 1 Height 85mm
Tier 2 Height 65mm
IMG_20170408_125414.thumb.jpg.a1ba294b6d34bc97394a84190047814f.jpg.14aa553b6b76cc198203141210aa3ba7.-a112246d94fc9cd47ad94c.jpg.f17722bf4b13cc4cef7a004dd01aede1.jpg.27f745dd6a260aae3e3cdaf73511d7d8.jpg
    • By surprisetech
      Item:  Sansui A-7 Integrated Amplifier and T-7 Auto-search Tuner combination.
      Price:   $150
      Item Condition:  Quite good for their age.  ID markings have been engraved on the top edges of the front panels as shown in the photos, but these are not really noticeable when installed.
      Reason for selling:  No longer required.
      Extra Info:  I happily used this combo for a few years in a second system until the Tuner auto-search drive cord broke.  By the time I got around to repairing it I'd already put a Rotel RA-970/Onkyo T-4700 combo into that system.  The tuner has since been repaired, 5 new power supply caps have been fitted to the amp, pots and switches cleaned and both items are fully functional.  (Photo of amp internals is before the caps were replaced.)
      PDF files of Tuner User Manual and both Service Manuals can be provided.
      AMP FEATURES
      Discrete class A/B amplification. Inputs for 5 sources including Phono Input. LED Output Power Level Meter. Speaker switching. Loudness control and High Filter switch. Front Panel ‘Tape 2’ input/output connections. Microphone input with input level control. AMP SPECS
      Power/Distortion:  45W/Ch into 8 Ohms @<0.05%THD
      Freq Resp:  5Hz – 60kHz +0.5/-2dB
      Hum & Noise:    PHONO 80DdB          AUX/TUNER/TAPE 95dB
      RIAA Curve deviation:  +/-0.5dB (20Hz-15kHz)
      Dimensions:  430 x 132 x 247
      Weight:  5.8kg
      TUNER FEATURES
      Motorized Auto-search feature. 5-step LED signal strength meter. 3-LED Dial Pointer Tuning Indication. Sensitive front-end and very good alternate channel selectivity. TUNER SPECS
      FM Usable Sensitivity (Mono):  0.9uV
      FM 50dB Quieting Sensitivity (Stereo):  19uV (37dBf)
      FM Alternate Channel Selectivity:  60dB
      FM S/N Ratio (Stereo):  72dB
      FM Distortion (Stereo):  <0.15%
      AM Sensitivity:  300uV/m
      Dimensions:  430 x 87 x 260
      Weight:  3.4kg
    • By surprisetech
      Item:  Yamaha RX-V667 7.1 AVR with Remote and YPAO Microphone.
      Price:  $250  $200
      Item Condition: Very good.  Fully functional. Some marks on the top cover and right-hand side as shown in the photos.
      Reason for selling:  Updated.  No longer required.
      Payment Method: Pickup - Cash, Paypal, COD Only.
      Great AVR with 6 HDMI inputs, support for the HD Audio formats and some I/O options not now provided on the newer models such as full 7.1 Pre-outs, 7.1 analogue inputs and Zone 2 capability.
      Amp assignment allows two of the power amps to be assigned to Zone 2 duties or for bi-amping the front mains if only 5.1 is utilized in Zone 1.
      Discrete class A/B amplification was re-introduced in this model after the luke-warm reception to the previous RX-V665 which used power amp modules.
      I used this unit for HT switching, processing and Centre/Rear amplification in my main system until it was replaced recently with a new Marantz NR-1508 to get the networking, remote app and Heos features.  It was relegated to 2-Channel duties in the family room, but has now been replaced there by a recently acquired Audiolab 8000A / 8000T combo and I can't justify having it sitting around gathering dust.
      SPECS & FEATURES.
      POWER:  90W RMS/Channel using discrete Class A/B Amplification.
      VIDEO INPUTS:  6x HDMI, 5x Composite, 1x S-Video, 2x Component.
