Audionerd
FS: CABLE CLEAROUT:TRANSPARENT, VDH, MIT, NORDOST,NBS,PURIST,QED,GUTWIRE
Item:
Transparent Audio Musicwave Plus 3m pr Bi-wire Speaker Cable. SOLD!
MIT AVt1 10ft (3m+) pr Bi-wire Speaker Cable.  SOLD!
MIT AVt1 1m pr RCA. SOLD!
Van den Hul The Valley 1m pr XLR (3T triple balanced with hybrid screen). SOLD!
Nordost Frey 1m pr RCA. $550 (RRP~ $1099)
 NBS (US) Serpent III XLR 4ft pr. $370 (RRP~$1095)
NBS Serpent III XLR 6ft pr. $470 (RRP~$1375)
NBS Signature III 1m AES/EBU (XLR) Digital Cable. $550 (RRP~$1175)
Purist Audio Design Aqueous Aureus 1.5m SPDIF (Coaxial) Digital Cable. $600 (RRP~$1199)
QED Reference 0.6m USB (A-B) Cable. $140 (RRP $229)
Gutwire (Canada) G Clef (Red) 5ft Power Cable. $340 (RRP $795)
Gutwire C Clef (Black) 5ft Power Cable. SOLD!
Item Condition: Transparent has slight discolouration of the sheath, normal for used cable and may clean up; MIT, Nordost, NBS Digital, Purist and Gutwire are in good used condition;  NBS XLRs are as new in bags; VDH & QED are brand new in box.
Reason for selling: Upgraded
Payment Method: Cash, Bank Transfer or Paypal
Extra Info: Both Speaker cables are factory terminated with banana plugs; MIT employ patented "Multiple Network Technology"; MIT and Nordost use WBT locking RCA plugs; VDH, Purist and NBS use their own tight grip plugs; Gutwire IEC & AUS mains plugs are ultra heavy duty
Edited by Audionerd
So much easier to read when the text/info is broken up by adding it above or below the appropriate pic when listing multiple items.
Not complaining, its your ad. Just a suggestion.
I would have posted that way if the template allowed it.
If you'd be able to explain how the standard format is bypassed, I'd be happy to oblige in future.
Edited by Audionerd
I hope my edit helps😊
Hi joz
Thanks for the edit. The item list is certainly easier to read when vertical.
Is there any easy way to attach a description to individual photos when there is a multiple list?
Alrighty I’ve made spaces between each pic except one, I missed it.
but while your in edit mode if you touch the right side of each pic it will show the curser bar.
Once you’ve done that you can add as much space between pics as you’d like.
Or you can add text between the spaces.
Give it a crack once your happy I’ll delete any of these unneeded posts.
Thanks for your help, but I can't get it to work.
Must be doing something wrong.
Hi there, I will take the VDH thanks if you will post to Adelaide.
    • By Muzza71
      Item:  Tauris Georgia HiFi Stand 4 Tier Shelf Tempered Glass
      Price: $100
      Item Condition: Very Good
      Reason for selling: NLR
      Some light swirl marks and scratches but nothing to obvious.
      750mm Height 650 Depth 500mm Wide
      470mm between inside posts
      450mm deep to rear frame.
      245mm bottom shelf height
      200mm middle shelf height
      210mm top shelf height
      Shelves be can interchanged.
      The rear frame has been opened up to accommodate different terminal positions on amplifiers and source components on 2 shelves.
      The bottom shelf has 6mm rubber sandwiched between two perspex glass plates to assist with sound absorbsion/isolation.
      Bottom shelf weight limit 45kg, other shelves 25kg.
    • By Muzza71
      Item: Speaker Stands 735mm High - Tempered Glass
      Price: $50
      These can be filled with your preferred sound deadener/Absorber.
      735mm high including spikes, perfect for smallerish bookshelves around 300mm in height
      Top plate D 180mm x W 150mm x 8mm thick
      Bottom plate D 300mm x W 220mm x 8mm thick
    • By bdavis84
      Item: KRIX Phoenix Floorstanding Speakers
      Price: $600
      Item Condition: Like New
      Reason for selling: Downscaling
      Extra Info: 2 small holes in one of the speaker mesh. Otherwise great condition. Barely used over the past 7 years. Also includes quad braided speaker wire valued at $25 pm.
    • By bdavis84
      Item: KRIX Concentrix Centre Speaker
      Price: $220
      Extra Info: Great Australian made centre speaker. Barely used over the past 5 years.
    • By bdavis84
      Price: $220
