awayward
SOLD: FS: Lenehan Ribbon Flex RCA interconnects 1m - 2 pairs
Item: Lenehan Ribbon Flex RCA interconnects 1m - 2 pairs
Price: $300 for both pairs, plus freight costs if required
Item Condition: Excellent
Reason for selling: Surplus
Edited by awayward
Hi
Are the lenehan cables still for sale?  How would you characterise the sound - I have a slightly bright system so I would prefer something on the darker side if possible?
Thank you
Lance
Still for sale, I would categorise these cables as neutral or accurate, producing what is playing.
Edited by awayward
Bump, nice cables that I would like to go to a good home 👍
$100 price drop, now $300.
    • By Gabehcuod
      Item: Focal Clear + Questyle CMA400i + Questyle stand + 1.2m aurealis 24 gauge litz xlr cable + matching XLR to 2.5m adaptor + 5m audioquest evergreen USB cable.
      Price: $2200 AUD + $100 for postage and paypal fees if delivery needed
      Item Condition: 9/10 - Pads a tiny bit darker than stock but have been regularly cleaned.
      Reason for selling: Introduced to Vintage Stax
      The focal clear was originally purchased 24/05/19 (invoice available at request). Both drivers were replaced in the focal clear on 19/10/19 due to rattling in the left driver when playing tracks with low frequency content (rma and image of box available at request). Questyle CMA400i originally purchased 26/08/19 from minidisc (invoice available at request). Questyle Stand originally purchased 14/10/19 from minidisc (invoice available at request). Aurealis cable (UPOCC copper Litz 24 awg. Amphenol 3.5 mm TRS at headphone end, Amphenol 4-pin XLR (AX4M) at source end) Originally Purchased 25/10/19 Aurealis xlr adaptor  (UPOCC copper Litz 24 awg with matching amphenol xlr connector) purchased some time after the regular xlr cable. Invoice unavailable. Audioquest USB cable was purchased soon after the Questyle CMA400i. The Questyle did not come with a stock USB cable.
      The focal clears have a nice sound-stage. Not artificially wide like the HD800, but not narrow either. It has a laid back and relaxed sound that you can listen to for hours without being fatigued.
      They are quite easy to drive which makes them quite portable, easily runs off a DAP.
      The sound is quite spectacular in this pairing. I spent quite some time demo'ing various amplifiers at minidisc before settling with the CMA400i.
      It has a very beautiful and emotional sound to it, easily driving the clears with its Current mode tech.
      Please note, all three of the stock cables broke with audio missing from one channel. Reading online, this was a very common occurrence and frankly the stock cables were extremely irritating to use in the first place.
      New value of this package is $2200 + $1300 + $100 + $355 + $85 + $140 = $4280
      Kind Regards,
    • By Eagleeyes
      Item: Lenehan Audio MLT3- 2018 models
      Price: $4200- Rrp approx 8500.
      Item Condition: 9-10
      Extra Info: Have boxes so can pack and send anywhere. Genuine Boxes say weight is 37 kilos each.
      https://www.lenehanaudio.com.au/ml3.html
      https://www.audiocircle.com/index.php?topic=95236.msg951583#msg951583
      The ML3 was designed with one specific goal in mind:
      Reproduce the input signal better than any Loudspeaker currently in production.
      The task is Herculean of course and we are very well aware of many other such attempts both present and in the past. What size room will this Loudspeaker be built for?
      There is no doubt that an 8inch two way will drive a room of reasonable dimensions only! We're talking here of around 140 cubic mtrs | 5000 cubic feet with dimensions approximately 6mtrs x 8mtrs x 3mtrs. This is certainly a decent size living room. Due mainly to it’s PRC Xover and bottom vent design, the ML3 will drive a room as small as 50 cubic mtrs | 1700 cubic feet with no bass boom whatsoever!
      OK, but how much energy can an 8 inch two way produce? I mean, will they have enough steam in the bass for me? After all sometimes when I’m in the mood I like to get into some Rage Against the Machine or Tool or even Faithless. But at the same time I mostly listen at moderate levels to Jazz and Classical music.
      ML3’s have, we believe; state of the art bass reproduction. Rock solid into the mid 20hz region, their speed articulation and detail in the lower frequencies is the foundation for the rest of the frequency range. The ML3 power handling is huge! mainly because of the immense high power understressed Xover.
      We believe the ML3 is the closest thing to the universal Holy Grail of balanced high end design that is possible to currently achieve. In a room of approximately 130 cubic mtrs or 4500sq ft the ML3 will play flat to near 25hz in the listening chair! And no it won't boom in the bass and be impossible to set up like many others. You won't for instance have to set them up 6ft into the room to get a decent balance.
      In respect of imaging and soundstage depth the ML3's will throttle your senses. In our test room with the ML3’s set up 75cm (2.5ft) off the front wall and 2.75mtrs apart with a listening distance of 3.2mtrs image width is at least 2mtrs wider than the loudspeakers with 3 dimensional soundstage that goes back through the wall!! Belafonte live at Carnegie hall for instance is simply huge with tremendous image and dimensional stability. Detail within the soundstage we believe is currently SOTA (state of the art). Speed, bass slam and transient abilities are also currently at the leading edge of moving coil loudspeaker design.
      The reasons for the ML3’s intrinsic superiority are many, but the unique and world's first acoustical foam baffle design probably heads the list. This baffle makes the enclosure of the ML3's ostensibly invisible to the low and high frequency drivers. Try this: put your hands around your mouth like your going to yell at someone 200mtrs down the road, but flatten them out so they don’t cup like a cone. OK, now turn to someone and recite a simple phrase, then take your hand away and recite the same phrase. The difference in the sound of your voice is of course amazing . You were listening to distortion of course and it’s obvious; Yes? That’s why all speakers with baffles of any sort are inferior.
      ML3’s bass loading is proprietary, the port is huge and under stressed so that at high sound pressure levels it still supports the bass driver, in fact it’s close to linear at all drive inputs. Rock solid extended bass that does not produce a grungy type of incoherent bloom underneath the mid’s and high’s. The corollary here is phenomenal transparency that hitherto has only been the province of the best full range electrostatics but with punch weight and authority that the former has simply never been capable of.
      As with all the ML series the Xover is hand built and hardwired. After run in each Xover is handtuned to each host loudspeaker in front of a measurement microphone to a virtually zero tolerance. Each Xover is subtly different to every other ML Xover because each Loudspeaker itself is an individual unto itself. The end result though is imaging and soundstaging perfection.
      These Loudspeakers can pull off the ultimate disappearing act, no doubt.
    • By Arv
      Item: Lenehan RibbonFlex RCA Interconnects 1M x 2
      Price: $200 per pair + delivery
      Item Condition: Excellent - Used
      Reason for selling: NLR
      Payment Method: Pickup - Cash, Paypal (as a friend or + 2.7%), COD Only
      Fantastic RCA interconnect cables from Mike Lenehan. Plenty of feedback on the forums. I have 2 pairs for sale.
      Recently purchased from pair from SNA and the other directly from Mike. One will be shipped with the original box and the other pair will be shipped in a curious cable box.
    • By WagonWheel
      Item: Audioquest Midnight Plus speaker cables 1.8M
      Price: $180
      Item Condition: very good
      Reason for selling: No longer required
      Audioquest solid copper cables, very nice sounding. Moved to an active system so they’re no longer needed.
