abnrqk Posted January 10, 2019 Share Posted January 10, 2019 (edited) Item: Schiit Magni 2 Uber Location: Adelaide, SA Price: $160 Item Condition: In excellent condition Reason for selling: Bought a new amp so surplus to needs Payment Method: Pickup - Cash, Paypal Extra Info: Comes with power adapter, packaging. Vendor notes: http://schiit.com/products/magni-2 http://schiit.com/public/upload/PDF/magni-2-uber-manual.pdf Magni 2 Uber is ready for any headphone, from IEMs to hard-to-drive orthodynamics. Switchable gain provides the fine control and low noise floor you need for sensitive headphones, as well as the power you need for hard-to-drive high-impedance headphones and orthos. Frequency Response: 20Hz-20Khz, -0.1db, 2Hz-250KHz, -3dB? Maximum Power, 16 ohms: 2.1W RMS per channel Maximum Power, 32 ohms: 1.5W RMS per channel? Maximum Power, 50 ohms: 1.2W RMS per channel? Maximum Power, 300 ohms: 320mW RMS per channel? Maximum Power, 600 ohms: 160mW RMS per channel? THD: Less than 0.002%, 20Hz-20KHz, at 1V RMS? IMD: Less than 0.003%, CCIF? SNR: Greater than 104db, unweighted, referenced to 1V RMS? Crosstalk: -70dB, 20 Hz-20KHz? Output Impedance: Less than 0.2 ohms? Gain: 1.5 (3db) or 6 (15.6db), selectable via rear switch Preamp Output: Yes, controlled by volume pot and switched via headphone jack Topology: Fully discrete FET/bipolar, constant feedback through audio band, complementary VAS drive, Class AB, DC coupled throughout? Protection: Standard failsafe DC power input and muting relay? Power Supply: “Wall wart” style 24VA 14VAC transformer, regulated +/-15V rails, with over 6,000uf filter capacitance Power Consumption: 5W? Size: 5 x 3.5 x 1.25”? Weight: 1 lb Photos will be uploaded tomorrow. In perfect working condition and no cosmetic flaws. Edited January 11, 2019 by abnrqk Link to comment Share on other sites More sharing options...
