Mitchelldean
FS: Audioengine D1 24-BIT DAC
Item: Audioengine D1 24-BIT DAC
Price: $100
Item Condition: Great- no marks of wear
Reason for selling: Sold my speakers for a set of bluetooth (with built-in DAC)
Payment Method: Pickup - Cash
Comes with protective case, setup manual and can throw in some decent RCA cables.
Edited by Mitchelldean
    • By logicaldisconnect
      Hi Dan, Do you still have this unit available?
    • By Tez821503563166
      Item full name and model: Olive 06HD 2TB
      Item condition description New Condition will suit new buyer
      Price and price conditions $2500 for DTV Users
      Payment Methods: Cash - Pickup preferred or Direct Deposit
      Reviews:
      http://www.whathifi.com/review/06hd
      http://www.gadgetguy.com.au/product/olive-06hd/
      Features:
      HD Digital-Analog-Converter based on top-of-the-line Burr-Brown PCM1792A
      • Fully balanced differential DAC. Two PCM1792A running in mono mode.
      • Ultra-low jitter master clock (10 picoseconds after re-clocking)
      • TI SRC4194 Asynchronous Sample Rate Converter (Up-sampling to 24-bit/384 kHz)
      • Ultra-fast op amps (< 20V/us slew-rate)
      • Analog filter: 2nd-order Bessel reconstruction filter
      High-end Headphone Output Powered by
      • Dedicated Burr-Brown PCM1792A
      • TI`s top-of the line TPA6120A2 High Performance Audio Amplifier (current-feedback architecture)
      High-precision linear power supply
      • Separate supplies for analog and digital components
      • High-performance AC line filter (ultra-high noise attenuation at close to 80db)
      • Custom-built toroidal transformer
      • Large reservoir capacitors
      • Ultra-low noise linear regulators (two stages of regulation, dedicated linear regulator for the clock generator)
      High-speed processor
      • Flawless encoding and decoding of lossless audio format
      • Fast management and access to extensive music libraries
      • Simultaneous streaming of high quality audio to multiple rooms
      Built-in CDRW drive
      • High fidelity TEAC CDRW mechanism
      • Import: Audio CDs
      • Burn: Audio CDs, MP3 CDs, Data CDs
      Ultra-quiet 2TB hard drive
      • 2.5” power-efficient AV hard drive
      • 2TB holds approximately 20,000 HD tracks or 6,000 CDs in original quality.
      Networking
      • Wireless (802.11a/b/g/n)
      • Gigabit Ethernet
      • Supports 1-button setup via Wi-Fi Protected Setup
      • Play music from Mac, PC, NAS (UPnP software required)
      Supported Audio Formats
      WAV, AIF, FLAC, MP3, AAC, Apple Lossless, Ogg Vorbis
      Audio Output
      Analog:
      o 1x XLR (Balanced), made by Neutrik
      o 1x RCA (24k gold-plated)
      o 1x Headphone, stereo, 6.4 mm
      Digital:
      o 1x optical
      o 1x coax (24k gold-plated)
      o 1x AES/EBU (Balanced), made by Neutrik
      Note: All digital audio is scaled to 24-bit/96kHz on digital outputs.
      USB
      Backup of music to external USB HDD
      HDMI OUT
      (1080P)
      Please note: Note comes with all original packing, accessories including remote, and power cord.
    • By jel
      In excellent condition with original box, remote (and allen key)
      Missing manual but it is available online at:
      http://www.aprilmusi..._Manual_Eng.pdf
      Review at:
      http://www.stereo.ne...mpdac/?hl=dp200
      + others on the net, google away.
      SPECIFICATIONS
      Digital to Analog Converter
      Selectable 24Bit/192kHz Upsampling (Bypass, 48, 96, 24Bit/192kHz)
      4 Digital Inputs AES/EBU, Coax 1,Coax2, Toslink
      3 Digital Outputs AES/EBU, Coax, Toslink
      AES/EBU: 110 Ohms
      COAX 1, 2: 75 Ohms
      Preamplifier
      Inputs 1 Balanced (XLR), 2 Unbalanced (RCA)
      Analog Input Voltage AUX 2: Max 1.4 Vrms
      Balanced: Max 1.0 Vrms
      Analog Outputs 1 Balanced (XLR), 1 Unbalanced (RCA)
      Max Output: 3.5 Vrms
      Digital Volume Control (FIXED, VARIABLE Output Mode, selectable)
      Full Balanced Class-A Operation
      Headphone Amplifier Interface & Socket
      Bypass for Surround Processor
      Full Function Remote (Standby, Upsample, Record, Display, Input, Volume, Mute, Bypass)
      Dimension (WHD) & Weight
      435 x 94.5 x 345(mm), 9 Kg
      Price
      $1200
      Pickup preferred but can ship if required.
    • By Cafad
      Item:  Redgum CD5ENR  2005 model.
      Price: $450  firm
      Item Condition: Excellent
      Reason for selling: I have 5 cd players and need to cull a few.
      Extra Info: Made with custom silver wiring for the first owner.  This model does not have a remote control so I was only using it as a DAC.  Very detailed, very energetic and very fast sound.  No original box, will wrap securely before packing.  Will also test play before sending.
      Here is a pic of it sitting on top of the pre and mono-block amps I used to have.
    • By Cafad
      Item:    Burson Conductor CV2+ (yes, this is the version with the DAC)
      Price:   $550 firm    (includes postage to the eastern states, maybe an extra $10 or $20 to WA or TAS)
      Item Condition:  Excellent, just over 2 years old.
      Reason for selling:  I've upgraded to a Gross DAC so the faithful Burson is not required anymore.
      Extra Info:  Comes with original double box and all original extras, cables, remote, etc.  See pics for details.
