SHF Mona Vale
Audio Space AS-6i (300B) Tube Integrated Amplifier
Item: Audio Space AS-6i (300B) Tube Integrated Amplifier
Price: $3800
Item Condition: Excellent Condition
Reason for selling: Trade In  Product
Payment Method: Pickup - Cash, Paypal, COD Only This product is available for in-store audition and is store pickup only
Extra Info:  https://sydneyhifimonavale.com.au/products/audio-space-as-6i-300b-tube-integrated-amplifier
Outstanding Features
Rugged stainless steel chassis
High quality EI transformers and components
Switching between direct and line input
Switching between high and low negative feedback
Headphone jack
Innovative tube circuitry with choke coil
Specifications
Output Power: 2 x 21W (Triode – Class A Push-Pull)
Output Impedance: 4, 8 ohm
Input: Single-ended RCA x 3
Vacuum Tubes: 2 x 6N9P (6SL7 or ECC35)
2 x 6N8P (6SN7 or ECC32)
4 x 300B
Dimensions (W x H x D): 400 x 190 x 300 mm
Net weight: 22 kg
Edited by SHF Mona Vale
    • By ssb102
      Item: 4x Fanless ROON ROCK Servers
      Price: Varies, see below
      Reason for selling: Surplus!
      It's 2020 and it's high time i cleared my backlog of projects.
      I have FIVE Fanless Roon Rock Boxes for sale.
      All totally silent with SSDs running the latest version of ROON ROCK
      Small enough to fit on a bookshelf and use far less power than a full PC or laptop so you can really leave them running.
      Your wife/girlfriend/dog/cat wont even notice.
      3x WYSE Zx0
      (2 Units) 8GB + Ethernet + Wifi $120 ea
      (1  Unit) 16GB + Ethernet + Wifi $150 ea
      (1 Unit left! ) 8GB + Ethernet + Wifi $120 ea
      1x Dell Optiplex FX160 with 32GB SSD
      $200 $150 PRICE DROP
      Intel Atom platform
      Gigabit Ethernet  (via USB 3.0 adapter, FREE)
      Wifi optional extra
      ALL BOOT INSTANTLY AND WORK FLAWLESSLY.
      These SSD sizes are more than adequate to hold the ROON database because with ROON your music is stored elsewhere.
      Priced fairly these are an excellent way to get started with ROON.
      Reasonable offers considered. Discounts for multiple purchases or pickup.
      Lowballers and timewasters will be sent a copy of the Betoota Advocate.
      ARSE mug not included.
      Shipping available just DM me for a quote.
    • By Vladas
      Item:
      MASTERSOUND INTEGRATED TUBE AMPLIFIER BOX R
      Parallel Single Ended in "Class A" Integrated - Made in Italy
      Power: 2 x 35 Watt
      Tubes complement: 2 x ECC802 - 6 x EL34
      Input: 3 line + Phono MM
      Output: 1 line
      Load imped.: 4-8 ohm
      Bandwidth: 18 hz / 25 khz 0 db
      Output Transformer: MastersounD
      Automatic Bias
      Supplied with remote control - R version
      Negative feedback: 0 db
      Dimensions: 43,6 x 40,9 x 18,5 cm
      Weight: 24 Kg
      Made in Italy
      Price:  $3000 (RRP - $5200)
      Item Condition: Brand New - still in the box
      Reason for selling: Change of financial situation
      Pure Class A  2x35 Watt PSET (Parallel Set) which is used in the very high end tube
      amplifiers like Aries Cerat $30K USD. This gives you uncompromising power to run in pure class A almost any 89+ db speakers.  Lack of power is Achilles weak spot of most tube amplifiers and I believe PSET is the best solution used by the very high end manufacturers. Legendary Mastersound brand - makes PF100 tube amplifier $50K USD. Fabulous musical EL34 tubes. To my knowledge, this model is absolutely the best value for integrated tube amplifier in that price range; made in Italy but priced similarly to comparable Chinese models. Includes very good phono pre-amplifier - same as in the flagship models.  This is Box R version with remote control (cost $330 AUD extra).
      Links below shows additional information about The Box and Mastersound brand in general:
      http://www.mastersoundsas.it/1/reviews_4451773.html
      https://soundapproach.com/mastersound-box-r-integrated-amplifier-class-a.html
      https://www.technologyfactory.eu/en/mastersound/integrated-amplifiers/mastersound-box/a-5384-10000401
      https://forum.audiogon.com/discussions/axpona-2018-integrated-mastersond-box
    • By russell66
      Item: Klipsch Synergy Home Theatre Speakers
      Price: $600ono
      Item Condition: Very Good all working well, some minor marks.
      Reason for selling: No Longer Required
      Excellent sounding home theatre package. Klipsch are well known for their cinema speaker designs.
      Fitting out many cinemas and shows with these speakers.
      They excel with soundstage, dynamics and detail.
      Package consists of ...
      2 x Synergy F10 Floor-standers
      2 X Synergy B20 Bookshelf's
      1 X Synergy C1 Centre
      1 X SW 350 Sub Woofer
      Post is available at your cost and risk.
