Mungbean66
Hulgich Audio Serenade Review (KIND OF!)
This will mostly just be some thoughts on what I've observed and how I've felt these wonderful speakers have performed. I will try and steer away from describing music choices as I listen to most music and I don't feel it will add to this 'review' as so much can change based on the source and amplifier.
Although I don't really believe in burn in, I've waited around 300 plus hours to do the review so as to be fair to Nick from Hulgich Audio.
The Serenades are a statement piece. Beautiful like a painting, slightly imposing but impressive, they make the room feel like is has a purpose without overpowering the room like a set of floor standers can. They have a high WAF and the finish is top notch; many of our friends (including women) comment on how nice they look. The high gloss white is gorgeous. Nick must be a perfectionist because it has a finish that looks like it would suit a piano. Even the speaker connectors are top notch and look all class. The speakers’ cabinets feel really inert and easily pass the knuckle test. So overall, build quality is what you expect from something made in Australia.
The matching stands really do make the speakers and are equally well made.  Mine are a gloss black, with an unmistakable style, a beautiful match for these large standmounts. Although you could live without them, I don't think I could, now knowing how well they suit the speakers. Undeniably worth every penny and very stable (child proven).
The speakers were delivered packaged better than anything I have seen to date. They would have survived anything including a drop from great heights. Too give you an idea, it took me 45min to unpack the speakers and stands (frustrating but worth it).
In terms of sound: The sound seems to be generated from the ether, almost like if you’re were floating in the inky blackness of space and somehow music just started to flow out of nowhere. Another thing of note is the amount of bass generated by the 6 inch driver. This is a speaker that does actually reach below 40Hz. How Nick does this is anyone’s guess. You can hear kick drums and bass guitars and I've found that a sub for music isn't necessary unless you need depth below 35Hz or love chest thumping bass. Although the mid-range is magical on these speakers the treble is detailed without being too bright but won't be polite if the recording is 'hot' or a singer/instrument is hitting powerful high notes (this is how a speaker should sound...'live'). Live music is awesome, well recorded music is equally fantastic and even poorly recorded music is still listenable. You will hear and understand what makes it so. The Serenades really are a window in the music without feeling that something artificial is helping create the sound.
The biggest thing I've found though is what people call tone. Does it sound right? Spendors, Harbeths, some higher end speakers and now the Hulgichs are the only speakers that have done Missy Higgins' voice justice. Having heard her live on multiple occasions, I would always feel disappointed hearing a song of hers on a hi-fi system. For information, the worst audition demonstrating her voice was on a KEF LS50W.  This is not a knock on the KEFs but unless the room was at play, they did not reproduce female vocals well.
Not only are female voices created beautifully with the Serenade but so are their male counterparts, instruments feel equally well developed and honestly just sound 'right'. I have yet to hear something and felt it sounded 'wonky'.
I am also a huge fan of drums and the Serenades do really show what great recorded drumming sounds like. An example is how good the recording at Sound City was like for drums. Tool's Undertow, Rage Against the Machine's self-titled album and Nirvana's Nevermind; all excellent examples of this. Hearing every strike of a drum or the rim and how hard it was struck is something new to me and I quite enjoy it with the Serenades.
On top of this is the fact that every instrument, voice and nuance has its own space and it is easy to track each separately.
With every DAC I've used this remains true, even the NOS based Paradesia 3, Aune X1S, Hifimediy UDA38 and the PDX DAC (level 2). Two of these DACs contain tube outputs if that helps. I found that these speakers are far from coloured and really do give you an insight into what is feeding it. DACs (within this, even tube choices) and amplifiers make huge differences; this was not the case with my previous, rather modest speakers. It was during some testing that I realised that my NOS Paradesia 3 paled in comparison in terms of the 'width and depth' compared to the PDX DAC (this was alleviated somewhat with a tube and op amp change in the Pardesia). On my old speakers (Monitor Audio S6) the DACs sounded quite similar but after changing to the Serenades the gulf widened to the point where, I simply couldn't listen to the Paradesia 3 on my main system.
I never really knew what people meant about pressurising a room but now I do. These speakers can easily pressurise my 3.5m x 4m room with ease without losing composure and do this without having to increase the volume to ear splitting levels. One of the best things I've discovered is that like most people my lounge is a shared space so the speakers need to be close to a wall, fortunately these speakers are made to be close to a boundary.
