Razuu
Luxman Int Amps - ownership thoughts...
On 24/02/2019 at 5:21 PM, ashmeow said:
Are they really that good Bill? 🧐
Yep. They sure are
1 hour ago, Bill125812 said:
Yep. They sure are
Hmmm if my speakers were not so big I would bring them with me when I come to your place.
Well you’ll just have to put up with my speakers.  I think you might be impressed
Hi. Great to hear from proud Luxman owners. A common theme of great built and great sound.
Hi [mention=131321]initforthemusic[/mention] , thanks for your comment. My rating of 8 for the 550AX is if you have a small room, efficient speakers and don't want to rock the house. When I moved, I went from 4 X 6 room with standard ceiling to 6 x 8 with 3m ceiling with open space on two sides, it just didn't fill the room. Most things were lost but when I got the 590AXII, the Luxman Class A sound was back.
When I got to Thailand, it was a very difficult decision to go for the 509X instead of the 590AXII. The 509 got the nod because it runs so much cooler than the 590 and in the heat of Thailand that's very important. BUT I still very much miss the emotion that the 590AXII generates.
Cheers.
Have you thought of adding a Luxman tube pre-amp! :-)
Absolutely!! Have research and priced a Luxman CL38u Tube Pre Amp. Very competitively priced in Thailand.
But the CL38 is not a Class A. Most reviews are glowing but from my discussions with a very independent seller, some have said the CL38u is a bit "mushy"?! So, the search continues....
Hi Razuu,
I am enjoying the 550AX very very much :) specially with my new B&W 703 S2, I am finally doing the amp some justice.
In summary, the 20w can easily drive them and the music sounded a lot better than what I demoed with the same speakers or similar ones at the stores.
I must say it's the amp :)
Hi
Fantastic. I am delighted that you finally got the speakers you wanted. Can't beat Luxman Class A (except for the heat)...
My next "toy" is an upgrade on my existing power cables, really expensive for the quality brand/models.
Take care and keep listening.
On 19/02/2019 at 8:00 PM, Razuu said:
Hi
This is actually a reply to another SN member's review of his Luxman 509X Int Amp.
After replying, I thought it would be nice to share it with other SN members. Just my thoughts on the three Luxman amps I have owned over the last few years.
I have been lucky enough in the last few years to have own the 550AX Class A as my first Luxman Int Amp, then due to a house move, needed more power, I got the 590AXII Class A, now living most of my time in Thailand, I am enjoying the 509X Class AB. I have also listened to the 507uX Class AB extensively.
My gear from the 550AX to 590AXII and 509X haven't changed - Macbook > JRiver or Roon App > Chord Hugo TT DAC (Cable = Audioquest Diamond USB from Mac to Hugo TT) > every Luxman Amp (Cables = MIT SL8 RCA interconnects) > Spendor D7 SPEAKERS (Cables MIT SL 9).
Quick rating of each amp:
1. 550AX Class A 20 watts pc. (Build - 8) - (Look - 10 - if you like the Retro style) - (Power/Drive - 8 - ONLY if you have a small room, efficient speakers & don't listen loud) - (Clarity/Details - 7) - (Quietness - 7) - (Soul/Emotion - 8
2. 590AXII Class A 30 watts pc. (Build - 9) - (Look - 10 - if you like the Retro style) - (Power/Drive - 8 - ONLY if you have a small/medium room & efficient speakers) - (Clarity/Details - 8) - (Quietness - 8) - (Soul/Emotion - 9
3. 509X Class AB 120 watts pc. (Build - 9.5) - (Look - 10 - if you like the Retro style) - (Power/Drive - 9.5 - Most room sizes and most speakers) - (Clarity/Details - 9.5) - (Quietness - 9.5) - (Soul/Emotion - 8)
Quick summary of each amp:
1. 550AX Class A 20 watts pc. Fantastic Class A Int Amp. Low power, which leads to other limitations. Only buy if you don't have enough money to buy the 590AXII for more Power and Soul/Emotion.
