SirRedNob
Amp recommendation for Paradigm Studio 60's
Hi guys,
I have a set of Paradigm Studio 60's - https://www.paradigm.com/products-archived/type=tower/model=studio-60/page=overview
They are currently being run through a Yamaha RV-V775 - https://usa.yamaha.com/products/audio_visual/av_receivers_amps/rx-v775/index.html
I basically use these exclusively for music, so I'm looking at getting away from the AVR and upgrading to (probably) a stereo integrated.
Preferences:
1. Stereo integrated. I really only want one unit.
2. Digital input (must have at least optical).
Budget: 2 - 4k
The speakers were only around $2200 from memory a few years back. I want a great sounding amp so willing to spend up to my max if it's worth it, however if that's more than they deserve 2-3k is fine.
Thanks in advance!
Try this.http://www.lenwallisaudio.com/products/amplifiers/integrated-amplifier/m5si
A superb sounding amplifier  and does everything you want and need.
I have one and it sounds beautifully balanced on a wide variety of speakers. IMO, it also represents superb value for money.
Thanks, I'll have a look at that one. Unfortunately it doesn't appear to have optical input though.
Consider Yamaha AS2100, there’s a used one in Gumtree for $1800.
I've done some research on the M5si you mentioned rantan - it does look great, except for the USB digital only which is a bummer. Not sure why they wouldn't put an optical on it.
Anyway it's on the shortlist while I keep looking. I'd rather not have to get a separate DAC for optical in if I can avoid.
Parasound HiNT6
http://www.parasound.com/hint6.php
Has all the features you asked for. You should be able to get close to your range in terms of pricing.
Also looks great but probably pushing it on price, will have a look around. Cheers
Yeah, you just missed out one in the classified. It was well under 4K. If buying new you should aim for 15-20% discount. Good luck hunting.
How about:
Denon PMA-1600NE
Simaudio Moon 240i
Hegel H90
Thanks roger - I'm leaning towards an original Halo Integrated (not Hint6). I can get one for 4k delivered - is that a reasonable deal? Was listed at 5.
Even though your speakers says it's impedance is at 8ohm. According to Stereophile, it can dip to 3.6 Ohm @ 185Hz. The Parasound should be okay IMHO. How it sound, that's entirely up to your ears.:)
"The Paradigm will play at satisfyingly high levels with relatively low-powered amplifiers. Its impedance (fig.1) remains between 5 and 8 ohms over most of the audioband, though a minimum magnitude of 3.6 ohms at 185Hz and a combination of 5 ohms and –37° electrical phase angle at 110Hz mean that the amplifier used should be capable of dealing with 4 ohm loads.
Read more at https://www.stereophile.com/content/paradigm-reference-studio-60-v5-loudspeaker-measurements#bTRKK7dKh7p4JGcr.99"
Thanks everyone for the help!
When I was looking around I spent quite a bit of time listening to the Cyrus Lyric and liked the sound of it for an all in one device. You can learn more about them here https://www.lifestylestore.com.au/catalogsearch/result/?q=+cyrus+lyric. They're a little outside your price range, but you might be able to score a good deal.
