I am considering the purchase of a new DAC, my key requirements being:
  • It supports MQA
  • It has a preamplifier built in with Home Theatre (HT) Bypass (supporting balanced XLR inputs from an AV preprocessor)
  • The sound quality should be a substantial upgrade over my Marantz AV8802A AV preprocessor
  • Not essential, but it ideally should have network streaming built in, with the primary objective to stream Tidal
I’m finding it surprisingly difficult to find units that tick all the above boxes. Specifically very few DACs have HT Bypass. I’d like to connect the DAC directly to my amplifier to bypass my AV system (but have the AV system connected to the same amplifier via HT Bypass).
I could connect the DAC to the Marantz 8802A in pure direct mode but I understand that the Marantz will still do an A to D and D to A conversion for the volume control, which would restrict the performance of the DAC. Correct me if I’m wrong here.
So the two candidates I’ve seen so far are:
  • Simaudio Moon 890
  • Mytek Manhattan II
Has anyone had experience with the above DAC/preamps? Any other DACs to consider? Really at the start of my investigations so look forward to hearing any thoughts or recommendations based on the above mentioned intentions.
My gear is B&W 804D3, Simaudio Moon 860A, Marantz AV8802A, Rel S/3 SHO subwoofer connected via high level inputs, streaming via Audirvana via UPnP or the Tidal app on iOS.
Thanks in advance :)
Edited by Ed Sky
clarified requirements
I have the upgraded Moon Neo Ace which now supports MQA and Roon Ready. Love it and the 890 can only be better. If funds permit down the track I’ll go 890 and separate power amp.
I have the 7702mkII in my ht room which is supposedly superior sonically to the 8802. The 7702 is WAY meatier and warmer sounding than the Moon, powered by an Electra amp which is quite neutral, it is definitely the Marantz creating the sound signature. I never use my ht system for 2 ch
Edited by blybo
48 minutes ago, Sime V2 said:
Hmmm, Brooklyn’s ………………………make sure you hear one first.
Of course...... can’t beat a home demo if possible.
Mytek are pretty good value imo, amazing how they can pack so many features in that little box!
@blybo so interesting to read your feedback around Marantz vs Moon sound. Glad you are enjoying your Moon Neo Ace, which is an encouraging endorsement for the 890. It is a pricey unit and I'm treading very cautiously because of this.
12 hours ago, Conch said:
Hey Ed,  you might want to keep an eye out for the soon to be released Mytek Brooklyn Bridge.
https://mytekdigital.com/hifi/products/brooklyn-bridge/
I think it has all the features your after?
Liam
@Conch unfortunately the Brooklyn Bridge doesn't support Home Theatre Bypass (well at least not with balanced input) which would be an absolute requirement for me so that I can run this in parallel with my AV setup. I did have a look at the link you provided and it does look like it'll be a hot product.
11 hours ago, Snoopy8 said:
2 potential candidates are the NAD M12 with BluOS module and PS Audio DS with Bridge option...
@Snoopy8 I hadn't seen the NAD M12 in my research yet... it looks like a very good candidate! I'll investigate further. The price is also a bit friendlier on the wallet :)
Have you had any experience with this NAM M12 sound quality wise? I'd be curious how it competes with the PS Audio DS, Mytek Manhattan II, Moon 890 etc. Definitely I'll check out reviews.
With regard to the PS Audio DS, I wish this was an option but from what I see it doesn't have Home Theatre Bypass.
Compared with my Gieseler Gross DAC, the PSA DS was disappointing given how many here rave about it.  At its price point, and with all those fantastic reviews, I was perhaps expecting too much.
No experience with the Mytek nor Moon,  both rated well.  I did research the Mytek Brooklyn at its peak hype, with prices stubbornly at or near RRP!  :sad:
Have not heard the M12, was beyond budget, also into valve preamp.  However, I can provide some thoughts based on my NAD T758V3 AVR.  For 2 channel music, it loses out to my dedicated setup.  But if I only had the T758V3, I could live with it.  Dirac Live (and get full license) makes a big difference.  BluOS was a pleasant surprise, easy to setup and use and recommended.  The M12 will have a better DAC chip and much much better analog circuitry, output stages, inputs.
