blackangus Posted October 17, 2018 Share Posted October 17, 2018 I am giving away some Polymax Acoustic Panels. I bought them as 2400 x 1200 x 100 sheets, roughly cut them up and built some corner traps now measuring 2100 x 600 x 330 [two sheets thickness per trap]. They are covered with muslin/ticking and mounted on a basic frame. I'm giving them away because while they do make a difference, I need the space. They are not works of art, but if your room is white and doesn't have a significant other visiting very often, they're fine If you want them you will need a van/trailer/wagon, or you can pull them apart and take them away [this way you could fold the sheets if you need]. You could very easily make a number of smaller traps using these sheets. Pick up is in Coburg Vic 1 Link to comment Share on other sites More sharing options...
frednork Posted October 17, 2018 Share Posted October 17, 2018 yes please! 1 Link to comment Share on other sites More sharing options...
Dean Gale Posted October 17, 2018 Share Posted October 17, 2018 I'm to slow I need these. Link to comment Share on other sites More sharing options...
blackangus Posted October 17, 2018 Author Share Posted October 17, 2018 Gone! Thanks for the interest Link to comment Share on other sites More sharing options...