Are there negatives? Of course, all speakers have some. For example, these speakers need power, 80W into 8ohms is just enough but I would say that over 100W is more ideal and after getting a 130W amplifier they just opened up another level. They do take a bit of power to come 'on song' as some people might say, which means that in some instances a preamplifier with gain may be needed. They will need the additional compensation circuit to be able to be driven from tube amplifiers. The stands are expensive but after seeing and using them, I believe they are necessary and the cost is justified. They are just as gorgeous as the speakers and I imagine, probably take as much work if not more to produce.
When it comes to music reproduction or when watching a movie, I don't hear any shortcomings and this seems like the end goal for many people, including me. The serenade is a very well rounded speaker that I believe would not be embarrassed being driven by high end amplification and sources.
If people would like me to give a detailed breakdown of some of the songs I used to test please just ask and I'll add to the end of this review after I've sat down for another critical listen of a few songs.
In case it's of merit I am currently running the following gear (Pic attached):
Power Regulation: 700W pure sine wave UPS
Streamer (USB): ALLO USBridge running DietPi
Media player (TOSLINK): PS4 Pro
Source:  HIFIMEDIY UDA38
PRE: Schiit Saga
POWER: Sansui 707i
Mung
Edited by Mungbean66
This will mostly just be some thoughts on what I've observed and how I've felt these wonderful speakers have performed. I will try and steer away from describing music choices as I listen to most music and I don't feel it will add to this 'review' as so much can change based on the source and amplifier.   Although I don't really believe in burn in, I've waited around 300 plus hours to do the review so as to be fair to Nick from Hulgich Audio.
PRE: Schiit Saga
POWER: Sansui 707i
Mung
49949612_385884132184759_8828102807874699264_n.thumb.jpg.9a95f2ca864152083d0bf64de4f812bd.jpg
Great write up , as a fellow Hulgich owner I feel very privileged to have - as you described an end game speaker! They certainly reward the best source and amplification you can provide, and obviously interconnects and cable.
And plenty of clean power, my Astors sound happy with around 200w - but cope well with my Melody valve amp at 42w driving them with ease
And the remarkable thing is all of Nick's speakers in his range sound amazing for their respective price point - his Dukes and Nina Bookshelves at the HiFi show were hard to split on which was better value, the soundstage and imaging were some of the best I've heard!
The quality of construction and impeccable finish is a credit to Nick's dedication to achieving as close to perfection.
I think once the outside World , and of course the broader Aussie hifi community cottons onto how well they stack up against often much more expensive brands - then Hulgich will become a very successful prestige brand.
No affiliation or bias on my side - just credit where it's due !
Hulgich speakers rarely come up in the classifieds. Actually, I don’t believe there have been any besides these Serenades and these  Maestro’s.
Nice review @Mungbean66These Serenades were a serious bargain. I was thinking about buying them as rears to match white Astors.
Having lived with the Dukes for several months, I concur that Hulgich does offer “end game” speakers at several price points within the realm of the achievable for most audiophiles. And for those who want more, Nick just might have a surprise in store:).
Lucky for me you didn't 😉. I actually prefer the way the grill and port are presented on mine.
First time I saw them, I knew I could live with them long term.
Elitist !!
Those Serenades are good enough for many as the front mains! :rolleyes:
Not surprised with your review. Heard the Maestros at the 2017 show and I can whole heartedly agree with the speakers disappearing and the music coming from nowhere. It really was that impressive.
@Mungbean66 Nice review and congrats on these fantastic speakers. Hope to hear them sometime.
BTW, which is that white TT you have on the rack? Sorry if I missed this in your post.
Cheers...
Hey Anand,
It's just a Pioneer PLX500. The internal preamp bypassed which helped quite a bit with sound. I didn't mention the TT as I don't really consider it good enough to critically listen to music on, I will probably need a better cart for that.
    • By ArthurDent
      Hulgich Audio & Holton Precision Audio
      8pm Wednesday 21st August
      Willis Room, City of Whitehorse Offices
      Maroondah Highway (Whitehorse Road), Nunawading
      Melway Map 48 Ref G9
      Contact: 9437 1249
      This month we have two interstate companies joining forces to present their Hi Fi products at the MAC. Both have exhibited together at the Melbourne International Hi Fi Show, winning "Best of Show Overall" for 2017 as well as "Best New Comer".
