Volume controling and noise
Hi Guys
I am using a pre-pro and a Yamaha AV receiver to power 5 channles.
Which unit should be used for controlling the volume ( I am presuming the pre-pro ) and that's how I have always done it. Besides I don't want to use the remote for the old Yamaha amp to control volume.
So the way I have it is default volume level 40/100 on the pre-pro and -1db on the Yamaha amp  ( that's pretty much full power ). Is this a normal way to setup? Or should I use only 50-75% power on the amplifier ? I don't like using the pre-pro at numbers into the 70's and 80's to get to my level though, it's just the way my mind works, feels like it lacks power.
The problem I have is introduced noise. When on 5.1 input I get audible low level noise in the speakers. If I turn the pre-pro to OFF the noise goes away. So is this normal when running the amp at -1 db .? It's in all speakers, I don't think there is an issue with the interconnects.
Link to comment
If you drop the volume on the RXV1, is the noise still there?  Also, try unplugging connections on the Integra, maybe noise coming from one of attached components.
FYI, this is posted on wrong Forum, which discusses 2ch stereo !
Link to comment
No, If I take it to 80% ( -20 db ) I cant hear any noise.
I guess that answers my question. I have to use higher levels on the Integra. I don't really understand the setting for absolute or relative in the menu for volume level.
Link to comment
There is some noise coming from the Integra which is being amplified by the Yamaha at high volume.  It is likely to be coming from one of your components attached to the Integra.
Maybe this will hep:
https://www.soundandvision.com/content/‘relative’-vs-‘absolute’-volume-what’s-difference
Link to comment
The noise was regardless of selected input
Ive just decided to use -20 and increase the Integra.
Thanks for the help and link, will read up on it.
Link to comment
In regards to reference level at 0 db ( using relative ) , how does this take into account the volume of the amp connected to it? It doesn't ? If I am at 80% on power amp then my reference level 0 db on pre amp is really not that at all , unless I use 100% power on the amp?
Edited by shueardm1
Link to comment
Noise may be coming from a component, a cable regardless of selected input. The only way to test is to disconnect the component.
It cannot take into account both units. The only way is to measure using a calibrated microphone, and noting settings on both units.  But why is it so important to know the actual level?
Link to comment
9 minutes ago, shueardm1 said:
I removed all connected components and it changed nothing.
You may have a ground loop or your Integra is noisy. Have a look at this article to determine whether it is a ground loop
https://www.techhive.com/article/3063590/home-audio/how-to-get-rid-of-hum-and-eliminate-other-noises-from-your-audio-and-video-systems.amp.html
Link to comment
To Top
