amdan
US power board
14 hours ago, rmpfyf said:
Try Gumtree! https://www.gumtree.com.au/s-server+power+board/k0
These look interesting - mega Elsafe boards at https://www.gumtree.com.au/s-ad/lansvale/other-electronics-computers/xmas-lights-power-boards-electrical-server-racks-computer-cabinet/1206376918! If you have the 15A supplies to drive 'em :)... though at the price he's asking you'd call out a sparkie, run dedicated RCD's and drop routes direct to earth with the change :P
Yep. They're the ones I use on my bench. VERY well built and cheap as chips. Gotta be around $500.00 worth. Those 15 Amp sockets are not cheap. All hand wired internally.
Nice catch.
Edited by Zaphod Beeblebrox
15 hours ago, HdB said:
Good info - thanks
Those Sydney Tools units, or similar, are available from Middy's, L & H, and indeed our local Bunnings - sometimes under the Arlec or  HPM name - I haven't seen any made as flat packs like the ubiquitous power strips but no doubt, they're probably available, complete with the RCD, etc, protections.
The reasons why I suggest that particular type of board, is because it uses a standard 3 pin outlet and is internally WIRED, rather than with several bent bits of brass. Most (all?) flat boards use the bent brass approach. I do not regard any (that I've pulled apart) highly at all. The only exception has been the Elsafe types, which use a different type of construction, where bits of bent brass are not used. All (that I have examined) use hard wired connections. They are far superior to all other types that I've seen.
Nice catch.
Props where due, you've been consistent on this. They're a solid product. $500 minus $39 buys a lot of sparkie time to reticulate properly :D
Haven't pulled apart a Cabac unit though they weigh a ton... any mileage here?
No need. Just get the sparkie to wire a couple of 10 Amp plugs to the ends. Of course, a couple of 15 Amp outlets would be a better, though inaudible, solution.
Quote
I haven't seen one. I'll look around. Do you have a link?
I'd call the sparkie over, put in two dedicated 20A RCDs, two good-quality 20A sockets and win forever on contact area, run the earths direct to stake and end the debate. Put a Thor DRM95 on one of the rails if feeling 'interesting' about it all. But sure, for a sub $50 argument running it to a 10A plug works too - would offer that depending how a home is wired that could run afoul of AS 3108 (table 6.1), max points, particularly if on a 16A breaker and a bunch of other considerations. Again, I'm not a sparkie, all should seek independent advice.
Cabac, https://www.cabac.com.au/products/data-and-av/server-racks-and-accessories/power-rails/power-rails/50155505, turn up on Kogan occasionally.
Agreed with all the above.
Quote
Oh, I know those things. I have a PR20V for my soak test/battery charging bench. Picked it up for $20.00 at the local markets. Had to beat the guy down. I would have paid much more. Very well constructed thing. Hand wired, of course. I love the way the sockets are spaced well apart. Brilliant. How much does Kogan move them for?
May have seen them for $60 or so once upon a time (10-outlet strip).
That's a good price for such a quality item.
There is also an Australian Rack company that makes their own certified power boards. They wave solder the outlets & current reset directly to a 16A double-sided PCB
Edited by Gee Emm
Link? (Interested).
