Hendoferson 4 Posted October 10, 2018 Share Posted October 10, 2018 (edited) Hello Audiophiles Greetings! I hope you are all well. I was hoping to get some ideas and reccomendations for good speakers to match my amplifier : Cambridge Audio CXA60. I have a small room and the speakers will be relatively close to the wall with a little breathing room. Currently I wad thikining about the elac b6 or elac B6.2 however I am yet to audition these speakers. My budget is around $600 . Second hand speakers would be considered as well. I listen to funk and soul, electronic music, disco, rock etc. Cheers Edited October 10, 2018 by Hendoferson Link to post Share on other sites
Bunno77 1,558 Posted October 10, 2018 Share Posted October 10, 2018 I love the entry level Dynaudios on that amp. It's worth the extra investment for the emit 10s or the 2/6 come up for sale here from time to time within budget. Link to post Share on other sites
Irek 603 Posted October 10, 2018 Share Posted October 10, 2018 Hi, few people were recommending Richter to go with Cambridge audio amp. Link to post Share on other sites
Moderators alistairm 3,251 Posted October 10, 2018 Moderators Share Posted October 10, 2018 Many lovely bookshelf speakers, but in your price range - or just a touch above - you might pick up a pair of Proac Tablette 8s eventually, or something like this: Just more food for thought! 1 Link to post Share on other sites
flat_eric 8 Posted June 17, 2019 Share Posted June 17, 2019 Hi All I'm also in the same boat as OP, with a slightly bigger budget ($800-1200). I was originally considering the Klipsch RP600Ms, however after a trip to the local audio shop today the sales rep quickly disparaged that matching. So unless someone has a differing opinion, I'm now tossing up between the Dynaudio Emit 20s or the B&W 606s. I listened to the later with the CXA60 at the shop and it sounded great. Any advice is much appreciated. F_E Link to post Share on other sites
Spoctordock 40 Posted June 17, 2019 Share Posted June 17, 2019 I’m using a pair of epos epic 2’s on a cxa60 and I’m enjoying that combo. These speakers can be had for around $400at the moment. 1 Link to post Share on other sites
prakashsvce 0 Posted June 17, 2019 Share Posted June 17, 2019 B&W 606 makes good volume and sounds very neutral. If you can squeeze a bit, you can go for B&W 707. Great sounding speakers. You may get a good used 684 or CM series around $600-800. Link to post Share on other sites
Bunno77 1,558 Posted June 17, 2019 Share Posted June 17, 2019 6 hours ago, flat_eric said: Hi All I'm also in the same boat as OP, with a slightly bigger budget ($800-1200). I was originally considering the Klipsch RP600Ms, however after a trip to the local audio shop today the sales rep quickly disparaged that matching. So unless someone has a differing opinion, I'm now tossing up between the Dynaudio Emit 20s or the B&W 606s. I listened to the later with the CXA60 at the shop and it sounded great. Any advice is much appreciated. F_E Did you listen to the Klipsch? I prefer the Emit M10s to the M20s Link to post Share on other sites
allthumbs 1,036 Posted June 17, 2019 Share Posted June 17, 2019 I wouldn't recommend them without a listen but: https://www.aliexpress.com/item/Mistral-BOW-III-6-Ohms-60W-x-2-Hifi-Bookshelf-Speakers-Pair/32471824835.html 👍 Link to post Share on other sites
flat_eric 8 Posted June 18, 2019 Share Posted June 18, 2019 19 hours ago, Bunno77 said: Did you listen to the Klipsch? I prefer the Emit M10s to the M20s Nah I haven't had the chance yet - but I've heard some good things. Why do you prefer the M10s? They're pretty pint size so I'd worry about filling a larger room. Link to post Share on other sites
blakey72 1,491 Posted June 18, 2019 Share Posted June 18, 2019 The RP600M's are a lovely speaker. Don't take notice of the salesman. What I found with the Dyn's (well Excites) was that the X12's were smaller than the X14's however the 14's sounded slow and a little muddy. Same might apply to the Emit's? These would be my choice with the Cambridge 1 Link to post Share on other sites
wen 1,700 Posted June 18, 2019 Share Posted June 18, 2019 i would give Monitor Audio Bronze 2 a good listen, the Elac was compared to these in a review, said the Elac's were found wanting in terms of dynamics, i have the earlier BX2's, front ported so you can go close to the wall, 4 x 4.5 m room, 40wpc Quasimodo amp, they rival my MA RS6 floorstanders, can be had for $600 new, second hand the BX2 are a steal, they do come up secondhand on SNA Link to post Share on other sites
nowallet 45 Posted September 30, 2019 Share Posted September 30, 2019 @HendofersonWhat did you end up buying for your CXA60s? Mind sharing your thoughts if you're still around? Link to post Share on other sites
chewstation 12 Posted February 10 Share Posted February 10 why is the klipsch downrated as per the sales rep? i have a klipsch RP-600M and was thinking of going with a CXA60. I currently have an emotiva A-100 - no complaints however wondering if i could get more 'subjective' performance out of the cambridge? :\ Link to post Share on other sites
blakey72 1,491 Posted February 10 Share Posted February 10 1 hour ago, chewstation said: why is the klipsch downrated as per the sales rep? i have a klipsch RP-600M and was thinking of going with a CXA60. I currently have an emotiva A-100 - no complaints however wondering if i could get more 'subjective' performance out of the cambridge? 😕 No idea why the 600's would be downrated, they are a great sounding speaker. I know older Cambridge gear could sound a little on the bright side of neutral and Klipsch has a rep for being bright. The newer Klipsch however aren't as 'lively' as the older models and same with the Cambridge gear. If you are in Melbourne head to somewhere like Audiotrends and ask them to give you a demo of the pair. That will tell the true story Link to post Share on other sites
chewstation 12 Posted February 10 Share Posted February 10 Does the cxa60 fall into that category? (Of being bright) Link to post Share on other sites
nowallet 45 Posted February 10 Share Posted February 10 24 minutes ago, chewstation said: Does the cxa60 fall into that category? (Of being bright) I've heard some people say that; but to me they are neutral and well-balanced from low to high frequencies. Link to post Share on other sites
chewstation 12 Posted February 10 Share Posted February 10 Thinking upgrading from an emotiva a-100. Thoughts? Link to post Share on other sites