Not having a HT bypass should not be a show stopper; just note the volume setting when using it with HT.
Perhaps I am missing something, but without HT bypass (and corresponding XLR analog inputs) how would I connect the AV system through to my amplifier in parallel? From what I can see the PSA DS doesn't have analogue XLR inputs. I would see the chain of components as follows: AV Pre/pro --> New DAC Prepamp --> Amplifier --> Speakers but don't think the PSA DS would allow me to do so. Unless there is another way to connect this up.
Thanks @Snoopy8 for your description of the NAD in comparison to the other DACS.
I dunno really how HT Bypass works, but in the manual for my Brooklyn plus it has a toggle on/of for theater bypass.
The bridge is identical to the plus, just with streaming capabilities.
My comment applies to HT bypass in general. It is easy to do a workaround without HT bypass.
I did not know about your XLR analog input requirements, so will leave it to you..
HT bypass is used to allow the concurrent use of home theatre and dedicated music stereo system at the same time. The rationale for this is that many people don't have the space / budget for separate speakers and amplifiers for home theatre versus music use. With HT bypass your home theatre AV unit send the pre output of the front stereo speaker to the input of a stereo preamplifier. With HT bypass activated the preamplifier sends the signal directly to the stereo amplifier without any volume control adjustment. So effectively when watching home theatre the preamplifier is invisible, just feeding the signal to your amplifier. But when playing music, the preamplifier is used solely to drive the amplifier and ignores the AV components.
The rationale for all of this is that a stereo preamplifier (with DAC) should provide much better performance for stereo than an AV processor.
So to clarify, a setup like this can run in two modes:
Home Theatre: AV Processor --> Preamplifier (via HT bypass) --> Amplifier --> Speakers
Stereo: DAC --> Preamplifier --> Amplifier --> Speakers
(In my case I'm looking for a combination DAC / Preamplifier to save space and cost.)
@Sime V2 have you tried to plug your DACs directly to the amplifier, bypassing your Marantz 8805 (assuming they have volume control)? In theory the Marantz is doing an analogue to digital and digital to analogue conversion of your DAC even in pure direct mode, so may be limiting the performance of your DAC.
With regard to the Brooklyn, thanks for checking out the manual to see that it has a toggle switch for theatre bypass. This would probably do the trick, but I don't think it has balanced XLR inputs so it would compromise the quality of the AV input from the Marantz a bit.
I think you have asked me this before but I forgot to reply.
I need to use the 8805 as a pre because it handles bass management, my room has a rather large bass bump when the 805’s run full range, so running my 805’s at an 80hz cut off solves the problem. And I prefer sub bass over the typical sound of full range speakers bass anyway.
In regards to what the 8805 does to the analog sound once it goes into it is not important to me, why you ask?
I regard any dac as a source, as we all do, so the better the source, the better the output, regardless of whether it’s converted in the 8805 or not. I’ve gone from a 2qute-Qutest-Qutest/M Scaler and a Brooklyn plus, all 4 have had vastly different results, and for the better as the tech improved.
But you are correct, sure I might not be getting the full benefits of my 2 DAC’s, but I’m getting a benefit in my current configuration. One reason I’ve kept the Brooklyn is because it’s a great way to show the benefits of the m Scaler, if you A/B/C it (Brooklyn direct from source/Brooklyn in bypass mode through the Scaler/Brooklyn being upsampled to 384 by the Scaler) there’s a massive difference being heard, and it more obvious through it than the Qutest, and easier to quickly AB also, but the Scaler/Qutest at 1m taps is king.
But the point is, even if the 8805 is doing its own conversion, the difference at the source level is noticeable enough to make the system as a full unit, substantially better.
The M-Scaler in combination with the 8805, both being rather new in the system, has completely changed the way my system sounds. So much so I’ve done more long periods of music listening lately than I ever have before.
So it’s not simply the case of getting the best performance from any dac, but the dac getting better performance for the system as a whole 😉
  • Like 3
I know the question was for Sime, but I did run my DAC directly to my active speakers for many months.  Adding a hybrid tube preamp changed a detailed, clean but clinical sound to more warmth, more bass without losing the detail.  I now have a pure tube preamp and doing tube rolling.
