kffern
FS: Toroidy Supreme 1200VA 2 x 65V Transformer
Item:  Toroidy Supreme 1200VA 2 x 65V Transformer (230V)
Price: 250 plus shipping (negotiable)
Item Condition: Used
Reason for selling: Replaced with 2000 VA transformer from Toroidy
Payment Method: Pickup - Cash, Paypal, COD, will post
I got this toroid with an DIY Holton HPA-NVL800 Stereo amp I bought via Stereonet. I used it with my Kings Electrostatics (early pair circa 2009) and it worked beautifully. So good that I reinstalled the crossovers and ran it with the one amp and it sounded better than it ever did DSP bi-amped with a Bryston 4B ST and a Panasonic Pro amp . However, with the 2 ohm load of the Stats, I wasn’t sure if I was getting all that the amp could give, so I bought a 2000 VA Audio grade toroid from Toroidy and replaced it. Saying that, the amp barely got warm even after running all day. It ran absolutely silent as well. Now I can understand what the reviews of the Kings were talking about.
I don’t think I gained anything apart from a slight bit of transformer hum but will keep it as I have already gone down that route. If I had an 8 or 4 ohm speaker I would be quite comfortable keeping it.
A new 1200 VA Supreme transformer will cost you over AUD 600. This doesn't include the mounting plate and bolt which I have included. I estimate shipping around $60 to the east.
https://sklep.toroidy.pl/en_US/p/TTSAS1200-SUPREME-AUDIO-grade-transformer-TSAS1200VA-voltage-from-55-to-100-V/425
https://www.diyaudio.com/forums/holton-precision-audio/324517-nxl800-amp.html
https://www.diyaudio.com/forums/holton-precision-audio/300643-nxl800-amp-build.html
ELECTRICAL DISCLAIMER
This product has not been manufactured by a qualified individual or company, therefore contains electrical circuits that do not necessarily comply with Australian Standards. I understand that as the seller, I may be liable to repercussions in the event of equipment failure. By advertising and selling this product, as the seller I also agree that I am solely liable, and the publisher of this website takes no responsibility for any injury or death resulting from, whether directly or indirectly, any accident that may happen as a result of the failure of the product being sold. If in doubt, seek the services of a qualified electrician to inspect the product to ensure it is safe for use.
Edited by kffern
    • By s4turn
      Item:
      Pricing in Australian dollars
      Scanspeak Revelator 12m 4631 - $400 /pr - pending sale
      Scanspeak Revelator 18w 8531 - $350 /pr - on hold
      ScanSpeak Illuminator D2004 / 6020-00 $150 /pr - on hold
      higher res photos of 12m's and 18w's
      https://photos.app.goo.gl/15qrZu7YEY6yM2UC7
      Shipping to be calculated
      Price: $900 + shipping
      Item Condition: used
      Reason for selling:
      Payment Method: Pickup Cash or Bank transfer, Paypal
    • By Darkstar
      Item: Melody 300B Mono Power Amplifier
      Price: 3000
      Item Condition: 8.5/10
      Reason for selling: Surplus
      This Melody 300B Push Pull amplifier is 2 mono blocks of 28W each.
      It is a high-quality construction and finishing with high end components (Howland, Duelund, Nichicon, ...) wired up, no PCB.
      From a sonic point of view it provides a clear and neutral restitution.
      It can drive without problem speakers from 87 dB (high standby current and good hold of bass)
      The supply stage is extremely reliable, bias and automatic timer with gradual rise of the high voltage.
      A lot of time and money was invested in tube rolling to get the right synergy out of the amplifier with the right tubes.
      Original valves have been replaced with Full Music 300B and Sylvania 6SN7 NOS. Over $600 worth of tubes there alone.
      Amplifier is in excellent condition for its age and presents itself beautifully in its deep piano black chassis.
      Will come with its original double boxes and manuals. Inspection and sound will not disappoint.
