khoihuyen
FS: JPS lab Kaptovator power cable
Item: JPS labs Kaptovator power cable 2m with US plug
Price: $850
Item Condition: Very good
Reason for selling: NLR
    • By frednork
      Item: Fanless C.A.P.S. style music server w SOTM usb PCI card and  Gieseler triple linear power supply
      Price: $650 ono
      Item Condition: works well
      Extra Info:  This server with the SOTM usb card and the triple linear power supply rivals or betters commercial units that sell second/hand for 2 1/2 times the price of this. Very nice sounding unit which benefits from the SOTM card and LPS.   This is similar to a C.A.P.S. V3 server but at a higher level with an Asrock AD2700 motherboard with 2gb single sided ram and a 128GB ssd, a highly modified SOTM usb card and a Gielser triple linear  power supply.
      The SOTM usb card has been upgraded with better quality caps and a larger power supply cap. One of the usb ports has been disconnected to reduce unnecessary noise and the power connector has been modified to accept bare wire to allow direct power injection.
      The giesler power supply provides 2 x 12 v and 1 x 5v. One of the 12v outputs powers the motherboard and the remaining 2 power the SOTM usb card. The outputs on the supply are all adjustable should you decide to use it for another purpose in the future (see pic below).
      The unit is all connected up and can be demo'd or shipped as is ready to go. The SSD currently has a demo version of euphony OS on it but any system could be put on it.  The unit will run Roon  but wont be suitable for upsampling  but will do simple dsp or convolution.
      If anything the case is a bit ordinary and does its job but could be changed for any case that will take a mini-itx mb, the motherboard has its own passive heatsink and doesnt require a fan.
      I used this server as a very clean endpoint in a Roon setup. I will be listing my powerful fanless server used for upsampling and processing soon.
    • By davidSun
      Item: AT-LP5
      Price: 300
      Item Condition:excellent
      Reason for selling:upgraded
      Extra Info: Selling without headshell and cart
      ridge
      Ok
    • By Koalabear
      Item: T+A D10 Anniversary tube SACD player/transport/DAC
      Price: $4500
      Item Condition:MINT
      Reason for selling: Not using
      Extra Info: Limited T+A Aniversary SACD Tube Player/Transport /DAC
      Paid $14500 New
      Both the T+A V10 integrated tube amp and T+A D10 Digital transport and DAC are a very limited 25th Anniversary Products
      Both products are the kind of industrial design that ends up in a contemporary design museum. Its combination of compact symmetry, proportions, textures, and materials is exceptional for a piece of audio gear—stunning without being gaudy, dramatic and appealing without calling attention to itself. And they use tubes.
      The sound is neutral and dynamic with a wide soundstage.
      Bandwith adjustable.
      Filters Adjustable.
      Can be linked to the T+A V10 integrated amp and controlled remotely.
    • By Koalabear
      Item: T+A V10 Integrated Tube Amplifier Limited Anniversary
      Price: $4500
      Item Condition: Mint
      Reason for selling: Not using.  Bought new $14500
      The V10 uses a pair of Svetlana's new EL509/II power pentode tubes for each channel's output, two EC99 double triodes in the driver-phase-splitter section, and two ECL82 (6BM8) triode-pentodes in the input stage. All these tubes are mounted in the mesh towers on the top of the amplifier. The preamp section uses a pair of long-plate ECC83 (12AX7) tubes, these mounted horizontally inside the chassis.
      Power is 80 Watts per Channel sand tubes last about 5000 hours. All operating information, including remaining tube life, can be accessed via the front panel's LCD display.
      The sound is neutral and dynamic with a wide soundstage. The V10 can  easily drive the  Wilson Audio Specialties SASHA speakers to high SPLs without strain.
    • By Koalabear
      Item: STAX SR-009 ELECTROSTATIC HEADPHONES
      Price: $4200
      Item Condition:MINT
      Reason for selling: Thought I would use headphones but have limited time and although bought new just not listening with headphones
      Extra Info: STAX FLAGSHIP EARSPEAKERS Paid $6500 new