Sure, I've just updated the post to clarify the XLR requirements as I didn't specify this initially. :)
Hmmm, now you got me thinking... tube preamp, you're not the first to recommend. Baby steps I guess
I understand now. I just assumed you were running your Rel's with the high level input, but if you need bass management for music then the Marantz will do that well. And it's great to know that plugging in a good DAC into the Marantz, not even running in direct mode, can improve the sound quality so substantially... gives me food for thought.
Yesterday evening I was experimenting with Audirvana's up-sampling capabilities and I was pleasantly surprised at the SQ improvements. (I was just up-sampling from 16/44 to 24/88 as my wifi network has dropouts if I go much higher.)
@Ed Sky just to add, I’m not using direct as you mentioned, though I do at times depending on the album, and I’m not using Audessey either for music(2ch) I use eq mode and taylor the sound to my liking.
Yes, baby steps is the way to go. You can add a tube buffer later.
Adding this narrows the choices, will rule out any DAC which has a powerful output stage that can act as a pseudo preamp.
Tell me more. Are you saying that you can add tubes after a solid state preamplifier to get the benefits?
Would I be able to use these DACs though as I wouldn't have a way to run them to my amplifier with the home theatre equipment working as well?
I haven't played around with EQ much. I'll give it a go. I recall in a previous thread you said you copied the EQ settings from Audessey. I'll give this a go when I have time to dedicated time tweak.
I am no expert, but I believe you can add it before or after.
That is a different question. Your challenge is a one box solution to handle DAC duties and switch to XLR for HT, plus streaming.  A two box solution, say DAC plus streaming, and a preamp with HT bypass will have many more choices, including used ones.
I wouldn't get all fussed over topology. A good pre is a good pre.
The Tube pre I had previous to my Neo Ace was a more expensive unit, and just about everyone would say an extremeely capable tube pre in an Elektra. However, I find very little difference after switching to the Neo Ace, but a whole magnitude of convenience, which was the reasoning behind my purchase anyway.
  • Like 3
Valid point for sure. I guess a two-box solution will open up many more options. Though my biggest concern is lack of space at the moment. I barely have space for an additional component. I guess what also appeals to me with an all in one solution is being able to control both volume and the music playing (and possibly power) from one remote, e.g. mobile phone.
With the lack of space, a 2 box solution is not an option then. And with more emphasis on the phone app and presumably streaming?  Not sure how many phone apps can control power (how does phone communicate with box which is not powered on?) but all should have volume control.  On the NAD, volume control via volume dial, remote and BluOS app, which is nicely done.
Suggest do further research on your 3 candidates and organise auditions for them.  You may prefer the sound of one but another may disappoint despite its good reviews.  Have fun, and do let us know what you end up with...
  • Thanks 1
  • 2 weeks later...
I just rang QualiFi (the Australian Marantz distributors) to ask them if any A to D or D to A conversion takes place if the Marantz AV8802a is placed in pure direct mode playing from the XLR analog inputs. They looked at the schematic diagram of the Marantz and concluded that with pure direct a purely analog path is followed, there is no digital conversion (and none required for volume control).
This perhaps places a different slant on things as perhaps I could bypass the requirement for a stereo preamplifier and just connect a DAC to the Marantz. Any thoughts?
That definitely can work. Note that a stereo preamp will likely outperform a prepro, regardless of whether there is direct mode. Direct mode, in theory, should not colour the sound, but it does a little. You have to decide whether the prepro can do the job by auditioning.
  • 11 months later...
Bumping this thread..:
what new options are out there as a dac/ preamp to work as a Roon endpoint?
I’m looking at options for a streaming system that runs RAAT to plug into a HT bypass scenario.
The nad c658 looks interesting, as does the NAD m12 (though this looks a little long in the tooth).
an AURALiC Vega looks good as well but doesn’t have a dedicated sub out. What else ticks this bill today?
https://kb.roonlabs.com/Partner_Devices_Matrix
If RAAT is mandatory, then the C658 will not make short list. And M12 does not do MQA decoding with RAAT.
