Antripodean Posted January 12, 2019 Share Posted January 12, 2019 Item: Planar XScreen 80” projector screen with stand on castors Location: Melbourne (3030) Price: $250 all included (over $4000 at the time of purchase) Item Condition: very good, very few marks what so ever. Still has plastic lining the picture frame Reason for selling: Getting a larger screen in the new house Payment Method: Pickup - Cash, Paypal (+ fees), bank transfer, COD Only Extra Info: This was the Rolls Royce screen at the time I bought it. Suitable for low medium light as well as a dark cinema room, it uses Daytime Screen Technology and displays well even with the lights on. It has a 4mm layer of hardened glass behind the screen surface and provides an absolutely flat screen, appearing like a plasma or other flat screen TV. I have had a movable stand made for it, which I am including, but you can also mount it to the wall. Lots of options given its strength and rigidity. I have the original box for it but given its size this is a pick up item only. From SoundandVision 2007: "At the core of the Xscreen is a high-gain, but highly directional, silvery screen. The point of this is to reflect as much light as possible from the projector but not the ambient room light (like a regular screen). To test this, I set up the Xscreen in our lab in front of our regular screen. Then, obviously, I projected an image on it. Just by dropping the Xscreen, I could see what the same-size image looked like on our normal 1.0-gain screen. Most readily apparent is the increase in brightness. The Xscreen was roughly three times brighter than our normal 1.0-gain screen. With the projector we were using, this resulted in around 94 foot-Lamberts versus 31 ft-L with the 1.0-gain screen. With the lights off, the black level was also about three times higher. With the lights on, however, an interesting thing happened. With a white field, the brightness on the Xscreen stayed almost the same, but, on the regular screen, it came up a little less than 10 percent (which, in this case, isn’t good, as it’s just reflected room light). With a 0-IRE black field, it was far more interesting. The black field on the Xscreen was actually 20 percent darker than it was on the 1.0-gain screen. It was doing just as it was advertised: It was blocking more of the ambient light than a regular screen. What this means is that the contrast ratio, on the 1.0-gain screen and the lights on, was a measly 57:1. On the Xscreen with the lights on, it was a far more watchable 194:1. With the lights off, this same projector measured over 8000:1, so the Xscreen can't work miracles, but it's doing quite a lot to make the image watchable in direct light." Link to comment Share on other sites More sharing options...
Antripodean Posted January 24, 2019 Author Share Posted January 24, 2019 This needs a new home. It's a great screen. Make me a fair offer and it's yours [emoji846]PM please Link to comment Share on other sites More sharing options...
Candyflip Posted February 9, 2019 Share Posted February 9, 2019 This advertisement has been withdrawn or the offer has expired. Link to comment Share on other sites More sharing options...