2. 590AXII Class A 30 watts pc. Great Class A Int Amp. Still low power for larger rooms. BUT simply amazing tones that ooze Soul and Emotion especially in vocals and acoustic music. Luxman Class A Masterpiece.
3. 509X Class AB 120 watts pc. Stunning Class AB Int Amp. Tons of power and punch. So quiet, so much details, so clean, etc. Only negative against the 590AXII - doesn't have that Luxman Class A Soul and Emotion. Against Class AB Amp in this price range, the 509X has very few to no rivals.
My "Ultimate" Amp:
*A Luxman because of the build quality, features and acceptable price. Compared to nearest & equal rival, Accuphase, Luxmans are a bargain.
*A Luxman Class A Int Amp for the tone, soul and emotions that they produce.
*A Luxman Class A 60 watts pc Int Amp!! - maybe impossible and imagine the heat!
Play more music!
To the 2 SN members who bought my 550AX and 590AXII, hope you are enjoying them.
Photos of 550AX, 590AXII and 509X
5ac5d46941bef_170915OOLLUXMAN5EDIT-02025.thumb.jpg.dcd13f8535e1b60cfe7a960eccef206d.jpgLuxman-590AX-II-Front-3.thumb.jpg.5fe56789e3e434b9b33f87d255957bbe.jpg751631789_Luxman509X.thumb.jpg.0547071190c2a5f7b393473023bd6a90.jpg
Hi there, good to hear about your sonic impressions. I have just acquired an older SQ507X 50W integrated amp that, even though it is of the 1970's old school of solid build quality, it sounds remarkably clean ... on one channel. I have two new sets of the driver transistors on the way, NEC 2SC1161/2SA653. The right channel 2SC1161 is rather burnt looking. I shall do a full re-capping while I'm at it. Love the looks and switch gear of this 45 year old amp and also that it has Pre-Out and Main In sockets.
It's not quite the classy and shiny look of your gorgeous 550/590 models, but I'm happy to have it in house all the same. It came with a good old Marantz Model 1030 at the same time :)
Looks great. Are you going to restore it?
Well done.
Well done.
Yes indeedy! The main power supply caps are in excellent condition, so I won't change them out just yet, though may bypass them with some quality ex Russian military 0.1uF PIO caps I have here. Every other cap will be swapped out for Nichicon FG stock and WIMA models for the smaller values. This is what I did in the restoration of an Akai AM2600 integrated that turned out a treat, the new owner is very happy with it! It retained it's punchy and communicative analogue character, while gaining a lot of transparency and focus. The phono stage turned out really well, perfect for the two turntables currently connected to it.
The Luxman SQ507X also has two phono stages, both MM, one of them being adjustable for input impedance. I'm about to start the strip down this afternoon.
please take progress photos and post...I am sure lots of people would love to follow the restoration.
Sure thing. I do that with all gear, turntables, amps and tuners :) I'm a photographer from way back and I just can't help myself. I should probably start a new post for that one.
 During a general restoration, I don't go as far as completely re-painting the rear panel though, that's beyond my skill base and besides, I like to have some of it's original patina of age, far too hard to screen print the decals and socket designations :) A good clean though is definitely on! Circuit boards are cleaned, new caps installed, any new transistors, diodes and dodgy looking resistors are up for renewal. Power supply diodes will be replaced with modern UF soft recovery types, as well as a few of the others on the boards. Initially, I will only replace the driver trannies on the right channel, the left is fine, but I will see how the sound balance is with both up and running. The protection circuitry will probably be completely renovated, as it was this in the Akai that failed and switched off the amplifier. Once replaced, all was well.
 The same process will be for the Marantz Model 1030, a sweet little amp, that after a good clean (It was twenty years in a farm shed, as was the Luxman!) has survived remarkably well and does actually run. I'm impressed at how well it still looks underneath the boards after 45 years!