Getting something with RAAT, MQA and a dedicated sub out makes it a challenge. Looking through the list, difficult to identify any, but I am not familiar with many...
  • 8 months later...
  • 3 weeks later...
Not sure how much interest there might still be in this thread, but I recently acquired a Benchmark DAC3 HGC from a friend, which combines a dac, preamp and headphone amp. Highly versatile with both USB and coaxial digital inputs, and XLR / RCA outs. I also has HT bypass and everything is easily controlled via a user friendly remote.
Highly recommended.
    • By atty
      Item Condition: Brand new Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: BONDI State: NSW Payment Method: Paypal, EFT, Cash on Pickup Reason for selling: Left over stock Hi all,    I'm selling a brand new Bluesound Node 2i in black. Unit is in factory sealed box. Unit comes with 2 years warranty backed by Convoy International Australia.    For clarification, I run speaker building workshops in Sydney and as part of the business I sell HiFi equipment - this is the last unit I have hence the discount.    Unit specifications and info can be found here.
    • By Tassie Devil
      Item Condition: Unmarked Shipping Options: Shipping is included in price. Suburb or Town: Dilston State: TAS Payment Method: Bank Transfer Reason for selling: Surplus to requirements This ia a small quality DAC/headamp as reviewed here:  https://www.listeningpost.co.nz/products/archives-discontinued/icon-dac-nuforce-force-__I.62364__C.50400__N.27756
      Key Features
      Asynchronous low-jitter USB interface Supports Windows 7, 8, Mac OSX, Android 4.1.1* High-precision 32-bit DAC Powerful 8V output headphone amplifier 6.3mm headphone output jack 3.5mm analog input and RCA analog output Audiophile TOCOS volume pot Multiple stage filtering and regulated up-converted 24V rail power supply High-quality aluminum chassis
      PLEASE READ
    • By MusicaMachina
      Item Condition: Excellent Shipping Options: Shipping is included in price. Suburb or Town: MELBOURNE State: VIC Payment Method: Paypal Reason for selling: NLR Further information:
      Shipping (Australia metro areas) and insurance allowance is included in price.
      Paypal fees at buyer's cost
      Excellent Condition
      Silver Aluminium Case
      I purchased this unit as new in July 2019 from Shenzhen Audio. It will be shipped will all original original packaging (box in box). Includes Unit itself, AU mains power cord, remote control, USB cable, 2 x wifi antenna and User Manual (English and Chinese language).
      The Matrix Element X can drive a set of headphones, active speakers or an amp and passive  speakers. It does DLNA streaming, MQA and functions as a Roon Endpoint or Airplay renderer. I used it in a second system mainly with Roon over WIFI network and Spotify via Airplay. I have tried the coax, optical  and usb inputs and they all work fine. I haven't tried the IIS as I don't have anything compatible.
      ·         DAC ES9038PRO/ES9311/Femtosecond Clock
      ·         USB InterfaceXU216 XMOS processor,
      ·         Full Balanced Headphone Amplifier
      ·         Pre-amplifier - built-in analog pre-amplifier with +10dB analog gain
      ·         Firmware updated to current version B61601
      Review (there are a couple of alternative reviews on Matrix website)
      Matrix Audio element.X streaming MQA DAC, HP amp and pre-amp – YouTube
      Matrix Website:  https://matrix-digi.com/en/products/321.html
      Matrix Audio MA Remote App iphone/ipad https://apps.apple.com/au/app/ma-remote/id1475439058
      Specifications
      Digital Input
