08Boss302
2ch Amps - curiosity to switch/upgrade
Hi all,
im thinking is like to try a different 2ch amp at home.
i currently have the Yamaha AS-1100 and am happy however curiosity has set in and an wondering if more power and a different signature sound will also satisfy me
some might recall my adventure getting this amp and the fact I have a Matantz AVR still set up at home and utilise a Beresford to switch between amps for HT and 2ch listening.
speakers are still KEF Q950
the Vincent SV237mk is still knocking at the door loudly and I see now the Rotel RA1592 is on sale at a lot of places for approx $2700.
I know the Vincent is a tad warmer and more powerful but the RA1592!ivenot heard but see it to be more powerful- anyone have experience with this amp?
being that I consider Marantz sound quite warm and smooth, the Yamaha sound is very neutral but still smooth (not as smooth), but not as “forgiving” as Marantz...
To spend the money on anew amp I’m keen to  look and listen to amps that have more power than the Yamaha as the KEFs like being driven to get the most out of them
any suggestions out there to add to the list Vincent and Rotel?
budget up to say $3500 but less if possible!
Understanding I’ll get suggestions above and double that but springing to mind is Roksan, musical fidelity and I think Onkyo have one for about $3k also.
Whatever I look at must have x4 analog rca options, digital inputs and dac not important as I have an Oppo 205 which I’ll connect to it for that purpose but it’s a full package like the Rotel that is fine also.
thanks all
keen to read your suggestions and any experiences
For $3.5K I would recommend going used. You will get $10K sound at today's new price.
Thanks @t_mike
I could/would consider used but tbh it wasn’t my first preference
Any brands/models you think should be on my radar on the classifieds?
@08Boss302 new ,look at an Exposure 3010S2D, 110wpc, $2795 +$595 for DAC to give you digital inputs, Andrew at Audiofix is a gentleman to deal with, your KEF's will sing
Cheers @wen
I’ll have a look into this. I see it comes in black too which is a preferred colour choice
Do a little bargaining, do a little stretching...
Now we're talking.
The Audia Flight FL3S is another you should listen to.
Can be had for $2500 used.
Ive been surprised how good it is.
If you intended to keep the yamaha, I'd suggest tubes. My KEFs sing with Prima Luna power amp, custom analogue audio pre amp. I have a transistor integrated (saving for, maybe, a Naim or Rega), but the SQ and listening experience with tubes is a mighty fine thing.
Thanks guys
I’ll look into the Accuphase and Audia Flight suggestions
if I make this change and prefer it I’d prob look to sell the Yamaha, the Vincent offers tube and solid state benefits, I did like this when auditioned it prior to buying the Yamaha and it never left my psyche.
hardest part is finding a retailer that sells KEF and Vincent or others.
i have just noticed Denon make the 1600ne also and it might be worth me looking st the marantz 8006 which I didn’t look at last time
the last rotel i listened to sounded sounded a little thin but all reviews on the 1592 state the opposite.
Anyone out there that listens to rock and metal have experience with the 1592?
i cant really afford to jump on the SV 700 https://www.selby.com.au/vincent-sv-700-integrated-amplifier-black-sv700b.html
But this one is of high interest still... https://www.selby.com.au/vincent-sv-237mk-integrated-amplifier.html
Selby had 30% off these about 4 months ago, i shouldve leaped but didnt, missed a bargain i guess
oddly the 237 seems to have more power than the 700 but i dont really understand the power thing in total so my guess the 700 has the trumps on it given its heftier price pont.
the Rotel seems such great value at the moment and has a tonne of power.  https://clefhifi.com.au/catalog/product_info.php?cPath=34&products_id=2788
As Denon and Marantz come from the same house (i believe) they should be similar house sounding.   The Denon seems to pack a few more features and power into its offering https://www.apollohifi.com.au/audio/stereo-amplifiers-receivers/denon-pma1600ne-stereo-integrated-amplifier-black.html
I live in melbourne, i can get to Clef and listen to the rotel thru my speakers as its where i bought my speakers and the guys there are good to deal with.  I can also get to Selby but they dont stock Kef so its a bit of trial and guess.  Denon if i want to go further with  i'll find a retailer in melbourne with the PMA 1600ne i am sure
The OP is looking for more power - so why would an Exposure (as you say, 110wpc - presumably into 8 ohms ... no specs for 4 ohms) give him an appreciable amount more power than his Yamaha AS1100 (specced at 160w into 4 ohms - so probably 100w into 8 ohms)?
actually spec'd at 90 WPC, just suggesting something spec'd higher @110WPC, also reading the OP's initial thread when looking for an intergrated amp , its one that was not mentioned, no different to suggesting an amp above his budget like t_mike suggesting the Accuphase in the classifieds, all food for thought
It's not just about watts, higher current amps at the same wattage can produce better sound also in some cases.