      Hulgich Audio is a new speaker company based in Adelaide headed by Nicolas Hulgich (pronounced Eu-Lich), who has spent more than twenty years in both Australia and his native Argentina building speakers with a variety of designs. He will be presenting to the club his statement speaker the 'Duke', with his in-house FTM (Feel The Music) speaker cable and interconnects.
      The 'Duke' is a 3-way floor stander designed as a dual enclosure. The upper enclosure houses a 1.2 inch dimple dome tweeter, and a 6 inch midrange made of papyrus fibres. The lower bass enclosure is a ported design that houses a 10 inch woofer also made of papyrus fibres. Hulgich has designed the 'Duke' to have a huge sweet spot and a large sound stage. By applying 'Low Diffraction Baffle Technology' (LDBT) that insures a smooth frequency response whether sitting off or on axis, and 'Coherent Sound Technology'( CST) which provides driver time alignment and phase integration.
      Nicolas will be playing his music with a modified OPPO 103 Multi-disc player and a AudioGD R8 Ladder Dac. Amplification is provided by Holton Precision Audio. Based in northern Tasmania, Anthony Holton has been designing and building high end amplifiers that have been demonstrated internationally at the 2018 Paris and Munich Hi-Fi Shows
      Anthony will be demonstrating two stereo amplifiers on the night, the Holton One-Zero-Zero Supreme (2x120W into 8 Ohms), and the Five-Zero-Zero Supreme (2x500W into 4 Ohms) with the matching Gain Block One Preamp. On static display will be a Phono Pre, while a 'DC Blocker One' will be used to look after the AC mains. This audio grade conditioner removes DC and filters the noise from the mains.
      With two presenters for the night, we are certainly going to have twice the value when it comes to sound quality. Not to be missed.
      Nick Karayanis, Program Co-Ordinator.
      Ken Tripp
      Wise and Wonderful Webmaster
      Melbourne Audio Club, Inc.
      http://www.melbourneaudioclub.org.au
    • By Mike13
      Item: Hulgich Audio Centre Speaker
      Price: $4,000
      Item Condition: Mint
      Reason for selling: Never required
      Extra Info: I bought this from @Marcto guarantee purchase of his Hulgich Astors (he wanted to sell as a package and there was a long queue of people wanting to buy them) on 14 Nov 2017, so I've had it a couple months but don't use it. He had it custom built by the Hulgich speaker designer to match the Astors. I don't believe he had it long.
      Marc paid a fair bit more for it and, according to Nick from Hulgich Audio, it is worth more than he paid. It is a serious centre speaker and is very heavy. It goes very low (30sHz I'm told). When I first used it I mistakenly thought the subs were on. I don't actually use it because the speaker spots on my amp are used by the mains and the Marantz AVR is different Ohms and I thought that could break it. It has a really nice custom built Hulgich stand, also very heavy, and a speaker cover (it looks better without). I had a shorter one of the new Hulgich Audio FTM speaker cables made for it, which you can have. http://www.hulgichaudio.com.au/ftm-cable.html It has some nice silver spikey feet (you might be able to see them on the Astors - I think they go under the stand? I think the specs are on the plate I photographed. If you want to know anything else I can ask for you. Local pickup preferred. Like all good audio, it is heavy and might be costly to ship. Actually, I don't have a box for it either.
    • By chefscuba70
      Hi all,
      Following our club meeting with Nick's presentation of his impressive sounding Ella Mk II speakers, Nick has graciously offered me the opportunity to hear these in my own system for the rest of this week to fully evaluate what these speakers are capable of achieving in a home environment as opposed to the large open room at the meeting hall last Sunday amongst a large crowd.
      So I thought, instead of selfishly listening and enjoying the Ella speakers all week, I would offer an open invite to anyone in Sydney who would like to listen to Nick's speakers to simply drop me a PM and arrange a time.
      I'll be able to host up to 3 people at a time any night this week until Friday between the times of 5.00pm to 8.00pm.
      The system will be;
      Hulgich Audio Ella Mk II speakers
      Plinius Reference amp in class A/B or class A power
      Classe CP-800 pre amp
      Antipodes DX2 music server running Roon or an Oppo 105 (CD or flash drive), each decoded by a Chord QBD76 dac
      Vertere IC's, Nordost Frey speaker cables and room treatments. Pic below.
      I have plenty of music on the server or bring your own. Sorry no vinyl but if it's truly a must have, I'm sure I can accommodate one you bring along.
