findbuddha
Seeking recommendation for speaker cabinet maker (Bris/SE QLD)
I'm getting back on the DIY train but hoping to reduce the amount of actual DIY I have to do to achieve it.¬†ūüėā
I'm building a pair of floorstanding speakers and would like to find someone to build the boxes (and hopefully paint with Duratex) for me. Does anyone have any recommendations for cabinet makers in Bris/SE Qld? (Further afield is fine if they can ship and the price/quality is right)
Thanks!
Thanks!
Wood N You in Coopers Plains will cut all the panels for you
If you ask them to add biscuit cuts you can glue & assemble them yourself
They also supply the MDF or other material as well
Then take the cabinets to a local spray painter to finish
They have cut half a dozen of my speaker builds and a plinth for my turntable
59 minutes ago, Hatlesschimp said:
Are they full range speakers, 2 way, 3 way etc. What tweeters and woofers are you using?
Full range, 2.5 way vented tuned to ~40hz. All Faital Pro components: HF108R on STH100 horn, 12FH520 woofers. Components partly chosen based on specs/distortion etc, partly based on what I can get here in Aus for reasonable prices.
46 minutes ago, Full Range said:
Wood N You in Coopers PlainsÔĽŅ will cut all the panels for you¬†
Fantastic, thank you! They're actually quite convenient to my workplace. If I can't find a competitive price for a full build I'll go that way.
They also have a La Marzocco GS3 espresso machine in the office  (well they did the last time I visited)
