praljak Posted February 8, 2019 Share Posted February 8, 2019 Hi Folks, I have just purchased a new PB16 Ultra. I am pairing it with Golden Ear Triton 1's and an Anthem AVM60 processor. I require some advice on the settings..... I have left the Low Pass Filter de-activated on the sub phone app. Within the Bass Management settings on the Anthem I have the 'Subwoofer LPF for LFE' set at 70Hz and the 'Front Crossover' set at 70Hz. I'm not sure this is the correct way to set it up so thought I'd ask. Any help is appreciated. Link to comment Share on other sites More sharing options...
Guest thathifiguy Posted February 8, 2019 Share Posted February 8, 2019 27 minutes ago, praljak said: Hi Folks, I have just purchased a new PB16 Ultra. I am pairing it with Golden Ear Triton 1's and an Anthem AVM60 processor. I require some advice on the settings..... I have left the Low Pass Filter de-activated on the sub phone app. Within the Bass Management settings on the Anthem I have the 'Subwoofer LPF for LFE' set at 70Hz and the 'Front Crossover' set at 70Hz. I'm not sure this is the correct way to set it up so thought I'd ask. Any help is appreciated. You will want some overlap between the two, so if you're happy for your fronts to go down to 70hz, maybe set the sub to kick in from around 90 - 100hz. Link to comment Share on other sites More sharing options...
praljak Posted February 8, 2019 Author Share Posted February 8, 2019 Thanks for that. My mains can go below 30Hz but I want to give the sub plenty of work to do Link to comment Share on other sites More sharing options...
Snoopy8 Posted February 8, 2019 Share Posted February 8, 2019 Suggest letting ARC run normally, then use profiles to tweak the settings. Profile 1 = normal, Profile 2 = cross over same for mains and sub, Profile 3 = overlap cross over. Profile 4 = mains to full. There is no "right" answer, listen and determine what is best for your room and setup. 3 Link to comment Share on other sites More sharing options...
Neilsy Posted February 8, 2019 Share Posted February 8, 2019 I would second this.What a speaker manufacturer says a speaker can do vs actual is another. Plus the LFE channel is meant to be set at +10dB to your mains... So if you run them below 80hz those frequencies are not at +10dB whereas the sub is meant to be.Suggestion maybe run mains at 70hz roll-off, Sub crossover at 90hz as you need to allow for dB per octave roll-off You will want some overlap between the two, so if you're happy for your fronts to go down to 70hz, maybe set the sub to kick in from around 90 - 100hz. Link to comment Share on other sites More sharing options...
praljak Posted February 8, 2019 Author Share Posted February 8, 2019 Thanks for the advice. I'll try a little experimentation and see how it goes. Cheers. 1 Link to comment Share on other sites More sharing options...
Snoopy8 Posted February 8, 2019 Share Posted February 8, 2019 A few more things to try Geeks Guide to using ARC-2 (Secrets of Home Theatre) Super Geek Guide to Tweaking ARC-2 (Secrets of Home Theatre) Link to comment Share on other sites More sharing options...
praljak Posted February 16, 2019 Author Share Posted February 16, 2019 Thanks Snoopy. Link to comment Share on other sites More sharing options...
Leftaudionut Posted February 27, 2019 Share Posted February 27, 2019 Just a heads up that SVS have a speaker matching tool that not only suggests a sub match but also recommends the crossover setting for both the sub and amp including the slope. https://www.svsound.com/pages/merlin Link to comment Share on other sites More sharing options...
praljak Posted February 28, 2019 Author Share Posted February 28, 2019 Cheers. I have set the crossover and slope according to this. Link to comment Share on other sites More sharing options...
TheDigitalPicture Posted April 22, 2019 Share Posted April 22, 2019 Hi, I can shed some light on this. In the Anthem units (and most others) where you set the speaker high-pass crossover and subwoofer low-pass crossover are independent. So if you set the left speaker crossover to 70Hz, the pre-amp will send all low frequency information on the left channel below 70Hz to the subwoofer. This does not affect the LFE channel at all. This is called a High-pass crossover, meaning that frequencies higher than this setting will be sent to the speaker. For the subwoofer, the LFE channel goes up to 130-150Hz typically, so set your sub crossover to 150Hz. All LFE data below 150Hz and all Left channel data below 70Hz will be sent to the sub. If you set the subwoofer low-pass crossover to 70Hz you will miss all LFE info above 70Hz up to 150Hz, which is a bad thing. Also, let the Anthem ARC software measure your sub and it will suggest an appropriate low-pass crossover, see what it gives you then tune it to taste. Scott Link to comment Share on other sites More sharing options...
