noddou
Teac A-2340r Switch
Hi Everyone
I'm seeking a power switch for a Teac A-2340r
any assistance appreciated
Wagner have an excellent range of switches. It is unlikely that they have the precise switch you require, but you should be able to find one that is close:
https://www.wagneronline.com.au/swp656/ps/
That is one example. Wagner have many more. All have plastic shafts though, so you will need to modify the button.
This switch at Altronics might be suitable, the specs say 250V:  https://www.altronics.com.au/p/s1511-salecom-dpdt-alternate-pcb-chassis-mount-pushbutton-switch/
When I bought one it was located in a different area to the other switches.  They also have a button to fit over then end (from memory it's square), and that was located elesewhere in the store even though it only fits this switch.  If you go to the store ask for assistance immediately and you won't waste the amount of time I did trying to find it myself.  Of course, it may be easy to locate in another of their stores.
Good luck with the repairs.
