Doug06 Posted December 27, 2018 Share Posted December 27, 2018 I have a Plinius 2b preamp with 7b power amp that I am hoping to get going again to run my turntable though the MM stage. The preamp or the power supply (from the power amp) going to it developed a problem several years ago were it would cause the speaker drivers to move over a long extension in and out at a relatively slow speed (can't remember if it was accompanied with sound). I say the preamp seemed to be the problem because since then the power amp part of the combo has been fine powering a couple of sub speakers from a different amps sub output. Any ideas of what might cause this problem with the preamp and if it is likely to be cost effective to get fixed? Any Adelaide people know of a good tech they would trust to look at it? Link to comment Share on other sites More sharing options...
Zaphod Beeblebrox Posted December 27, 2018 Share Posted December 27, 2018 No idea without seeing the product, but I have found that Plinius (NZ) to be extremely helpful in the past. I would suggest you contact them. They can also advise you of a suitable repair person in your area. Link to comment Share on other sites More sharing options...
BioBrian Posted May 17, 2019 Share Posted May 17, 2019 I've just come across this, and wonder how you went. I have a similar pair (Plinius 2B and 7), and remember once seeing the woofers moving in and out an alarming amount, really slowly. I thought it must the the same speed as the TT rotation. Were you running the TT when you noticed this? Link to comment Share on other sites More sharing options...
