dreamz
WITHDRAWN OR RELISTED: FS: Paradigm Studio ADP590 Adaptive Dipole Surround Speakers
Item: Paradigm Studio ADP590 Adaptive Dipole Surround Speaker Pair
Price: $1100 less than 60% of RRP $2999
Item Condition: See Photos
Payment Method: Pickup/Post - Cash, Bank transfer, Paypal
Extra Info: Speakers sounds Excellent, no damage on any of the corns, one of the grill cloth damaged, one speaker got some cracks on the corner plastic, it wont be noticeable much once you mount it in the wall with the grills. check the photos, i tried to cover the best i can with every angle. i cant find the mounts, which you can order from audioactive if needed and wont cost much or just use any clamp you can get from bunnings.
No Box but happy to pack and shipped to anywhere in australia at the cost.
This item has been withdrawn from sale or relisted.
    • By krusto
      Item: Paradigm Monitor 10 Sub
      Price: $600 obo with donation of course
      Item Condition: NR MINT/MINT
      Reason for selling: NLR offloading my subs
      Extra Info:  Lightly used for music, very nice, smooth subwoofer. Incredibly small (sealed) cabinet. Not only awesome for musical applications, but deep and powerful enough for any home theatre enthusiast.
      Original box and accessories for safe delivery. Happy to courier if required.
      The amp and driver in this Monitor range are made in Canada, assembled in China.
      DESIGN Single driver, acoustic suspension, built-in advanced Ultra-Class-D™ amplifier, USB port for PBK?equalization, removable grille AMPLIFIER 900 watts Dynamic Peak; 300 watts RMS Sustained AMPLIFIER FEATURES Auto-on/off, soft clipping, thermal protection ROOM CORRECTION Anthem Room Correction (ARC®) (sold separately) LOW FREQUENCY DRIVER 254-mm (10 in) carbon-loaded polypropylene cone, Active Ridge (ART) Technology surround, 38-mm (1-1/2 in) 4-layer copper-clad aluminum voice coil. Nomex® spider, 4.5 lb ferrite magnet, AVS™ die-cast heatsink chassis FINISHES Black Ash WEIGHT 30 lbs. (13.6 kg) DIMENSIONS HXWXD 13" × 11.125" × 12.75" (33.0cm × 28.3cm × 32.4cm) LOW FREQUENCY EXTENSION 17 Hz (DIN) LOW PASS FILTER FREQUENCY Variable 35 Hz - 150 Hz; Bypass Option SUB / SAT PHASE ALIGNMENT Variable 0° - 180° INPUTS Two RCA (L/R-Mono) for L/R lineout or Sub-Out/LFE-Out of receiver/processor or other line-level source COMPATIBLE PRODUCTS PT-2 Wireless Transmitter (sold separately)
    • By krusto
      Item: Paradigm Monitor 10 SUB
      Price: $700
      Item Condition: Excellent/Mint
      Original box etc for safe delivery.
      DESIGN Single driver, acoustic suspension, built-in advanced Ultra-Class-D™ amplifier, USB port for PBK?equalization, removable grille AMPLIFIER 900 watts Dynamic Peak; 300 watts RMS Sustained AMPLIFIER FEATURES Auto-on/off, soft clipping, thermal protection ROOM CORRECTION Anthem Room Correction (ARC®) (sold separately) LOW FREQUENCY DRIVER 254-mm (10 in) carbon-loaded polypropylene cone, Active Ridge (ART) Technology surround, 38-mm (1-1/2 in) 4-layer copper-clad aluminum voice coil. Nomex® spider, 4.5 lb ferrite magnet, AVS™ die-cast heatsink chassis FINISHES Black Ash WEIGHT 30 lbs. (13.6 kg) DIMENSIONS HXWXD (33.0cm × 28.3cm × 32.4cm) LOW FREQUENCY EXTENSION 17 Hz (DIN) LOW PASS FILTER FREQUENCY Variable 35 Hz - 150 Hz; Bypass Option SUB / SAT PHASE ALIGNMENT Variable 0° - 180° INPUTS Two RCA (L/R-Mono) for L/R lineout or Sub-Out/LFE-Out of receiver/processor or other line-level source COMPATIBLE PRODUCTS PT-2 Wireless Transmitter (sold separately)
    • By Mironyousuf
      Hi All,
      I’m planning to buy a pair of surround speaker and a pair of Ceiling speaker.
      I have now Paradigm  Premier 800F front and Paradigm Premier 500C centre. For surround I have now pair B&W M1 speaker and ceiling I have pair of Canton 445. Subwoofer I’m using SVS SB3000. Amplifier I’m using Marantz SR6013.
      I’ve upgraded fronts centre subwoofer amplifier between 6months to a year ago. Now I’m ready to upgrade surround and ceiling speakers.
      I’m not sure if I must use paradigm surround and ceiling to complement my front and centre or should I go other brand with better crossover and better value.
      my budget $1000-$1500 for both surrounds and ceiling speaker.
      Thanks in advance for all suggestions.
    • By myryad
      Item: Paradigm Seismic 110 Subwoofer
      Price: $1700
      Item Condition: Excellent (Mint)
      Reason for selling: NLR - selling on behalf of family member
      Paradigm Seismic 110 Subwoofer purchased in April this year from a Sydney retailer. The sub is in mint condition as can be seen from the photos.
      The Sesimic 110 sub is an absolute beast. The small footprint can fool people but this thing can get very low and has amazing speed.
      It is a fantastic sub to use with a 2-channel music system due to its incredible agility and also perfectly suited to movies/home theatre duties as well, especially in small/medium sized rooms. The compact footprint also makes it great for dual sub setups.
      Significant saving from RRP on a sub that is only a few months old. It is also still under warranty.
      Full specs here: https://www.paradigm.com/en/sealed/seismic-110
    • By Keza_punk
      Item: Cambridge Audio azur 340r and 5.1 speaker setup.
      Price: 450
      Item Condition: All items as new condition.
      Every speaker works perfectly. AVR comes with remote control.
      Reason for selling: Change to 2.0 setup.
      Up for sale my music and ht setup.
      Sale incudes
      ****  4 star What HiFi review.
      1 x Cambridge Audio azur 340r receiver
      Very musical amp, perfect for music listening.
      ***** 5 star What HiFi review.
      2 x Cambridge Audio Siccoro s30 speakers
      2 x Mourdand Short speakers
      1 x Paradigm centre speaker
      1 x Cambridge Audio Active Subwoofer
      If you're after sound quality this setup will be perfect. Sound is crisp with plenty of details and low end.
      Demo and inspections welcome.
      Buy only if you're happy with sound quality.
