The One Demon
Two subs too much for my room? (Velodyne SPL-1000 + SPL-1200 Ultras)
So I'm thinking about possibly getting a second sub in the future, but not sure if it'll be too much for my room? At the moment i have a Velodyne SPL-1000, but I'm thinking of also getting a SPL-1200 too. The room is about 6.7m x 3.6m x 2.5m high (I'll get new measurements tonight), there's a door that's always open smack bang in the middle of the front wall to the dining/kitchen/lounge room (large open area basically).
I'm also wondering if it's a bad idea at all to have different sized subwoofers? I'm guessing it'd be fine though.
I just got my HTS setup the other day, and my god it sounds so much better than my old one (like a $600 or something HTiB). It certainly makes for a more enjoyable and cinematic experience!
Also does anyone know where I could get a remote for these Velodyne SPL-1xxx Ultras? I've contacted Velodyne about it about 2 weeks ago but haven't had any response at all.
EDIT - Forgot to say it's a bedroom as well as the entertainment room I guess. It's basically divided in half, left side is bedroom, right side is where the TV, lounge, etc is if that makes a difference.
Edited by The One Demon
Added that I currently have the SPL-1000.
just get in touch with velodyne local agent (who ever that is at the present) or work through the retailer purchased from originally. this is best. large organisations are not often setup to deal directly wiht end user/customer, usually expect that through local agent/retailer who are more setup for direct customer contact.
as to subs, no problem with two and no dont have to be the same. do be careful in setup as one can literally kill and neutralise the other ! also one can compound the others faults. so be very with placement. you will need also an AVR that can handle dual setups for measurement, setup and eq. however placement is key. some suggestions
the harman white paper below is a good one on what tends to work in most rooms,
https://www.harman.com/sites/default/files/multsubs_0.pdf
so something like front back, with the large one up front and smaller up back is probably best point to start. if have an odd shaped non stereotypical room then either trial and error or measurement are best ways forward. the model up velodynes in the DD series come inbuilt with a RTA (real time analyser ) which can use to optimise one sub, two subs for placement.
note this is all before EQ which then like spak filler can be used to add final touches and integrate :)
I dont know how this room is going to be setup, but if split in half setup (physical) of speakers and subs is going to be crucial.
Thanks for the info! Will check that paper tonight after work. It's a rectangular room, skinny and long. Just that because it's also a bedroom the other half is taken up lol. Should be able to put the smaller sub back left or right though most like left I think, because the right is a corner where a surround will be on a stand and there's a skinny bookshelf there too.
the other thing to consider is how much you are looking to pay for the 12" version. the last one on stereonet i think was $900?
yes i would have 2 subs and yes one would be a 12", fine with the 10. but watch your spend as adelaide things can easily be overpaid for. recent sales of svs pb2000's were around the $800 mark and a pb13 ultra went for $1500. just saying do your research.
as for the remotes they sometimes come up on ebay for silly prices. maybe a universal remote and you can down load the settings to that.
Edited by hopefullguy
Yeah I missed out on that $900 one, ended up paying $1,100 plus postage. I was more going to go for another SPL-1000 or the SPL-1200 because they should be very similar to each other and keeping it the same is just easier lol (Do these noticeably sound different like different speakers?). What would you consider a decent price for a used SPL-1200? Also what if I got a PB2000 or PB13 Ultra? would it still be fine even if you're mixing sealed and ported subs?
You are pretty on the money that subwoofers are like speakers, so I wouldn't mix and match too much unless you want them doing completely independent loads. But that can create other issues and does require an AVR or processor that has a lot or control with dual sub output.
I'd recommend keep your eyes peeled for another SPL 1000 or 1200 second hand.
It's the easier integration method for the most balanced response
    • By Keith Raufer
      Item: 18” Subwoofers, Dayton UM18, Sealed Black Oak Enclosures.
      Price: $1400 each
      Item Condition: 6 months old
      Reason for selling: Need Room
      Extra Info: I have 2 Dayton Ultimax UM18 Subwoofers, (subs only, no amp). Finished in a custom 4 cubic feet enclosure, made from 25mm MDF and very heavily braced. The Subs weigh in at just over 50kg each and are wrapped in a black oak veneer. Connections are speakon for simple secure connections.
