Wifi vs USB
Hi there,
can someone please advise on the best way to send data from a Mac to a DAC (without USB input) using Roon?
I need to decide between a USB to SPDF converter and a relatively cheap wifi streamer (Sonos?) or even Airplay. I do not have any hi res file, only redbook.
Many thanks
Link to comment
Guest thathifiguy
Optical cable with 3.5mm adapter. They are dual purpose analog/toslink headphone output.
Edited by thathifiguy
Link to comment
16 hours ago, Ittaku said:
Is distance and cables a problem? What budget do you wish to spend on this? A simple USB to SPDIF converter such as the the Gustard U12 will give you the best quality for the price.
Budget: less than 300-400 dollars
Distance is not a problem. The Gustard loos good. Thanks for the tip. I wonder how is that superior to Airplay if you dont have hi res files?
Link to comment
can you  please clarify what you mean? I need to convert USB to SPDF or even toslink
Link to comment
It effectively will act as a mild decrapifier but mainly a de-jitter as well.
Link to comment
Lots of (all?) Macs have a combo 3.5mm jack that can output digital over mini-toslink. So a mini-toslink to toslink cable (or adapter and standard optical cable) may be all you need if your dac has optical input
Eg
https://www.cablechick.com.au/cables/2m-toslink-to-mini-toslink-35mm-optical-cable.html
Link to comment
Eg
uh! did not know that! thank you!
Link to comment
Guest thathifiguy
The headphone jack on the MacBook is both analog and digital toslink.
Link to comment
To the OP
A Mac normaly has
  • headphone out - which is also Toslink(optical) as others have posted.
  • usb out
  • possibly Firewire or Thunderbolt
The cheapest and most effective way is to use Toslink, but you may want to pursue possibly better alternatives like the Gustard, Audiophilleo, Singxer in the form of usb to spdif converters. After that there is a plethora of usb cables and other stuff that you can add to the chain to improve the music further (if you wish :) ).
Link to comment
  • 2 weeks later...
To Top