      I live about 10 minutes from Parramatta (so no need for a compass) in a nice leafy suburb opposite a park (so no need to bring security) and I'm a friendly hospitable guy with a healthy liver and kidneys (I think).
      From those that attended the club meeting, most were very impressed with the sound of the Ella's with some saying they were in their top 3 -5 speakers heard at the club. Some info and thoughts can be found with the link below but ultimately you should hear them for yourselves to make your own judgement.
      Look forward to hearing from you.
      Steve. P
    • By TomW
      For our March club meeting, we are very pleased to have Nick Hulgich of Hulgich Audio present his Ella Mk II speakers.  The speakers of Nick and his design partner Göran Niréus have been attracting much attention worldwide.  Their speaker design and performance is of the highest standard.  Nick and his company is based in beautiful Adelaide – all Hulgich Audio speakers are meticulously crafted in Adelaide from the best quality components.  More below…
      Details of the system….
      Presented by Nick Hulgich of Hulgich Audio – refer to http://www.hulgichaudio.com.au/index.html
      Hulgich Ella MK II Loudspeakers - http://www.hulgichaudio.com.au/ella.html.  Also read about its Best In Show rating at the 2017 International HiFi Show - https://www.stereo.net.au/features/stereonet-awards-2017-international-hifi-show
      Nord Acoustics Nord One SE Mono Block amps - https://www.nordacoustics.co.uk/product-page/nord-one-se-up-nc500mb-mono-block-black-single and http://hifipig.com/nord-one-up-nc500-dmst-power-amplifier/
      FTM Cables - http://hulgichaudio.com.au/ftm-cable.html
      Mac Mini with External HD - presenters music
      Bricasti Design M1 DAC - http://www.bricasti.com/en/consumer/m1.php
      Classe CP-800 Pre Amp - https://classeaudio.com/cp-800/
      Oppo BDP-105D Multi Player - http://www.theabsolutesound.com/articles/oppo-bdp-105d-audiophile-blu-ray-disc-player/
      The second half of the music sessions will be our popular BYO.   Members and guests are welcome to offer music to share with us all.  So bring along your favourite music on CD/SACD or Flash drive.  Sorry, no vinyl this month.  All we ask is that the music and recordings be interesting.  We'll ask you to tell us a little about the artist/recording before it is played.  Tracks over 6 minutes will be faded out, to give everyone a fair go.
      Whether you are a novice or a seasoned veteran, you will have the opportunity to listen, learn and share your experiences with others.  Feel free to come and hear the capabilities of the system, or to just share the experience with like-minded music lovers in a friendly and relaxed atmosphere.
      Guests are welcome – we are a very friendly club so you don't need to know anyone to join us for an afternoon of fine music and sound.
      Venue:  Epping Creative Centre, Dence Park
      Address:  26 Stanley Road, Epping
      When:  Sunday 11th March 2018
      Doors open 1pm
      Meeting starts at 2pm
      Best regards,
      Tom Waters
      President
      Sydney Audio Club
      W: www.sydneyaudioclub.org.au
      FB: https://www.facebook.com/sydneyaudioclub
      E: tomwaters@sydneyaudioclub.org.au
    • By Marc
      Item: Hulgich Audio Astor Loudspeakers
      Price: $8500.00
      Item Condition: As new.
      Reason for selling: Funding a new build by Hulgich Audio, that impressed I have been by this speaker. This listing has the blessing of Hulgich Audio.
      Payment Method: Pickup - Cash, Paypal (+fees), or Credit Card (With associated fees)
      Extra Info: I received these very early from Hulgich Audio for a no-obligation product review for StereoNET. They've been here for approximately 12 months I assume. So impressed was I by what I heard, I called Nick and bought them full price, no questions asked. They've remained my benchmark reference speaker at the price point easily up to speakers I've heard approaching $25K and more. You can read my full review: https://www.stereo.net.au/reviews/review-hulgich-audio-astor-loudspeakers
      I do also have a custom design and built (by Hulgich), matching centre channel if you're interest in Home Theatre duties also. Price by negotiation.
      Auditions available here in Sunbury. I do have the original transportation crates that these were shipped from South Australia in, but for local transport I would suggest the normal care and wrapping / blanket etc. Preference is given to a local buyer, but if necessary freight can be arranged by the buyer and I will assist from this end.