    • By olegau
      Item: Infinity Primus PS-8 Subwoofer
      Price: 180 ono
      Item Condition: good
      Reason for selling: upgraded to bigger one
      Great sound and, besides a small dent in the speaker cone, great condition.
      Infinity PS-8 Subwoofer
      Features and Specs
      Enclosure  Bass Reflex
      Video Shielded   No
      Woofer Size (inches)   8
      Woofer Composition   M.M.D.
      Firing Direction   Front
      Wireless    No
      Preamp-Level Inputs   3
      Speaker-Level Inputs  Yes
      Speaker-Level Outputs        No
      Low-Pass Crossover Freq   50-150 Hz
      High-Pass Crossover Freq  None
      Phase Switch     Yes
      Amplifier Output (watts)        100
      Frequency Response 35-150 Hz
      DIMENSIONS & WEIGHT
      Width 10.6 in
      Depth 16.8 in
      Height 17.5 in
      Weight 33.07 lbs
      Features
      Metal Matrix Diaphragm (M.M.D.): Derived from the C.M.M.D. material used in Infinity's flagship Prelude drivers, M.M.D. features a stiff aluminum core that provides exceptional strength and rigidity for clean, realistic low-frequency tones.
      Amplifier: The 8" M.M.D. front-firing cone woofer is powered by a 100-watt (RMS) amplifier.
      Surround: For a smoother response and improved durability, the woofer uses a rubber surround.
      Bass Ports: There are two rear-firing bass ports that allow deep bass with high acoustic efficiency and low distortion.
      Gain Control: The subwoofer has a rotary control on the rear panel for adjusting the level of the bass.
      Phase Switch: The subwoofer's phase switch allows you to control the phase of the subwoofer's output relative to the front speakers. If the bass sounds muddy or unclear, toggling the phase control can sometimes strengthen the bass "attack."
      Auto On/Off Circuit: The auto on/off circuit turns the power amp on when a signal is sensed and turns the amplifier off and into standby mode approximately 10 minutes after a signal is no longer received. An LED indicator on the rear panel glows green when the amplifier is on and red when the amp is in standby.
      Low-Pass Crossover: The subwoofer features a continuously variable 50Hz-150Hz low-pass crossover that determines the highest frequency at which the subwoofer reproduces sounds. The crossover has a 24dB/octave slope.
      Inputs and Outputs Notes
      Line-level Inputs: The subwoofer has a gold-plated LFE input and gold-plated stereo RCA inputs. If you have a Dolby Digital/DTS receiver or processor with a low-frequency-effects (LFE) output, you should use the LFE input on the subwoofer. If your receiver/processor does not contain a Dolby Digital or DTS processor but has a subwoofer output, you must use the stereo RCA inputs. If the receiver/processor has a mono subwoofer output, a "Y" adapter is recommended to maximize performance.
      Speaker-level Inputs: The left and right gold-plated 5-way binding posts allow you to connect the subwoofer to a receiver/amplifier using speaker wire.
    • By olegau
      Price: 180
      Item Condition: good working order
      Features and Specs
      Video Shielded   No
      Wireless    No
      Phase Switch     Yes
      DIMENSIONS & WEIGHT
      Width 10.6 in
      Depth 16.8 in
      Height 17.5 in
      Weight 33.07 lbs
      Features
    • By Lincolnbl
      Items:
      Mission M73i Floorstanding speakers (in Beech colour)
      Mission MC72 Center Channel (in Charcoal)
      Mission M70 Surround Speakers (in Charcoal colour)
      Velodyne CHT12R Subwoofer
      Yamaha RXV3800 AV Receiver
      All items have been well cared for. Never abused. Non-smoking house.
      Price: $950 $750
      Item Condition: Used. Well looked after.
      Reason for selling: Upgrade time.
      Extra Info: Selling as a set at this stage. But if interested in individual components reply indicating your interest and will consider a split if most stuff goes.
    • By Neilsy
      Item:  Velodyne Digital Drive 18 Subwoofer -- Black
      Price: $2,500 PayPal / $2,350 BT/Cash/cleared
      Item Condition: Excellent
      Reason for selling:   No longer in use, taking up floor space.
      Extra Info:    Selling my gloss black Velodyne DD18. Excellent condition as stated, everything working per new and includes remote, manual, the accessories kit and everything in it. Wear and tear on the mic clip which is normal. Comes packed in original Velodyne packaging and box.
      PM if interested in multiple units, per last picture.
