Sime
Chord Electronics Owners & Discussion Thread
I believe that what the Mscaler brings is system dependent, particulary concerning speakers. I was not greatly impressed when I heard it at a dealer, but when I loaned one it was a different matter. It totally transformed my system and I made the purchase.  The improvement the Mscaler brings mainly concerns the sound stage and the speakers need to be responsive. I am yet to read of anyone with PCM speakers being all that impressed with the Mscaler.
I'm hoping another M-Scaler owner might be able to help me out here with a bit of an issue.
Firstly, some background. My M-Scaler runs into a Chord Dave via twin Analysis Plus BNC cables. Source is an Innuos Zenith connected to M-Scaler via Curious USB. Previous source was an Aurender N100.
When playing 16 bit 44.1kz files, the system works perfectly. I accept others may have different opinions, but I love the sound, the level of detail. It is the best my system has ever sounded. The issue arises when playing higher resolution files
Anything over cd quality results in irregular pauses/silences in the music. Not long, maybe a second, but incredibly annoying. It has happened with both sources, and from locally hosted high res files and Tidal MQA files (first unfold on the Aurender). I tried reducing the level of upscaling but that didn't make a difference.
I have searched for this issue but haven't found other references to it. Has anybody else come across this problem, or read about it somewhere? Any feedback would be appreciated
@markm1111 is this at the beginning of a track when the M-Scaler goes from 44.1 to a higher Bitrate?
If so, that’s normal, I’ve had conversations with Rob Watts about it and it’s just basically the m-scaler and the dac combined deal with bit rate changes. It’s not ideal, but how it is.
ive got a whole conversation with Rob Watts you can read if your interested.
The full 16x upscaling adds 600ms of latency but once started should continue uninterrupted. Any time you change sample rate it will add that latency as silence. If you're going to an 8x upsampling (by starting with 88/96) then the latency will be 300ms.
Wrong.
from Rob watts
OK I have checked the code, and there are reasons for the behaviour, and it's due to locking of the DAC when SPDIF goes out of lock momentarily on the M scaler. That's why it flashes red, as the default 44.1 is sent to the DAC when it's input goes out of lock. Clearly I don't need to do this with Qutest on its own, it just mutes during SR change - there is no need to maintain M scaler/DAC lock under all circumstances.
8 minutes ago, Sime said:
Wrong.
from Rob watts
Maybe, but the latency is still very real.
But it has nothing at all to do with the issue.
dd you even see what’s actually happening in the video?
Edited by Sime
Can't watch from where I am right now, sorry
But it’s been discussed with Rob and myself already, and it’s all to do with the reclocking of the two devices.
If your playing a track and decide to click the next track half way through and the next track is a higher resolution, some good aweful noises can occur.
Alrighty, my mistake. I thought the latency would be responsible.
@Sime @Ittaku
Thanks for the thoughts guys. Unfortunately it isn't just at the beginning of the track. It happens sporadically throughout the song, no particular time intervals, very inconsistent. It almost feels like it is buffering
Have you tried using coax or optical into the scaler?
Not an option for me, only output on both Zenith and N100 is USB.
I might temporarily pull my Audiophilleo 2 out of the other system to give it a try, but I don't want to permanently introduce another element. If that works, then I might have to try different USB cables to see if any of them make a difference.
@markm1111 yeah, my scaler/Qutest have never done what yours has running coax all this time so I can’t be of much help.
My Mscaler has never done this connected to a microRendu via USB.
On 19/08/2019 at 9:31 AM, rossb said:
Having lived with three M Scalers (okay, two M Scalers and a Blu 2) with four chord DACs, the DAVE, TT2, Hugo 2 and Qutest, and having compared the M Scaler to PC upscaling via Roon, I don't agree.
It is true that the M Scaler sounds a bit better than PC upscaling. Rob Watts clearly tweaked it to produce a warmer sound than conventional upscaling. But it still sounds bright, brittle and etched to me - the same as software upscaling - just a bit less so. In other words, not an improvement at all and in my opinion, a significant downgrade in sound. The effect of the M Scaler is to remove the natural warmth, fullness and texture of the music, and replace it with an artificial sense of detail that people seem to hear as an improvement.
For a couple of years I drank the Chord Kool Aid and convinced myself that the Blu 2 improved my DAVE, and that the M Scaler improved my TT2. I posted gushing reviews of which I am now embarrassed. When I briefly listened to the DACs without the M SCaler and found that it sounded warmer, fuller and more natural, I convinced myself that I was mistaken. The M Scaler made a remarkable difference, so of course it must be an improvement. Except that it wasn't.
Try making a digital recording from a known and repeatable audio source - eg from an LP - play it back over a Chord DAC without the M Scaler. And then play it again with the M Scaler, compare it to the source, and you will find that it becomes a bleached, etched replica of the original.
The first time I heard the DAVE and Blu 2 at a dealer a couple of years ago we swapped back and forth with another well-known, reputable high end DAC. The DAVE/Blu 2 sounded so radically different that I thought Rob Watts had discovered some hitherto unknown principle of digital playback and that what I was hearing was a revolution. I wasn't sure I liked it but it sounded so radical that I ordered the DAVE on the spot. But I know now that most of what I heard that day was the Blu 2 upscaler. In that unfamiliar system, it was the Blu 2 producing the massive difference between the DACs, and if I had heard it in my own system that day I would probably have recognised the bright, colourless, forensically lean sound it was producing as grossly unnatural. Unfortunately, like many others, I interpreted difference as improvement, and strangeness as innovation.
Of course, I am in a minority. Most people do seem to like the M Scaler, and believe that it is in an improvement. But I know I am not alone, there are quite a few others who have similar views of the M Scaler to mine. But if you own a Chord DAC, definitely listen to the M Scaler before buying one and be sure that the difference you are hearing is a worthwhile one before spending big money on one.
I’m also in the minority. Having had the Qutest and M Scaler for a week I would agree with your review.  I found that I preferred the Qutest without the M Scaler.
When I first heard the Mscaler at a dealer, paired with a Qutest, it did not sound as good as the Qutest alone in my home system.  When I took it home on loan the improvement was nightj and day. I could not be without the expanded sound stage and increased seperation between everything.  My view is that what the Mscaler brings is system dependent as well as a matter of personal taste.
Hi guys,
I am considering upgrading hugo to hugo 2, can some owners give me feedback/advice?
Are there any Chord DACs which support volume control via USB?
I have an Auralic Aires connected to my Qutest via usb, I can change the volume via the Aires (iPad controller). Is this what you mean?
Hard to say, it could be that the Aires is doing volume control (which means a loss of resolution) instead of the Qutest. When I tested the Qutest at the store I tried it via USB with a few devices, an iPad, Mac, PC, and it didn't support volume control with any of them. Likewise for the Hugo TT.
I was hoping maybe the Hugo TT 2 might support this.
Hi all, I have a question.
I’m currently using chord TT as a dac connect to a preamp. I find that TT is controlling the volume. The volume on my preamp doesn’t work much now.  Is this correct? I prefer dac just to the dac job and let pre amp to decide the volume. How can I do this?  The manual had some instructions but I find not very detail and clear.  If anyone know please help. Thanks.
@TDX, if you turn off the Hugo first.
then turn on the Hugo TT from switched off while holding the X-PHD button (second silver button in from the left side)
the Hugo should light up blue on the volume wheel indicating the “line level output” is enabled.
Hope this helps :)
Edited by Signatune
Hope this helps :)
I see! Your explanation is better than the textbook (manual)!  Thanks mate.
