systemawarrior14
Capacitor advice.
Hi fellow SNA members,
I would like some clarification on the value of a capacitor for replacement on my Jamo D570.
It is the tweeter cap at the top labelled 4.7k. I would like to replace them but am not sure of their value in uf. Any advice is appreciated.
Best regards
Darren.
Guest Muon N'
Clay's suggestion of Jantzen Superior is a good, a musical cap in the affordable price range :thumb:
2 hours ago, Gieseler Audio said:
2 hours ago, mwhouston said:
4.7uf.
Something to ponder.
I have used Auricap before and really liked their neutrality and clean signal. What are the characteristics of a Jantzen cap?
Guest Muon N'
@systemawarrior14 sorry, this is something you might also need to know, film caps normally have an inner foil end and an outer foil end, so installed one way they will reject interference (noise) more than if installed the other way.
Here is someone testing for outer foil ends with a few different caps using an oscilloscope.
http://www.jimmyauw.com/2010/04/24/observing-inner-and-outer-foil-of-some-popular-capacitors/
This looks like a cheap Jaycar cap possibly a metallised polyester or polyprop. The safesy bet is to measure it.A second order network on the tweeter is observable from the photo of the crossover . 4.7 uF is the  most likely value together with the glued  air core coil will be the two components  of the 2nd order network ,no dropping resistor to the tweeter is evident though.
The choice of cap should be undertaken to compliment the tweeters sonic signature . ie bright thin sounding tweeters eg some metal domes or hard domes should go with dark sounding cap like Mundorf supreme or Audience auricap, from my own experience over the years.
Tweeters such as soft domes can handle a little more transparency from associated cap such as Jantzen Z silver (could border on bright)or copper.
Agree with everybody's comments here.
Even a basic solen mkp type will outperform your current cap.
Also look at Intertechnik (Audyne caps)
and Clarity Caps Csa high voltage series or film and foils ( metalised caps are not  usually .directional) The Oblligatos premium are excellent for the money too. Audience Auricaps are smooth sounding but expensive for what you get. Dont forget that the capacitors we're talking about here may be more costly than the installed tweeter!
Good luck.
Thanks Cello sweet. I had some old Solen .10 uf from an old Maggie 1.6 crossover and bypassed the tweeter caps on the Jamo . Well I can tell you the difference was immediately noticeable and for the better. This is what has convinced me to replace the entire cap.
Thanks for your advice.
Best regards
Darren.
On 17/02/2019 at 12:38 PM, Muon N' said:
If strapped for cash, these are a discontinued cap from Obligatto also in that test.
Xender Discord Omegle
http://shop.diyhifisupply.com/product/4-7uf-630v-obbligato-euro-film-cap/
But it all depends on budget and what sound signature you feel might work well with the Jamos and considering you system sound as a whole..
Edited by jojo320
Hi Jojo,
I ordered some of the Obbligato on Monday. Thought it was worth a try at that price. I have a Yamaha AS1100 amp and Micromega mydac with the Jamo's. The overall sound is quite organic and the tonality of the Jamo's is very nice. There is a chance that the Obbligatos could overly ripen the sound, but if they do I'll just get some Auricaps.
Guest Muon N'
I find Auri caps sound a tad synthetic to me, those black case Obligatto caps to my ears sound more real.
See how it goes, let them run in for 50+ hours, I think you will like them. :)
Edited by Muon N'
Of course they're synthetic, you think they flamin grow on trees?  🤣
Guest Muon N'
Bob, I said 'sound' as in subjectively sound that way, I was not referring to construction.
But if intentionally misconstruing things gets you a giggle, that's cool ;)
Edited by Muon N'
Oops, typo
    • By lordvader82
      Item: 4x 1000uF 25V Blackgate NX caps
      Price: $230AUD each (postage free).  $850 for the lot. Will entertain reasonable offers.
      Item Condition: Used - test strongly
      Payment Method: Paypal - will cover postage
      I have 4 1000uF Blackgate NX (25V) capacitors salvaged from unused DIY projects.
      They all have an ESR of < 0.016ohm, and have tested to the following values:
      1067uF 1111uF 1081uF 1038uF
      Also selling on another platform - so whoever claims first wins.
      These are pricey, but I've trawled the internet, and these are available on ebay for $340USD (about $500!).
      So I guess they're a bargain?
    • By lordvader82
      Price: $300 $250AUD each (postage free). $1000 $900 for the lot. Will entertain reasonable offers.
    • By Somethingclever
      Item: Pair of Duelund 3.3uf 630 vDc CAST Pure Copper Foil
      Price:  800 ono ( Happy to post at buyers expense )
      Item Condition: Very Good
      Reason for selling: Change
      Extra Info: To quote Benjet who sold something similar..."If you know what these are then you don’t need me telling you all about them. If you don’t know them you probably don’t need them."
      Currently in use, will demount them when sold.
      These top of the line Duelunds were worth about 600 to 700 each when new as far as I can tell.
    • Guest scumbag
      By Guest scumbag
      Item: WITHDRAWN  X2 Audience Auricap 4.7uf 400v NEW
      Price:  - prefer local pickup but could post at cost (Officeworks is very cheap ATM).
      Item Condition: Perfect - never used.
      Reason for selling: I have a lot of extra speaker stuff that I picked up to experiment with. Need to get rid of some of it.
      Payment Method: Pickup - Cash, Paypal, COD Only Add 3% if not paying as a friend - if you don't pay as a friend and don't add 3% then I will refund the payment - sorry a bit sick of people ignoring that request.
      Some comments / reviews from the interwebs:
      "Sound: I find these capacitors to have a pleasantly smooth and clear presentation that is slightly forward if directly compared to bright-ish capacitors like the Jantzen Silver Z-Cap or Silver Gold Z-Cap. The Auricap retrieve enough amibent information that helps to make an orchestra properly placed in a concert hall (recording permitting) and project the image more in the width than in the depth. Overall performance is very satisfactory and has something correct / complete about it. I have added them to my favourites list."
      "nice detail, speed, musicality, and their sound gives an extra bloom to the sound, which will make them fit well into somewhat cooler-sounding components"
      "The balance is perfect, the sound is perfectly neutral, uncoloured. Not even an hint of coloration"
      "smoother midrange but a neutral balance through the whole audio frequency spectrum…………..You can say that the Auricap does nothing wrong, but look elsewhere if you are looking for a cap to colour the tonal balance of your system."
      So I would describe them as neutral veering towards warm. Good detail and image depth. Well made and suitable for use in electronic components and crossovers.
      TNT review
    • By Cafad
      Item: Jantzen Metallized Polypropylene Capacitors, see below for values.
      Price: Varies with type and value.
      Item Condition: I guess they count as new, still in their individual plastic bags from Speakerbug.
      Reason for selling:  Bought to upgrade some speaker crossovers a few years ago but it did not happen, I upgraded the cabinets instead.
      Superior Z-Caps, 800VDC   1.0uF   $10 each (2)
                                                    3.3uF   $12  each (1 only)
                                                    4.7uF   $15  each (2)
      Standard Z-Caps, 400VDC  6.8uF   $3 each (3)
                                                     15uF   $6  each (2)
      Cross Caps, 400VDC             47uF  $10 each (4)
