Rockster
Rotel RT-12 Digital Gateway, DAC and Tuner
Item:  Rotel Digital Gateway, DAB+, Wireless Internet and FM Radio
Price: $495
Item Condition: Excellent, one owner, used in a dedicated music room, complete with all original accessories and packaging.
Reason for selling: NLR
The RT-12 is an FM and DAB+ preset radio tuner and much more besides. By incorporating wireless and Ethernet network capabilities, the RT-12 can receive thousands of internet radio broadcasts, and play audio files stored on UPnP servers such as Windows computers. If your computer is home to a library of music files and you have wondered about playing them over your hi-fi, the RT-12 is your answer. The RT-12 boasts digital to analogue conversion based on the Wolfson WM8740 DAC chip to ensure that each digital source retains every last drop of musical quality, and it can serve as the wireless hub for the Rotel iPhone and iPad Remote app to control the entire hi-fi system.
Specifications:
Model: RT-12
FM Tuner -
Usable Sensitivity: 22.2dBf
50dB Quieting Sensitivity: 27.2dBf (mono)
Signal to Noise Ratio: (at 65 dBf) 63dBf (mono) 60dBf (stereo)
Harmonic Distortion: (at 65 dBf) 0.2% (mono) 0.3% (stereo)
Frequency Response: 10Hz-15kHz, ±3dB
Stereo Separation (100/1kHz/10kHz) 40dB/45dB/35dB
Output Level 1.0V
Antenna Input 75Ω unbalanced
DAB+ Tuner -
Sensitivity -80dBm
Tuning Range Band III 174-240MHz
Audio Data Rate 320Kbps (Max)
Frequency Response 20 - 20KHz +/- 1.0dB
Analogue Output 2.1V at 0dBFS
Antenna Input 75Ω F connector
Networks -
Network Connection 802.11b/g
Security WEP, WPA1 (TKIP) , WPA2 (TKIP)
File Formats (UPnP Music Server) AAC, MP3, WMA (except lossless), OGG
Vorbis, WAV, AIFF, FLAC and AU
General -
Power Consumption 16 Watts
Standby Power Consumption (Normal Mode) 0.5 Watts
Power Requirements (AC) 120V, 230V, 50Hz (Australia)
Weight (Net) 5.1kgs (11.24 lbs)
Dimensions (W x H x D) 430 x 93 x 330mm
Front Panel Height 80mm
Finish Black
    • By Ron12
      Is this happening anywhere else?  I was tuning past some DAB+ stations this morning went past Koffee, but the music sounded more like Smoth FM.  In fact there were occasional announcements for Smooth FM, but they were for Smooth 95.3, i.e. Sydney not Melbourne.  They also had the occasional ad, again Sydney related.   It wasn't a rebroadcast of Smooth 95.3 itself.  This afternoon it's still the same.
      Koffee is still on the internet though, so what's going on?
    • By g12345567
      My DAB+ digital radio is reporting that BBC world service on SBS digital 4 is changing to SBS digital 3 on April 18. SBS 4 currently plays the BBC/Special events channel.
      Can't find any further information on what this means for the current lineup of programs.  So was wondering if anybody has any further information on this change.
      Does this mean BBC will become 24/7 on SBS 3 or will it still remain the BBC/Special Events channel? What will happen to SBS Chill currently on SBS 3? Will it move to SBS 4 or just be discontiued?
      SBS 3 radio is also on Digital TV. Will that also change?
    • By alanh
      HE AAC compresion is used in our DAB+ digital radio along with DRM digital radio & DVB-T2 TV.
      Remember that DRM+ is quite capable of carrying 160 kbit/s, the DAB+ 64 kbit/s/broadcaster is a restriction!
      Sound compression for TV must become more efficient because of the increases in efficiency in video compression. MPEG-4 halves the data rate and H265 halves this data rate again!
      http://www.iis.fraunhofer.de/content/dam/iis/en/dokumente/pr/2012/20120906_IBC_TV_e.pdf They are the researchers, and manufacturers of the broadcast equipment.
      http://www.abu.org.my/Latest_News-@-Radio_on_the_agenda_at_DBS.aspx
      Alanh
    • By alanh
      http://www.drm.org/wp-content/uploads/2013/03/India-DRM-trial_NXP.pdf
      http://www.nxp.com/products/automotive/multi_standard_digital_radio/#overview
      Finally a world digital radio can be made with existing chip at an economic price.
      Alanh
    • By Ron12
      Was listening to abc 774 on my DAB+ radio overnight and this morning and it didn't sound much better than AM in terms of frequency response. Am I the only person getting this?
      The bitrate was 64kbps but it sounded worse than say Newsradio on the same radio or ABC 774 at 64kbps MP3 or 48kbps AAC on my iPhone. Signal quality was 100%.