For amp suggestions see regular poster Cafads reviews of many items.
Also, consider used Yamaha AS 2100 and 3000 amps and Musical Fidelity.
Separate preamp and power combos can be put together as well with potential better results. See previous forum posts on this.
Edited by Al.M
Agreed, t-mike.  Unfortunately, integrateds aren't typically built with "high current" in mind.
    • By Supedeloop
      Item: Rotel A12 Intergrated Amplifier, 12 months old
      Price: $900 ono $720.00 inclusive $20 Donation
      Item Condition: Excellent
      Reason for selling: Change in direction
      Payment Method: Pickup - Cash
      Extra Info: Item is in excellent condition minus a little dust. Have box and I think all the original packaging.
    • By doubleaitch
      Does anyone out there have advice for a newby to the vinyl school trying to find that sound I had in the early eighties from a Luxman system with Yamaha NS690 III speakers.  They are monitors and I still have them although one of the mid range and possibly a tweeter has been blown.  I have thought about having them repaired (as I can get the parts), but I am considering if there is something out there comparable.  I have a pair of ELAC 2.0 5.2 bookshelf speakers and they are OK.  I have been pretty happy with them but I miss the clarity I recall from the Yamaha's.  I have tested the ELAC's on a few of my 'test' tracks like Elton John's Song for Guy and Fleetwood Mac's Landslide and they sound nothing like the clarity of the Yamaha's.  Is it the fact that the Yamaha's are considered monitors?  They are as sharp as a tack which may not suit a lot of people but I do love the clarity which I have been unable to get from the ELAC's even through an Ortofon Quintet Blue on my MMF7.1 turntable. And what about the 2 way / 3 way difference in modern speakers - does that mean less clarity or is it just a tech advancement that means we get more from mid range now.  So confused atm.
    • By audio_file
      Item: Rotel RA-820
      Price: $150
      Item Condition: Scratched
      Reason for selling: Replaced
      Payment Method: Pickup - Cash, Paypal, Bank transfer
      Specifications from https://www.hifiengine.com/manual_library/rotel/ra-820.shtml:
      Power output: 25 watts per channel into 8Ω (stereo)
      Frequency response: 10Hz to 40kHz
      Total harmonic distortion: 0.4%
      Damping factor: 20
      Input sensitivity: 2.5mV (MM), 150mV (line)
      Signal to noise ratio: 75dB (MM), 95dB (line)
      Speaker load impedance: 4Ω to 16Ω
      Dimensions: 430 x 66 x 271mm
      Weight: 5.5kg
      This was used for PC desktop speakers driving KEF Q1 speakers.
      I tried it on my Spendor SP2/3R2 and it had no problem driving these.
    • By Willmax
      Item: YAMAHA M-2 Power Amplifier, 240WPC @ 8 Ohms, 240v multi-voltage unit
      Price: $1100
      Item Condition: 8.5/10
      Reason for selling: NLR
      Payment Method: Pickup - Cash, EFT, PPF
      This M2 power amp has served me well for a number of years and never missed a beat, cosmetically it is pretty neat considering its age (see pictures), all lights working and the green LED VU meter is a treat!
      I've had the speakers terminal upgraded and the new ones are pretty chunky and work well with banana or spade terminals.
      I've been in two minds about selling it, but it is finally time for some one else to enjoy it!
      Happy to take to Pack & Send for Australia wide delivery.
      Please send any questions strictly via PM.
      http://marantzhallo-fi.blogspot.com/2016/12/jims-yamaha-m-2-power-amplifier-ns.html
      https://www.hifiengine.com/manual_library/yamaha/m-2.shtml
    • By Lincolnbl
      Items:
      Mission M73i Floorstanding speakers (in Beech colour)
      Mission MC72 Center Channel (in Charcoal)
      Mission M70 Surround Speakers (in Charcoal colour)
      Velodyne CHT12R Subwoofer
      Yamaha RXV3800 AV Receiver
      All items have been well cared for. Never abused. Non-smoking house.
      Price: $950 $750
      Item Condition: Used. Well looked after.
      Reason for selling: Upgrade time.
      Extra Info: Selling as a set at this stage. But if interested in individual components reply indicating your interest and will consider a split if most stuff goes.