      It is a 230V/240V - 50 Hz model
      Specifications :
      2 x 28 W AB1 class
      Tubes by block : 300B x 2, 6SN7 x 2
      inputs on RCA or XLR with selective switch
      HP 4 and 8 ohms
      Frequency response : 20 Hz ~ 30 kHz
      Input Sensitivity : 800 mV
      S/B ratio : ≥ 88 dB
      Harmonic distortion : 1 %
      Dimensions (mm) : 480 (l) x 215 (h) x 290 (p) mm
      Weight : 21 kg each
    • By Darkstar
      Item: Melody H34 Signature Integrated Amplifier
      Price: $1800
      Item Condition: 9/10
       This is my very first amplifier into the world of tubes and valves. A lot of time and money was invested in tube rolling to get the right synergy out of the amplifier with the right tubes. Original valves have been replaced with Mullard reissue El34, Mullard 5AR4, Brimar 6SL7 and Ken Rad 6SN7. Over $600 worth of tubes there alone. Amplifier is in excellent condition for its age and presents itself beautifully in its deep piano black chassis. Will come with its original double boxes and manuals. Inspection and sound will not disappoint.
      Extract from the internet
      MELODY H34s ASTRO BLACK Favorite tube of many music lovers is the EL34 which excels at tone. The tonality of the EL34 makes it also popular with musicians using stringed instruments, especially guitars. The most popular amplifier in the Melody range and winner of many awards the Melody H34 Signature offers fantastic sound quality at a price that seems unbelievable. With a full size chassis in piano black finish and retro styling it is a statement product in quality and style. The 25mm thick front panel contains three large solid aluminum knobs which control power on/off, volume and four RCA inputs. The volume knob controls a stepped resistor array with 24 positions. This ensures precise channel matching and maximum sound fidelity. The power tubes are four EL34 which deliver 40 watts of effortless power. This allows it to drive a wide range of loudspeakers with ease. The input and driver tubes are 6SN7/6SL7 and the amplifier has full tube rectification provided by the 5AR4 tubes. All the internal wiring is done by hand point to point with no circuit boards at all. This is the traditional way to build a long lasting amplifier with maximum sound qualities. It permits easy servicing and parts replacement or upgrading which modern solid state circuits with surface mount devices to not allow. At the rear are three oversized and shielded transformers with a power transformer in the centre and an output transformer either side for the left and right channels. Melody’s know how has delivered an amplifier that is powerful, delicate and with a depth of tone that makes it very beguiling. This amplifier can be muscular at one minute yet delicate the next, extracting minute details from the music. The sound stage is wide and deep and the bass is extremely realistic. The bass however is not dry or truncated, like many transistor amplifiers. It delivers information in the bass registers with plenty of feeling. The H34 Signature is an amplifier that music lovers will enjoy, not only for its sound but for the unbeatable value it offers.
      Power Output: 2 x 45W
      Tubes: EL34 x 4, 6SN7 x 2, 6SL7 x 2, 5AR4 x 2
      Frequency Response: 20Hz–20kHz
      Input Impedance: 250 kOhms
      Output Impedance: 4 Ohms, 8 Ohms
      Input Sensitivity: 480mV
      Signal to noise: 90dB
      Harmonic Distortion: 1%
      Dimensions: 430 W x 215 H x 410 D mm
      Weight: 24 kg
    • By tcliffo1
      Item: Technics SL1000 MK2 Turntable
      Price: $1650  $1500
      Item Condition: Good
      Reason for selling: Too many turntables
      SH-10B3 (slight crack pictured, can be repaired)
      Custom Lid
      SH-10E Power Supply
      EPA 500 tonearm board
      SP10
    • By Matt99
      Item: Two Libratone Zipp 2 Wireless Speakers
      Price:  $600 plus shipping
      Item Condition: As New
      Reason for selling: No Longer Required
      I imported these myself from Amazon as they ticked all the boxes for my requirements:
      * Wifi and Bluetooth
      * Support AirPlay 2 and Spotify Connect
      * Work as a stereo pair
      * Battery powered (12 hour life)
      * Most important, they sound great
      Sound is very good, one on its own can fill up a medium sized room easily. As a stereo pair the imaging is surprisingly good and the sound is big. They have built in room correction which is quite effective.
      Multi-Room / Stereo pairing features work well, Airplay 2 support is solid, and so is Spotify Connect. We've been using them with Apple Music, Spotify and Roon for lossless streaming over Airplay. All work well. (They also have internet radio which I didn't use, and Tidal support which I found a bit flaky.) I also used them for a while as TV speakers with an Apple TV, which worked really well.
      They support Amazon Alexa, which I don't use so I haven't tried it.
      They are about 3 months old and in as-new condition. Due to some recent purchases they are no longer required (i.e. something had to go).
      They come packed in the original box with the original power adapters, and Australian adapters.
