amdan
US power board
32 minutes ago, Zaphod Beeblebrox said:
Yep. They're the ones I use on my bench. VERY well built and cheap as chips. Gotta be around $500.00 worth. Those 15 Amp sockets are not cheap. All hand wired internally.
Nice catch.
Props where due, you've been consistent on this. They're a solid product. $500 minus $39 buys a lot of sparkie time to reticulate properly :D
Haven't pulled apart a Cabac unit though they weigh a ton... any mileage here?
No need. Just get the sparkie to wire a couple of 10 Amp plugs to the ends. Of course, a couple of 15 Amp outlets would be a better, though inaudible, solution.
Quote
I haven't seen one. I'll look around. Do you have a link?
Edited by Zaphod Beeblebrox
I'd call the sparkie over, put in two dedicated 20A RCDs, two good-quality 20A sockets and win forever on contact area, run the earths direct to stake and end the debate. Put a Thor DRM95 on one of the rails if feeling 'interesting' about it all. But sure, for a sub $50 argument running it to a 10A plug works too - would offer that depending how a home is wired that could run afoul of AS 3108 (table 6.1), max points, particularly if on a 16A breaker and a bunch of other considerations. Again, I'm not a sparkie, all should seek independent advice.
Cabac, https://www.cabac.com.au/products/data-and-av/server-racks-and-accessories/power-rails/power-rails/50155505, turn up on Kogan occasionally.
Agreed with all the above.
Quote
Oh, I know those things. I have a PR20V for my soak test/battery charging bench. Picked it up for $20.00 at the local markets. Had to beat the guy down. I would have paid much more. Very well constructed thing. Hand wired, of course. I love the way the sockets are spaced well apart. Brilliant. How much does Kogan move them for?
May have seen them for $60 or so once upon a time (10-outlet strip).
On 12/01/2019 at 11:03 AM, Zaphod Beeblebrox said:
The reasons why I suggest that particular type of board, is because it uses a standard 3 pin outlet and is internally WIRED, rather than with several bent bits of brass. Most (all?) flat boards use the bent brass approach. I do not regard any (that I've pulled apart) highly at all. The only exception has been the Elsafe types, which use a different type of construction, where bits of bent brass are not used. All (that I have examined) use hard wired connections. They are far superior to all other types that I've seen.
There is also an Australian Rack company that makes their own certified power boards. They wave solder the outlets & current reset directly to a 16A double-sided PCB
Edited by Gee Emm
Link? (Interested).
