Ants01
Thorens TD 125 paired with SME 3009 tonearm.
Hi All
Currently upgrading a Thorens TD 125. It is in mint condition with original TP 25 tonearm, but have read the SME 3009 tonearm (which was a config option when it was originally sold) is better if I want to use a modern, high compliance cartridge. Any advice appreciated. Thanks!
13 hours ago, Ants01 said:
Hi All
A high compliance cartridge (which generally means an MM cart) - modern or old - requires an arm with a low effective mass.  According to the Vinyl Engine arm data base, the 3009 Series 2 comes in 3 different effective weights:
  • 3009 Series 2 improved - 6.5gm (very low)
  • 3009 Series 2 S2 improved - 9.5gm (low-medium)
  • 3009 Series 2 - 12.5gm (medium)
Edited by andyr
and the Thorens arm is about 16 g, so yes, it would be better, but what cartridge were you thinking of using?
16g would make it too heavy.
I think that was the point of switching to the SME for high compliance carts, yes.
To clarify, I was saying it would be better to use the SME.
Edited by aussievintage
Pardon mate, missunderstood.
You quoted my post with your above answer … but you really need to ask the OP what cart he's intending to use.  :)
You are correct Andy!  :baby:
Hi There. Thinking of using an Ortofon 2M black - compliance rating is 20, so I'm aiming to find a 3009 Series 2 improved - 6.5gm. I think that combination should put me in a good resonance range. Does that sound right to you?
That'll give you 9 or 10Hz resonance.   Good.
Have you seen this page?    https://www.vinylengine.com/cartridge_resonance_evaluator.php?eff_mass=6.5&submit=Submit        Very handy
The Vinyl Engine "Cart Resonance Calculator" shows the 3009 Series 2 S2 improved - at 9.5gm eff weight - is good too.
S2 improved = removable headshell , effective mass 9.5grams
Series II Improved = fixed headshell, effective mass 6.5 grams
Very confusing from SME.
I have a 2M black on one here at home (Thorens 124 MK2) and it sounds pretty darn good.
Resonance calculations aside, I have had Shures, Ortofons, ATs, Stantons, and probably others I have forgotten, also different weighted headshells, on my SME 3009 arms (series II and improved), and all seem to work great.   It's a great versatile arm.
