Gijo1977 Posted February 11, 2019 Share Posted February 11, 2019 (edited) Item: Denon DP60L Direct Drive Vintage Turntable Location: Canberra ACT Price: $1100 + Packing/Shipping Item Condition: Excellent cosmetic condition with only a couple of blemishes both of which I’ve tried to highlight in the pictures. One is a graze on the left side of the plinth (minor colour repairs have hidden it well), the other is a small blemish in the plinth veneer between the tonearm and drive body towards the rear of the turntable (about 1cm long and hard to clearly photograph). Original mat is in great condition and the dustcover is very clean. Operationally all functions are working perfectly – both speeds lock immediately, the arm descends slowly and auto lifts gently at the end of the LP and the platter stops spinning quickly when ‘stop’ is pressed. I purchased this from a former member who directly imported it from his Japanese contact - it was serviced electronically, lubricated and tested before leaving Japan. Reason for selling: Desire to upgrade / Try something new Payment Method: Pickup - Cash, Paypal, COD Only Extra Info: This would be a brilliant way for someone who wants to try a foray into vinyl without spending mega bucks. This table bettered my enhanced Rega RP6 in pretty much every department (except the Gloss Black Modern Looks one) This example includes everything you need to have a high-end experience: 'S' Arm + Heavy Counter weight Straight Arm + Light Counter Weight Tortech Voltage Transformer (Bought new with turntable) Vintage Denon Headshell (~6g) Original rubber mat I have not included a cartridge though I can provide some insights into how Dynavector, Benz and Supex carts have worked. I can look to package the unit for shipping (or take to Pack and Send) but would require any purchaser to take shipping risk as there are no original (or professional packing materials). My preference is for local collection (and demonstration). Denon Description The DP-60L has a head shell integrated into the arm tube, with its connector portion located at the base of the tube. The tube is a replaceable S-shaped arm tube with standard 4P connector. By replacing the low mass arm tube with the S-shaped tube, virtually all head shells or integrated cartridges can be utilised. By having the ability to use the widest selection of cartridges, your audio enjoyment will be significantly broadened. Specifications Drive system: direct drive by AC servo motor Speed control system: servo control with frequency detection Speeds: 33.33 and 45rpm Speed deviation: less than 0.002% Wow and flutter: less than 0.015% WRMS Rumble: less than -78dB Starting time: less than 1.5 sec to 33.33rpm Platter: 300mm aluminium die-cast Tonearm: straight and s-shaped type Effective length: 244mm Overhang: 14m Stylus force: 0 to 2.5g Cartridge weight: 4-10g (straight tube), 12-18g (s-shaped tube) Dimensions: 485 x 180 x 410mm Weight: 13kg Pictures: Edited February 15, 2019 by Gijo1977 price drop 1 Link to comment Share on other sites More sharing options...
Gijo1977 Posted February 15, 2019 Author Share Posted February 15, 2019 Price drop - $1100 Link to comment Share on other sites More sharing options...
Ahh- Schnoo Schnoo Posted February 20, 2019 Share Posted February 20, 2019 I will take this if still available Message sent yesterday Please contact me Thanks Link to comment Share on other sites More sharing options...
Gijo1977 Posted February 20, 2019 Author Share Posted February 20, 2019 Sold pending payment - will edit ad from the laptop later. Link to comment Share on other sites More sharing options...
Roosy Posted February 27, 2019 Share Posted February 27, 2019 good purchase, beautiful turntable Link to comment Share on other sites More sharing options...