      COAXIAL & OPTICAL
      PCM 16-24Bit /44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz
      DSD 2.8MHz (DoP)
      IIS LVDS
      PCM 16-32Bit /44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, 384kHz, 705.6kHz, 768kHz
      DSD 2.8MHz, 5.6MHz, 11.2MHz (DoP)
      DSD 2.8MHz, 5.6 MHz, 11.2 MHz, 22.4MHz, 45MHz (Native)
      USB Audio
      PCM 16-24Bit /44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, 384kHz, 705.6kHz, 768kHz
      DSD 2.8MHz, 5.6MHz, 11.2MHz, 22.4MHz (Native)
      Network
      LAN: 10BASE-T/100BASE-TX
      WIFI: 2.4GHz/5GHz, IEEE 802.11 a/b/g/n/ac standard
      Line Output
      XLR
      SNR: > -131dB
      THD+N: <0.00012%@1k, <0.00025%@20Hz-20kHz
      Frequency Response: 20Hz-20kHz ±0.05 -3dB@120kHz
      Crosstalk : >-145dB
      XLR Amplitude: 4.5VRMS@0dB ,15.8VRMS@+10dB
      RCA
      SNR: > -124dB
      Frequency Response: 20Hz-20kHz ±0.05 -3dB@105kHz
      Channel Crosstalk : >-137db
      RCA Amplitude: 2.3VRMS@0dB , 8VRMS@+10dB
      Headphone Output
      XLR4 and Dual XLR3
      SNR: >-117dB
      THD+N: <0.00055%@20Hz-20kHz 1VRMS
      Frequency Response: 20Hz-20kHz ±0.05 -3dB@50kHz
      Output Impedance: <1.5Ω
      Output Power: 1700mw@33Ω, 1180mw@300Ω, 650mw@600Ω, 1%THD
      Gain: +18dB@Low Gain, +28dB@High Gain
      TRS 6.35mm
      SNR: >-112dB
      Frequency Response: 20Hz-20kHz ±0.1 -3dB@50kHz
      Output Power: 1150mW@33Ω, 308mW@300Ω, 152mW@600Ω, 1%THD
      MA.PLAYER
      Format Supported
      MP3 , WMA , WAV , AIF, AIFC, AIFF, AAC, FLAC, OGG, APE, ALAC, M4A, DSF, DFF
      PCM Sampling rate
      PCM 16/24/32Bit 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, 384kHz, 705.6kHz, 768kHz
      DSD Sampling rate
      USB Storage Device
      element X can use the devices which conform to USB mass storage standards and supports FAT, FAT32, exFAT, and NTFS file formats, but is not guaranteed to be compatible with all storage devices or memory cards.
      Power
      Power Voltage
      230V position is fit for AC220V-240V (on base of unit) 50/60Hz 115V position is fit for AC100V-120V 50/60Hz
      Stand-by Power Consumption<1W
      Sleep Power Consumption  <4W
      Dimensions
      340×281×60mm
      (L×W×H, including the protruding part)
      Weight
      4.2kg
      Accessories:
      RM3 remote control
      Power cable
      USB cable
      WiFi antenna x2
    • By Snoopy8
      Been going through the Gieseler DAC threads to dig up owners’ reviews & impressions over the past 2 few years.  Together, they provided an impressive picture of how well Clay has made his DACs and has lead me to consider  purchase the upcoming Groß DAC with balanced outputs.
      Kompakt Reviews & Impressions
      lenticularis 23 Sep 20, 29 Nov 20 compared with Klein III
      herbs 24 Sep 20
      franky995 24 Sep 20 compared with Gross
      naggots 25 Sep 20
      pete_mac 20 Oct 20
      John0001 10 Nov 20
      ray4410 24 Nov 20 compared with Denafrips Ares II
      Fein II Reviews & Impressions
      helland 28 Mar 19
      RussB 14 Apr 19 compared with Gross with gold tuned PSU
      Snoopy8 14 Apr 19 compared with Gross with gold tuned PSU
      Galatic Soap 30 Jul 19 compared with Chord Hugo TT2 + BluMk2
      Max Headroom 30 Jul 19 compared with Chord Hugo TT2 + MScaler
      andrewyuri 2 Aug 19 compared with Chord 2Qute
      Steve M 8 Aug 19 compared with Holo Audio Spring Level 3, MF Trivista 21,  NuForce Reference, Topping D10
      Suopermanni 12 Sep 19 compared with Topping D70
      Pete Gardner 16 Jan 20 compared with Klein III
      Scott Daniel 6 Jun 20
      Klein III Reviews & Impressions
