Selby Thornbury
SOLD: FS: Rel Habitat 1 Powered Sub-woofer White $500 (RRP $2499)  Ex-Display
Item: Rel Habitat 1 Powered Sub-woofer White
Price: $500  (RRP $2499)
Item Condition: Ex-Display. Excellent Working Order. Some minor marks to finish, but no major dents or deep scratches. Broken Grille  - please note - grille can no longer be sourced as a spare part from REL.
Reason for selling: Clearance Stock, Discontinued Model.
Payment Method: Pickup - Cash, Paypal
Extra Info: Can be viewed in person at the Thornbury retail store before purchase.
Manufacturers Sales Pitch:
The Rel Habitat 1 is a powerful slim line sub-woofer of incredible quality.
This sub can be wall mounted or floor mounted & allows wireless communication from the module to the speaker.
It is powered by a massive 150 watt mono-block amplifier and contains 2 x 6.5" drivers and 1 x 10" driver.
Specs and Features:
TYPE: (2) Front-firing active drivers, (1) rear-firing passive
ACTIVE DRIVER SIZE & MATERIAL: (2) 6.5 in., 165mm long-throw, steel chassis
PASSIVE RADIATOR SIZE & MATERIAL: 10 in., 250mm steel chassis, black cone
LOW FREQUENCY EXTENSION: -6dB at 30 Hz
INPUT CONNECTORS: High Level Neutrik Speakon, Low Level Single RCA, LFE Single RCA
OUTPUT CONNECTORS: N/A
POWER OUTPUT: 150 watts (RMS)
AMPLIFIER TYPE: Class D
WIRELESS CAPABILITY:Longbow, Zero Compression, Individual Discrete D/A and A/D Encoders
PROTECTION SYSTEM: Yes - Fully Electronic SET Safe, DC Fault & Output Short
MAINS INPUT VOLTAGE: 100-240V Operation
FUSES: 1.6A for 230V Operation, 3.16A doe 120V Operation
DIMENSIONS (W X H X D): 25 x 16 x 4.5 in. (635 x 406 x 114 mm)
NET WEIGHT: 50 lbs. (23kg)
FINISH: White Lacquer, 8 coats
SUPPLIED ACCESSORIES: Longbow Transmitter, IEC Mains Lead, Neutrik Speakon Cable For Use With Longbow Transmitter and Users Manual.
Condition:
New Open Box Ex Display Unit.
This unit was used for display purposes in a retail environment, minor scratches are present, but no major dents or deep scratches, but has a broken grille.
Excellent working condition.
Includes Full Manufacturers Warranty
Feel free to ask for more information.
Edited by Selby Thornbury
    • By vik74au
      Item: REL Acoustics R-505 Subwoofer
      Price: $1,100
      Item Condition: Excellent, perfect working condition
      Reason for selling: Upgraded
      Excellent working condition, albeit some fine scratches on the piano lacquer finish, only visible under direct close light, see pics. Sole owner since new, carefully maintained in a smoke-free, no-children and pets home throughout its life.   Heavy duty long throw 12" Drive unit, 500 watts Class D See photo for more specs   Original box and packing as in photo, for pick up only as this sub is a heavy 26kg.   Accessories included as in photo: - Power Cord - Neutrik Speakon Interconnect (High Level) - Spikes - User Manual   NOT Included: I also have a set (of 4) of IsoAcoustics Gaia III isolation feet and carpet discs that I have been using on this REL for sale separately if buyer is interested, see last pic of it (without carpet discs) on the REL.
    • By olegau
      Item: HiFi stereo system
      Price: 1200
      Item Condition: very good
      Reason for selling: too many stereo systems
      Carefully selected Hi-Fi stereo system. All in good condition and working order.
      Separated sale:
      1. ROTEL RA-980BX Integrated Amplifier $390
      The amp was checked and serviced recently.
      It has OP amp sockets, DIYer could change the OP amps to get different sound. Open the the top cover and then change the OP-Amp you like.
      There are three pairs of Ops: original AD712 (vintage sift sound, JRC4558 (modern  more clean and detailed sound) and LM4562 (bit more detaied). Currently installed LM4562. Many other OP-Amp suits for this amp..
      Dimensions: 440 x 121 x 347mm
      Weight: 10.1kg
      Example:
      2. Speakers: Ascension Woodfox Ribbon 822SRTL Bookshelf Speakers. $890
      Dimentions: 500 H, 270mm W and 315mm Depth. Weight is approximately 18kg each. High quality woofer using an Papyrus cone, ribbon tweeter, Rose Mahogany Veneer.
      Two years old.
      Power 120W
      8 ohms
      Sensitivity 91db
      3.  Sold.  Subwoofer: Infinity Primus PS-8 $170
      See spec attached
    • By powerinnumbers
      Item: VAF LFE-o7
      Price: $600
      Item Condition: Good
      Payment Method: Pickup - Cash, Paypal + 3%, Credit Cards + 1.8%
      Extra Info: The sale does not include GST as it wasn't purchased part of business.
      Will not ship , must pickup in person or paid in advance and arranged own transport.
      Happy to demonstrate
      Would suit somebody with an existing LFE-07 to match . I don't know too much about subs to explain much, since this is the only one I ever owned.
    • By Lucki
      Item: Canton SUB 10.2 10 Inch Active Sub-woofer
      Price: $499
      Reason for selling: Need to downgrade to a compact sub
      Payment Method: Pickup - Cash, Paypal Only
      Extra Info: Sub is in almost new condition with no blemishes or marks whatsoever. Also have the original box if required.
      I have for sale a sparingly used matte white Canton SUB 10.2 10" active sub-woofer rated at 200 watts RMS & upto 300 watts peak. The subwoofer is ported so would be ideal for movies but it is great for music also, as it features acoustic room compensation to make the bass sound wider or narrower.
      I purchased this earlier in the year and have since enjoyed the LFE mixes of a great few movies, and some good music scores too. It goes so deep that you feel the floor and the windows vibrate, yet it sounds clean and deep. Unfortunately I need to sell as I don't have the space anymore for a large sub-woofer in my setup. I also have placement limitations in my living room. The dimensions of this unit are 320W x 456D x 432H and weighs 15.3 KGS.
      More info and reviews below:
      https://www.canton.de/en/archive/sub-10.2?number=
      https://www.amazon.co.uk/Canton-03303-10-2-Subwoofer-Black/dp/B00AZUS16U
      https://www.digitalcinema.com.au/canton-sub-10-2-10-active-subwoofer.html
    • By olegau
      Item: Infinity Primus PS-8 Subwoofer
      Price: 190
      Item Condition: good working order
      Reason for selling: do not need
       Good sound and good condition.
      Infinity PS-8 Subwoofer
      Features and Specs
      Enclosure Bass Reflex
      Woofer Size (inches) 8
      Woofer Composition M.M.D.
      Width 10.6 in
      Depth 16.8 in
      Height 17.5 in
      Weight 33.07 lbs
      Firing Direction Front
      Preamp-Level Inputs 3
      Speaker-Level Inputs Yes
      Low-Pass Crossover Freq 50-150 Hz
      High-Pass Crossover Freq None
      Phase Switch Yes
      Amplifier Output (watts) 100
      Frequency Response 35-150 Hz
