Gieseler Audio
Power supply upgrade for Gross, Fein & Klein III DAC’s.
On 30/11/2018 at 9:30 AM, Gieseler Audio said:
Well I have just done another critical comparison of the Gross using
1. std supplied 9v plugpack transformer.
2. Kraftwerk M18PSU 12v 4A unit.
3. All Silmic version of the Kraftwerk now with 100+ hours run in on the Silmic's.
With out a doubt the std Kraftwerk unit is clearly the best sounding & not by a small margin.
I did this test first thing in the morning so I was nice & relaxed & focused.
I just thought I would post this so anyone considering a PSU upgrade can be assured that currently my best sounding PSU is the Kraftwerk M18PSU 12v 4A unit.
Note & can also supply it with a 9v output.
Hi Clay,
are you planning to do Kraftwerk as 14 v? I think you said before that 14v was preferable for the Gross dacs?
Hi Russ,
I did compare the sound at 12v, 14v & 15v but in the end 12v seemed fractionaly better so I'm sticking with that.
Edited by Gieseler Audio
1 hour ago, Gieseler Audio said:
Hi Russ,
I did compare the sound at 12v, 14v & 15v but in the end 12v seemed fractional better so I'm sticking with that.
Thanks Clay.
i’ll be ordering one soon
Hi Clay,
I do not want to be picky but when you feed with 9VAC you get 12,7VDC so 13VDC maybe worth a try as well.
ATB
Matt
Edited by matth
Yes good point Matt.
I actually measured the DC output of the main supply for the analogue section in the Gross when powered by the normal 9v external transformer & it was about 13.65v. Based on that & allowing for the diode drop in the bridge rectifier I thought between 14v to 15v dc in would give the same final dc voltage. Well 14.3 v dc in gave me the equivalent final voltage that the 9v AC transformer produced however with listening tests 12v dc in worked out to be the sweet spot. All the lead pre regulators in the Gross have an output of 8v & drop about 2v so 10v or more on the input side is enough for them to regulate. At the end of the day it is all about the sound quality & 12v dc in just sounded the best. The DAC runs slightly cooler with the 12v dc supply too so that is a bonus. I have carefully monitored all the internal DAC, Amanero & S/PDIF voltage rails with 12v dc in & they are all spot on & rock solid so I’m happy with that.
Well Gents, i've been running the new 12v 4a - standard Kraftwerk LPSU in for nearly 40 hours since i got it  on Monday evening but i didnt do any listening until yesterday evening    Let it be known that i've only recently transacted with Clay, getting a Klein III dac 2 weeks ago and now the Kraftwerk LPSU and had no affiliation nor heard of any Giseler products prior.
Packaging & Service
Cant fault with either, it arrived real fast, and was packed really well.  Build quality superb, the connectors fit snug and it even has plastic locking cover to prevent the LPSU cable from being accidentally disconnected.  The external EI transformer was quite heavy (bonus!)
Sound
Let me say that the stock standard PSU that Clay provides is not in any way inadequate for running the Klein III to its fullest.  I could easily live with it and wouldn't have known any better until all that ruckus came up on running a DC LPSU to the Klein III.  So what improvements did I notice with the upgrade you ask?  The sound took a step forward, it sounded bolder, highs and mids slightly more refined, bass was much deeper.  What i really noticed more so was the layering of the music was much better, which enhanced the depth and stage of the song.
Its always hard to put an actual equation or means to substantiate what I heard accurately, but if I were to take a stab at it, its like squeezing out that last 10% performance from the Klein III.  Is it a necessity? No, and thankfully its an upgrade path that is offered should funds or the option to do so permits.
Sorry Clay, as much as you've kindly offered the option to return the Kraftwerk LPSU back to you, i dont think its gonna be coming your way.
If you have a Fein DAC, don't stop and think about buying a Gieseler Kraftwerk power supply. Order it NOW - your ears will thank you!
Takes it up level or two and makes the DAC a killer at the price.
Have a look at my review...
Clay, you might want to remove this from the listing on the website.
‘Not compatible or required with other Gieseler products.’
New production bench (& staff) added to cope with all the new Kraftwerk M18 PSU orders
The notes show the missing parts required for completion - I have a ton of parts coming in Friday/Monday so hopefully we will fill back orders &  actually have finished units in stock
early next week.
Guest DarkNark
I am getting confused here. 🙄
The standard version is better than the upgraded "Silmic II" version?
What’s with the microwave Clay? Going to burn in units before sending them out?! Hahaha.... ok bad dad joke [emoji4]
He only has time for working lunches with all these Kraftwerk orders coming through! I know, another dad joke...
 I understand that this is the recommended one by Clay:   Kraftwerk M18PSU 12v 4A.
Not the Silmic version.
Edited by buddyev
Actually it is a Breville pro convection oven which is modified slightly with our custom arduino controller & now doing
reflow soldering duties . The surface mount components of Klein III’s are all reflowed in it. It was a bit of a learning curve to
start with but all sorted now.
Guest DarkNark
That was my understanding. The $375 version is better than the $500 version. :P
@Gieseler Audio Clay can you put me down for ..................
Edited by DarkNark
Awesome work Clay!
I am thoroughly enjoying the boost in performance the new Kraftwerk psu adds to my Gross.
I will have to give it some more time to run in but initial impressions are very positive. Thanks mate 👌
11 hours ago, DarkNark said:
Well at least you get some honesty from the designer/manufacturer.
Guest DarkNark
Absolutely 👍
I didn't mean to insinuate otherwise.
I think the opening post needs to be edited. Rather than have to read the whole thread to find out the experiment didn't quite live up to expectations. As I said, I started to get a bit confused what model we were talking about.
Sorry guys - yes it is a bit confusing.
I was totally expecting the Silmic one to sound better but I was wrong.
In future I will wait until I've actually heard new designs before posting.
Guest DarkNark
10 minutes ago, Gieseler Audio said:
Sorry guys
No need to apologise. It was interesting to read along even though it didn't work as planned. Just goes to show, to me at least, how much effort and testing goes on "behind" the scenes.
Disregard my comments, I am easily confused. :)
Actually,  this level of transparency with trying things is likely to be good for business as it likely inspires confidence in those who haven't done business with you yet. It's nice to see a manufacturer actually promote the better sounding gear rather than just what costs more as so often happens with audio gear.
I'd encourage you to continue along these lines :)
We all live and learn - but half the fun is in the journey itself
