Paul R
FM Tuners - ABC Classic FM
Listening to Mahler on Classic FM, ABC at the moment.
One can easily forget how good a decent analogue tuner can sound with a decent aerial.
I cannot compare this with the digital equivalent as I don't have a digital radio tuner in the main system. In the car, yes, digital trumps FM.
All I can say is that the old Pioneer TX-9800 is a fine sounding tuner, bearing in mind I've not compared it against the top tuners from Sansui, Yamaha, or Kenwood/Trio!
Paul R
Yes, I get excellent sound from ABC FM using my TV antenna (an older, large type that still covers the VHF band).
I find that to be the case when in a fringe reception area. The digital audio signal is noise-free.
In a good signal strength area I find I prefer the sound of ABC FM from a car radio FM tuner, over the sound from a car radio DAB+ tuner. I find the DAB+  sound a bit bland.
The bitrate for the HE-AAC codec used for the digital audio, isn't all that high. The nominal bitrate for the ABC FM DAB+ service is 80kbps.  In practice the bitrate available for the audio is somewhat lower than that because of the need for redundant data to be included in the DAB+ broadcast stream to facilitate error correction in the receiver. Also, there needs to be an allowance for other data (mainly for small slides displaying text and graphics).
Edited by MLXXX
I’ve got a lovely TX 9500 that I’d love to use but being in East Gippsland, I find it hard to get a nice clean signal. Would connecting it up to my (unused) TV antenna be the way to go?
It should work quite well, um.  :thumb:  Not as well as an FM antennae - but I would think, good enough.
(But don't have the antennae plugged into anything else.)
As long as it's not a UHF only antenna. FM broadcast is close enough to the old VHF TV antenna specs to make it work pretty well.
If you refer back to my post re: Rotel RT-624, my father used this tuner and built his own high gain FM antennas. He was getting good reception from regional stations 100's of km's away. It's also important to have a rotatable antenna if you're wanting to pick up stations situated in different directions.
 FM DXing (long range FM reception)
http://brisbanefmdx.com/antennas_39.html
http://home.iprimus.com.au/toddemslie/Korner-15-11-FM-yagi.html
Good info @Ian McP, thanks for that.  I have to do something to improve my FM reception...what I've got now is not really cutting it, although it is a good start.  Would be lovely to talk to someone that knows this stuff but the antenna guys I talked to only know tv reception and were little help at all.
Enjoying my Scott tuner
listening to ABC FM but should also get around to organizing a dedicated antenna. IMG_3669.jpg