      AUDIO INPUTS:  1x Calibration Microphone Input, 6x Stereo RCA, 1x Multichannel (7.1) RCA, 2x Optical S/PDIF, 2x Coaxial S/PDIF.
      VIDEO OUTPUTS: 1x HDMI, 2x Composite, 1x Component.
      AUDIO OUTPUTS: 3x Stereo RCA (AV out/Audio out/Zone2 out), 2x Subwoofer out, 1x Multichannel Preout (7ch), 1x Headphone.
      AUDIO FORMATS: Dolby TrueHD, DD+, DTS-HD Master Audio, DTS-HD HR, DD-EX, DTS 96/24, DTS-ES, Dolby Pro-Logic II, DTS Neo:6, etc. etc.
      FEATURES:
      ·        YPAO Room Optimizer (microphone included).
      ·        ‘SCENE’ function and Input naming for easy operation.
      ·        Zone2 capability.
      ·        HDMI & AV Input on Front Panel.
      ·        Headphone socket.
      ·        FM RDS.
      ·        Pure Direct mode.
      ·        Large clear front panel display + OSD on TV.
      ·        Multi-channel analog inputs & outputs for external decoder &/or external amplification.
      DIMENSIONS (W x H x D): 435 x 151 x 364 mm
      WEIGHT: 10.5 kg
    • By ChrisHooton
      Item: MIXED BUNCH OF VINYL
      Price: AS LISTED
      Item Condition: AS LISTED
      Reason for selling: DOUBLES
      Up for sale are the following mixed vinyl
      Matt Corby - Telluric Box Set
      5pc Vinyl Box Set
      Still Sealed , Mint Condition
      $180
      Captain Beefheart - Trout Mask Replica
      RSD 19 Press
      Still Sealed , Slight tear in outer Plastic Shrink, Near Mint
      $60
      Kanye West - Beautiful Dark Twisted Fantasy
      VG/VG
      $50
      Drake - Scorpion
      Mint Sealed Condition
      $50
      Pickup from Caringbah or I can post anywhere at buyers expense
      Payment via cash on pickup or PayPal if posting
    • By ChrisHooton
      Item: OZ HIP HOP VINYL RECORDS
      Price: AS LISTED OR $470 for the Lot including Postage
      Some Oz Hip Hop Vinyl
      Must Volkoff - White Russian
      VG+/VG+
      $65
      Discourse - Megalomaniac
      VG/VG
      $40
      VG/VG
      $40
      Prophet Rayza - Year of the Rayza
      EX/VG+
      $40
      Crate Cartel Classics - Phil & Flu
      VG/VG
      $40
      Mantra - Telling scenes
      EX/EX
      $40
      Mata Must Flu One Sixth - Four Aces EP
      $80
      Kogz - Trash Talk ( Signed )
      EX/EX
      $135
      A.B Original - 2 Black 2 Strong
      7” EX/EX
      $30
      Priced individually or I’d sell as a bulk lot for $470 for the Lot including Postage (listed price is $510 plus postage would be at least $20)
      Can post anywhere at buyers expense, payments via cash on pickup or PayPal if posting
      Cheers for checking them out !!!
    • By Frank Prowse Hi-Fi
      Item: FS: Ex-Demo Quad QC-24P Phono Pre-Amp
      Price: $2,249 (RRP; $2,949) inc. shipping nationwide.
      Reason for selling: Client changed his mind while unit was in transit to us
      Payment Method: Pickup - Cash, Bank Deposit
      Extra Info: Current model. This unit is highly acclaimed and comes from the brains of Tim de Paravicini. Unit was ordered in specially, but after further discussion client has moved up the food chain. Nice feature is the unit has a variable output, so can be used as a TT preamp straight into a power amp.
      Rather than send back for a restocking fee, happy to offer here as new complete with FULL WARRANTY. Unit has been opened only to take pictures and clock about 20 hours on the tube, hence the "EX-DEMO" designation. We have partly run it in for you!
      Supplied with original box and packaging.
