daoki
Add more speakers lose power ?
7 hours ago, daoki said:
Here are pictures of behind my power amplifier is it possible to do and how ?
https://www.canuckaudiomart.com/details/649315113-yamaha-pc2002m-2-channel-amplifier/images/1383908/
Nope, it is not possible for two reasons:
1) Channel A and B refers to left and right. Since the amp is a pro model, left and right are not the usual conventions used, but it simply means Channel A = Right and Channel B = Left.
2) Your amplifier has a minimum rated impedance of 8 Ohms. If you try to connect two pairs of 8 Ohm speakers, then the connected impedance will be 8X8/(8+8) = 4 Ohms. Your amplifier could be damaged by a 4 Ohm load.
7 hours ago, Sub Sonic said:
Might need to correct this Dave (my italics)😉
Oh, right - I see my grammar error.
EDIT:  I had also misunderstood how they were hooked up - they're parallel (I had thought series).
We also didn't know the amplifier was only designed to drive above 8 ohm loads.....  so I think we need to walk this back a little bit, sorry.
On 06/12/2018 at 3:22 AM, daoki said:
What will happen if I set them up like that ?
Ignore most of my previous advice.
Don't hook them up like you have.    You amplifier isn't rated for the extra load .... and even if it was, like I said before - these cubes are going to be swamped by the bass frequencies, and it will likely hurt their cones (no smoke fro the speaker, but torn cones and bad sound).
Edited by davewantsmoore