      pnes_nv 20 Oct 18 compared with Arcam irDac II
      pete_mac 10 Nov 18 compared with Klein
      DrSK 11 Dec 18 compared with Oppo 205
      Snrub 8 Mar 19 compared with Audiolab M-Dac
      lenticularis 4 Sep 19 compared with Modi 3
      pete_mac 24 Sep 19 compared with Audio-GDPCM1704UK
      bjs 30 Oct 2019 compared with Musical Fidelity M1 Dac, 14 Nov 19 compared with Chord Mojo
      krappo 26 Feb 20
      Groß (Gross) Reviews & Impressions
      illbarto 18 Sep 17 compared with Klein II
      Snoopy8  5 Oct 17 compared with Audiolab 8200CDQ, 13 May 18, compared with Chord 2Qute, PS Audio Direct Stream jnr
      BAM 6 Oct 17 compared with PSAudio Directstream
      bhobba 28 Nov 17, 22 Jan 18 compared with PSAudio Directstream
      Ancientflatulence 15 Dec 17
      Suopermanni 23 Dec 17 compared with Gungnir Multibit
      Bill125812 18 Jan 18 compared with PS Audio Nu Wave
      scumbag  18 Jan 18 compared with PS Audio Direct Stream jnr
      RussB 23 Feb 18, 8 Apr 18 compared with Klein, Chord Qutest
      Mattw 4 Mar 18 6 Mar 18 14 Mar 18 compared with Starting Point Systems DAC3
      Mike13 6 Mar 13 compared with Chord 2Qute, 13 May 18 compared with Chord 2Qute, PS Audio Direct Stream jnr
      Francisco 8 Mar 18
      Stereophilus 11 Mar 18 compared with Mola Mola Makua, PSAudio Directstream, Chord DAVE
      Assisi 11 Mar 18 compared with Mola Mola Makua
      Rosco8 24 Mar 18 compared with Cayin (Valve/SS),  ARCAM-II DAC II
      Bunno77 26 Mar 18 compared with Geek Pulse S Infinity
      Rawl99 2 Apr 18 compared with Killer
      rmpfyf 2 Apr 18 compared with Killer
      Conch 16 Apr 18 compared with Klein II, Chord 2qute, Accuphase Dac50
      Max Headroom 10 May 18, 13 May 18 compared with Chord 2Qute, PS Audio Direct Stream jnr
      buddyev 31 Oct 18 compared with Topping D50
      lemarguis 10 Jul 19 compared with Klein II
      Pkay 23 Jul 19 compared with Chord Qutest + Mscaler
      noisuf 23 Oct 20  compared with Denafrips Ares II
      Konverter Reviews & Impressions
      ~Spyne~ 29 Apr 17
       Woadl 13 Jun 17 compared with Auralic Vega
      Klein II Reviews & Impressions
       Andrewyuri 1 May 16 compared with Klein
       Jonny 31 Jul 16 compared with Antelope Gold
      Klein Reviews & Impressions
       GPK 17 Jun 15
       Bill125812 28 Jun 15 compared with NAD M51
       naggots  29 Jun 15
       rambada 7 Aug 15
       matt200sr 10 Aug 15
       naggots 21 Sep 15 on SE version
       scumbag 16 Oct 15 compared with MyDac
       joz 29 Oct 15
       pete_mac 5 Nov 15 compared with audio-gd DAC16DSP
       pop9745 25 Nov 15 compared with Chord Hugo, Resonessence Labs Concero HD, and Ifi
       betocool 1 Dec 15
       woadl 1 Dec 15
       andrewyuri 13 Apr 16 compared with Arcam irDac, Nad M51
      Jventer 15 May 16 compared with PSAudio Directstream
       NcA 27 May 16
       Tellmidd 16 Jul 16
       Powerav 15 Oct 16
       Zypr 16 Jan 17
      Terry0 11 Mar 18 compared with Oppo 205, Bluesound Node2
      Please post if corrections, additions required…
      p/s no association with Gieseler Audio.
    • By SssJedi
      Item Condition: Mint - always used with leather case Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Tarneit State: VIC Payment Method: Paypal with fees, EFT Reason for selling: Moved to desktop setup, surplus to requirements Further information:
      Chord Mojo with Miter leather case in great condition. Selling as have moved to desktop amp setup. Comes with original box and USB charging cable.
      Bought year and half ago but used for less then 6 months, as moved to Sony DAP and then a desktop setup.
      PLEASE READ
