pulinap
Recommendation for DAC+Streamer+Headphone amp
Mornin' fellow SNA travellers, I am seeking your advice on a 3 in 1 device that has DAC+Streamer+Headphone amp up to a budge of 2K.
Conductor v2+ by Burson audio gets good reviews.
Audio GD have a good reputation.
I've been using the nad d7050 in a similar role quite happily too.
Thanks.
But can any of them bring used as a streamer connected to NAS and or stream Tidal ...
Don't reckon they do, though i did recently notice the d7050 no longer supports spotify.
if portable than any modern DAP should do what you want such as Onkyo, Pioneer, Sony, Fiio or iBasso, definitely check XDP-300R, DP-X1A, fiio M9 or dx150
if standalone I would look at Marantz ND8006 or Pioneer N-70AE,  typical cheap solution would be Bluesound node 2i, and many expensive products such as Auralic Vega G2, Moon audio etc...
 Uniti Atom, Marantz ND8006 ?
How about the Marantz NA6006 (which is a ND8006 without the CD player)?  Well under the $2K budget...
If budget can be stretched (or wait for sale), the NAD C658 is another option.  I have a NAD-T758V3 AVR, which is reasonable for 2 channel, especially with Dirac Live.  I would expect the C658 to be much better for stereo. And BluOS is user friendly and good for streaming.
After considering the comments above and doing some more research, I have shortlisted two:
1. ifi iDSD PRO - one box solution, valves, plethora of options, expensive
2. Holo Cyan+SoTM 200 - two boxes, better streaming capabilities, slightly less expensive.
Comments are welcome....:)
I assume budget is now significantly increased and more than 1 box is acceptable?   The ifi DSD Pro is certainly a good option.
If you are considering the SOtM SMS-200, then consider option to go second hand  SMS-200 Ultra.  Also MicroRendu and UltraRendu version...  Plus you then need to consider a better usb cable, which will make it more expensive than the ifi.
The budget remains the same.....
You can buy a new Holo Cyan and a S/h Sotm for just under 2k.
ifi iDSD pro might be just above 2k for s/h....Just have to have patience ....... :)
Cables+many boxes is the main reason for a one box solution....
Edited by pulinap
https://addictedtoaudio.com.au/products/ifi-pro-idsd-digital-analogue-converter
Wow, if you can get it for just over $2K, that is definitely the way to go.
Edited by Snoopy8
Typo with link
As I said.....patience is the name of the game.... (if you are on a shoe string...)
+ no one pays RRPs these days....
What was the kit that was decided?Looking for something similar.
Haven't decided one yet.....
But if you want all 3 to be decent....options are limited.
Realised that, now looking to combine DAC and Headphone Amp and leaving the streamer as a computer.
I did a bunch of research into combined DAC/HP amps a while ago. The ones I remember standing out as possible good buys were the Nuprime DAC 10h, Oppo HA1, Benchmark DAC3 and the Topping DX7.
If you consider second hand DACs there are plenty of people who praise the Chord Hugo, Hugo TT and Hugo 2, if you can find a bargain in your budget.
I personally have owned an Audiolab M-DAC and said plenty of nice things about it in the past.
Edited by Snrub
