pwstereo
3RRR reception in East Gippsland?
Item: Receiving 3RRR fm station in East Gippsland
Price:
Item Condition:
Reason for selling:
 Why is a new post in this forum formatted as a For Sale ad?
I love my aussie, indie, and alternate music, I love 3RRR (and 3PBS to a lesser extent), and have recently moved from Melbourne to East Gippsland.
I made a loop antenna tuned to 102.7 MHz and can get a barely discernable output from my Denon AV receiver with it indoors.
Outdoors I can tell what song is playing with the loop held up high on my back (West facing) porch.
The loop is not weatherproof, it was just quickly built as a test.
I'm preparing to build a 6 element Yagi-Uda antenna tuned to 102.7 MHz for erection on the same bargeboard mount as my UHF TV antenna.
Before I do that, I'm wondering if anyone else in the Bairnsdale area has had any success in getting a quality output from the lower powered
Melbourne FM stations? If so, what antenna arrangements were used?
Thanks.
Moderator
I certainly don't get reception in the Ovens Valley but just stream it. Have you good enough internet for that option?
Yes, can your Denon AV receiver get Internet radio?
If you do have "good enough internet for that option" then maybe buy a Sangean WFT3 to plug into your Denon?
Yes, I can stream it, but I’d rather get it as an fm transmission if I can.
a good Yagi essential and perhaps a better tuner?
www.fmtunerinfo.com
2 hours ago, Ian McP said:
Thanks Ian, I'd visited that site and checked the info there. The 6 element Yagi-Uda antenna I'm building should give me around 10 db gain.
From what I can see, the FM tuner in my Denon AV receiver has fairly good sensitivity, I do also have a Rotel tuner that I could try.
Some of the best performing tuners were made before the accountants got to company's budgets and can be had for not much moolah on ebay if you're quick. Back in the late 70's through to the early 80's models.
My late father had amazing reception in Mt Eliza with home built antennas and a just a mid range Rotel RT624.
One of my fave magazines Audio had an equipment directory published in each October issue. Here you could check many tuners' sensitivities and other specs, a handy guide. You can find many archived here:
https://www.americanradiohistory.com/Audio-Magazine.htm
Hifi Engine is an excellent source for user and service manuals
https://www.hifiengine.com/
I've been a die hard PBS and RRR listener since the late 70's! One of my fave shows just finished a few hours ago today.
Black Wax on PBS, prefer listening to it live however on demand handy when you miss an episode
https://www.pbsfm.org.au/blackwax
regards Ian
The Rotel tuner I have is the RT-850A and it seems to have very good sensitivity, it's from 1990 I think.
RRR and PBS are very good, I've learnt of a lot of new music from listening over the years.
Price:
Item Condition:
Reason for selling:
Thanks.
Wow, that's going to be a challenge.
I struggle to get full quieting at Gembrook when the weather isn't favourable.
However, if your loop gets some reception, then the tuned Yagi might do the job. You could also try adding a good quality VHF masthead amp if the Yagi doesn't quite get you there.
Make sure the antenna impedance matches the tuners antenna input impedance
I feel for you.  I spent a lot of weekends up at Stawell last year sorting out Mum & Dad's place after they went into care, and really missed my PBS & RRR weekend listening.  JJ and SBS Chill via their set-top box had to be my substitute.
Your RT-850A does have excellent sensitivity specs.  I had an RX-850 Receiver in my garage for a while, and even it was quite good.  Only thing it lacks is a "Blend" (sometimes labelled "Hi-blend" or "NR") button which can be really useful for maintaining listenable stereo in fringe reception areas.  If you do consider another tuner, make sure it has that facility and matches or betters the sensitivity specs of your Rotel.
Keep us posted on your progress.
    • By JohnK1
      Hi all.
      I've installed a new antenna Jaycar LT3182 91 element job, after doing a bit of research on the net. On our main TV (Sony) the signal quality is 100%, while signal strength is between 90 - 100% for all channels. Another TV (Palsonic) installed in the bedroom however, drops out on some channels, picture breakup, loss of signal. I've replaced the cable to it which made no difference. Yet another TV (Sony) in the office is OK.
      I find it hard to believe the signal isn't strong enough, in fact I've read that too strong a signal may result in the same symptoms. Any advice greatly appreciated!
    • By zandahar
      Long time lurker but just got asked a question and thought no better place to post it. Friend of mine is having a huge number of double story units being built right behind them which appears to have just completely toasted any of the tv signal. The timing matches perfectly with the top level going up and the bricks and roof being done. He has an external antenna relatively new and been working fine and has tried pulling a new run of cable but no difference. Even tried a powered booster suposedly and no dice. Thought it may have been the TV originally so bought a new one and same deal.
      If you can rule everything else out and looks to be the new building impacting the signal is there anything that can be done ? By that I mean approaching someone and logging a complaint and who knows maybe make the developer pay to put up a mast for the antenna ? Even without pursuing the jumping up and down route any other suggestions ? Relocating the antenna is a possibility but by the description of the layout and position of the two properties its unlikely to help.
    • By marchino61
      I have been using to DAB in Perth for more than 4 years. I live in East Victoria Park.
      I most often listen to three ABC stations: News Radio, Radio National and 720 Perth. I have two receivers, one upstairs in my bedroom and the other downstairs.
      Until the last 3 or 4 week, I had flawless reception. Now I get regular drop outs on all three stations, sometimes lasting more than 1 minute, on both radios.
      Is anyone aware of any issue which would have caused these problems to flare up in the last few weeks? Is anyone else having the same problem?
    • By et tu Brute
      Good points MLXXX, a few people stopped getting excited about this forum due to the stupidity of others. Forum moderators are responsible for this mainly, I've also seen much advice and no field experience coming from said person. I don't like being told "remember" hey I do this job everyday. I have some great friends who are former broadcast engineers. I like to study different products to come up with viable solutions to simple issues. But I know I can be arrogant hence my comment about my experience the ones on here that seem to know the most only use it when necessary and with discernment, rather than pretending to be an authority.
    • By et tu Brute
      Our reception for all channels goes from okay one moment to zilch for a day or so and revert to okay. This has been going on for the last 3 weeks. Left voice mail for our antennae repairer last week and still waiting for a call back. We are within 1.5km line of sight from the Bruxner Park Transmission towers, but too far away (26km?) From Mt. Moobil to the South of Coffs. Some days only the ABC and SBS channels are being received and tonight we are only getting the ABC1 channel, somewhat pixelated. Coincidently perhaps, but we have notice a drop in performance from Bruxner Park after each upgrade, particularly since the introduction of the shopping channels & the racing channel (68). I wouldn't have thought these mattered considering our close proximity to the transmission tower. Prior to the shutdown of the analogue services and the first major overhaul, our reception was first class on all channels.
      If anyone else locally receiving their signals from Bruxner Park, I would be interested in hearing from you regarding the quality of service you are receiving.