Love my L-507uXII, drives both the Spendor D7's & PMC twentyfive.23 with ease. I have a small-medium space but have found that @ 8.45 on the volume dial is plenty loud. The only exception is light classical music, volume needs to be around the 9 mark, but all genres have great presentation. Build quality & having two speaker outputs also makes choosing speakers easy with an A-B comparison...
Well, a Luxman Amp and Spendor D7 can't go wrong.  Are you using the D-05u as your DAC?
Hi Corey, yep great as a DAC as well spining discs. If your musical collection is mainly Redbook standard, highly recommended. It's only if you have a lot of hi-res material that you would need to look @ a dedicated DAC from companies like Chord, PS Audio, & Gieseler Audio
    • By Lovesit
      Item: LUXMAN PD-350 Turntable with LUXMAN TA1 Tonearm made by Micro Seiki and VS 300 Vacuum Stabiliser
      Price: $3800
      Item Condition: Very Good 8/10
      Reason for selling: Regretful Sale, Newborn on the way
      Payment Method: Pickup - Cash
      Doesn't get better than this.... VINTAGE RARE ITEM...
      Still RATED the best LUXMAN by Micro Seiki Turntable ever made. Regretful sale have a newborn on the way.. have owned this turntable for 14 years now, second owner has been refurbished and serviced by AUDIO RESTORATIONS.. All CAPS have been changed, amps calibrated to AUS standards 240 Volts, serviced and tested.
      RARE opportunity last time item like this was advertised for sale was 7 years ago.
      DONT MISS OUT...
    • By Lovesit
      Price: $3800 ONO
      Reason for selling: Regret-full Sale.. Newborn on the way
    • By LyallJ
      Item: Luxman 505u Integrated Amp
      Price: 3000
      Item Condition: Excellent, mint condition
      Reason for selling: Purchased a Devialet 220
      Payment Method: Pickup - Cash, Paypal, COD Only.
      Two things to note:
      The remote is dodgy with its Volume control; over the years I have either changed volume manually or use a DAC/preamp.
      I imported the 505u direct from Japan so it was assembled for the Japanese market and set to 100volt mains electricity. Therefore it comes with a Kashimura TI-20 step-up transformer (photos attached). There has never been any issue playing it here in Adelaide.
      The Luxman has been in daily use since July 2010. It has always worked well and given me great listening pleasure.
      I have attached a User Manual and Brochure.
      The 505u has a phono input with both MM & MC selections.
      The amp can be used as a pre-amp only or power amp only.
      The 505u weighs 21kg. The transformer weighs 4.5kg and its dimensions are 170x135x100mm.
      I will post both items if there is no buyer in Adelaide for pickup - postage costs would have to be checked and agreed to.
      I still have the original box available for transportation.
      Luxman L-505u manual.pdf Luxman L-505u Brochure.pdf
    • By olegau
      Item: Luxman L-509U Integrated Amplifier
      Price: $5900
      Item Condition: as new
      Reason for selling: need money
      The highest-class model of LUXMAN  Integrated Amplifier.
      I am one only owner. Bought new for $8000 in 2012
      The amp has never been repaired, works very well. No issues, can give a week warranty.
      The unit has never been loud more then 9am because I live in a flat and I like my neighbors.
      Continuous effective output: 120W + 120W -8ohm   240W + 240W  4 ohm
      reproduction frequency: PHONO: 20Hz ~ 20,000Hz  0.5dB) LINE: 20Hz ~ 100kHz (+ 0, -3.0dB)
      SN ratio: PHONO (MM): 91dB or more PHONO (MC): 75dB or more LINE: 107dB or more
      Dimension: W 467 x H 179 x D 435 mm
      Weight:  28 kg
      Preferably Pickup
      Also look  another my amp Sansui AU-a607DR amp for sale on this site.
