Matyk
Qed ref 40 xlr (0.6 ) meter.
Item: qed xlr
Price: 170 $
Item Condition: 2 hours old
Reason for selling: nlr
Payment Method: Pickup  sydney only.
 170$$
 pickup only!
Edited by Matyk
## price drop  180$$$###
170$
Edited by Matyk
170$
Edited by Matyk
3 minutes ago, Al_B said:
Hi, I've sent you a PM
To post means effort from  me
Dirt cheap and post?
Nah. No thanks
    • By Vladas
      Item:
      MASTERSOUND INTEGRATED TUBE AMPLIFIER BOX R
      Parallel Single Ended in "Class A" Integrated - Made in Italy
      Power: 2 x 35 Watt
      Tubes complement: 2 x ECC802 - 6 x EL34
      Input: 3 line + Phono MM
      Output: 1 line
      Load imped.: 4-8 ohm
      Bandwidth: 18 hz / 25 khz 0 db
      Output Transformer: MastersounD
      Automatic Bias
      Supplied with remote control - R version
      Negative feedback: 0 db
      Dimensions: 43,6 x 40,9 x 18,5 cm
      Weight: 24 Kg
      Made in Italy
      Price:  $3000 (RRP - $5200)
      Item Condition: Brand New - still in the box
      Reason for selling: Change of financial situation
      Pure Class A  2x35 Watt PSET (Parallel Set) which is used in the very high end tube
      amplifiers like Aries Cerat $30K USD. This gives you uncompromising power to run in pure class A almost any 89+ db speakers.  Lack of power is Achilles weak spot of most tube amplifiers and I believe PSET is the best solution used by the very high end manufacturers. Legendary Mastersound brand - makes PF100 tube amplifier $50K USD. Fabulous musical EL34 tubes. To my knowledge, this model is absolutely the best value for integrated tube amplifier in that price range; made in Italy but priced similarly to comparable Chinese models. Includes very good phono pre-amplifier - same as in the flagship models.  This is Box R version with remote control (cost $330 AUD extra).
      Links below shows additional information about The Box and Mastersound brand in general:
      http://www.mastersoundsas.it/1/reviews_4451773.html
      https://soundapproach.com/mastersound-box-r-integrated-amplifier-class-a.html
      https://www.technologyfactory.eu/en/mastersound/integrated-amplifiers/mastersound-box/a-5384-10000401
      https://forum.audiogon.com/discussions/axpona-2018-integrated-mastersond-box
    • By russell66
      Item: Klipsch Synergy Home Theatre Speakers
      Price: $600ono
      Item Condition: Very Good all working well, some minor marks.
      Reason for selling: No Longer Required
      Excellent sounding home theatre package. Klipsch are well known for their cinema speaker designs.
      Fitting out many cinemas and shows with these speakers.
      They excel with soundstage, dynamics and detail.
      Package consists of ...
      2 x Synergy F10 Floor-standers
      2 X Synergy B20 Bookshelf's
      1 X Synergy C1 Centre
      1 X SW 350 Sub Woofer
      Post is available at your cost and risk.
    • By fffastfaz
      Item: Chord Shawline USB Cable 1M
      Price: $275.00 incl postage
      Item Condition: Brand new
      Extra Info: Cable is brand new and cost $350.00
    • By 81Vintage
      Item: Custom Rega Style Turntable, AudioMods Tonearm, IsoDrive PSU
      Price: $3300 Price Drop $2850 inc shipping Australia Wide, can do a little less if you can collect in person to save packing and freight.
      Item Condition: Excellent, Used
      Reason for selling: New Project/Custom Build
      This is a complete custom build from the ground up based on a Rega P series design. Raw cost of materials and items was over $6000.
      Plynth milled from single block of billet alloy on CNC router (around 15kg) Finished in red automotive paint Followed same dimmensions as a Rega P3 plynth. 5x Maglev feet (tried with 3, 4 and 5 configurations and 5 was the best) IsoKinetic IsoDrive Power Supply with 33/45 speed selection IsoKinetic 25mm Acrylic Platter IsoKinetic IsoSub Groovetracer Machined Subplatter IsoKinetic Phosphor Bronze Bearing Sleeve IsoKinetic Ruby Bearing + Spindle Oil (lifetime supply left in bottle) IsoKinetic Puck/Stabiliser IsoKinetic Red Thing Silicone Belt + Spare New One in Packet IsoKinetic MTB-D Motor Thrust Bearing + Motor Isolation Mod for Premotec Motor Premotec 50hz Synchronous Motor Audiomods Series 4 Tonearm with Series 5 bearing, lift and arm hold. Full VTA Adjustment - no VTA adjuster.  All original weights and headshell weights/spacers included to adjust to any cart. Custom Acrylic Dust Cover to accomodate arm height No cart included, but I did have an Ortofon MC25e on it and it was stunning.
      *I have covered the hole bottom left corner where a power button would have gone if I didnt use the external motor PSU and controller with a samurai silver coin from WA mint. So the turntable is dubbed "The Samurai"
      For interstate buyers, it will be professionally crated and foam lined for shipping with tonearm back in original transport box. Shipping Australia wide with insurance included.
      For those that want to know where to from here - my next build will be in the similar vein...but using the MK6 Audiomods tonearm for primary, 200mm monster delrin platter,  ceramic bearing sleeve, larger billet plynth with 2 armboards for future arm addition and external motor and controller.
    • By Vintage_Hi_Fi
      Item: Thorens TD-316 turntable
      Price: 700
      Item Condition: used
      Reason for selling: no longer needed
      Extra Info: Thorens TD-316 turntable. New belt fitted and new upgraded RCA leads. Includes original power supply. Includes Shure ME95ED cartridge with new high quality stylus. Includes original manual and is in excellent cosmetic condition floating platter system with original tone arm.
