Byron Bae
Subwoofer Integration
I'm running a pair of Monitor Audio Gold 100s and am looking at buying a sub for some proper oompf.
I've heard rave reviews of how well RELs integrate, but do they integrate better than a sub made by the same speaker brand? In particular Monitor Audio? If anyone has  had any experience with this, I would love to hear your insight.
many people state REL indeed integrate well,
with many different brands
I had till recent a strata 5 with dynaudio c1
and it worked very well
really depends if you want hi fi (2 ch ),or home theatre type sound
I now use 2 subs , another issue altogether :)
dont have to match brands, and rel have always worked well to integrate with mains. particularly in many cases they are looked more as a woofer than sub woofer for extension and work well in that role.
ps monitor audio do make some really good subs to so I wouldnt eliminate them, and they would match in well aesthetically as well :)
Sounds like I'll stick with my idea of getting REL. I do like the idea of a sub using a high input the same as your speakers.
I might be putting my pair of Rel s2 up for sale.  Keep an eye on Classifieds.  I got them to work with MG 20.7.
Other standard advice for integration applies - run your sub a bit quieter and it'll integrate better. Can also play with the balance of the A/V Receiver vol output and the subwoofers gain to achieve the right level of integration and balance between thumping base and not standing out.
Unless you have a proper high pass for the L/R, they'll never integrate properly.
One brand "integrating" better than another is pretty well wishy-washy BS.   It's just about how you set up the woofer/speaker crossover.    You would expect manufacturers would design their mains and subs to blend together well - but this isn't always a good assumption  (and rooms also conspire to wreck the match anyways).
So that means getting the subwoofer to have a flat response.    This depends on where the subwoofer is, where the listener is, and any EQ applied to help (eg. your subwoofer might have EQ controls on it)
... and then getting the speaker and subwoofer to blend ("crossover") well.   This is what A9X is referring to.
You can either match the subwoofer (using the controls on the subwoofer) to the main speakers where they naturally play down to (reportedly Monitor Audio Gold 100 play down to 40Hz) .... or you can add a high pass filter (suggested by A9X) to the main speakers, and then match the subwoofer to that - this will take some bass load away from your main speakers, which will likely be better (assuming the sub is setup well)
You won't know what really works without testing it in your room, as the room and positioning of the sub can make a huge difference. I ran an NHT 10" sub with my GR10's which worked great until I moved house. I was never able to integrate it well in the next place due to the shape of the room. I then ran a Sunfire True Sub with my GR20's which has worked well in my current room possibly because of the bass exiting the sub in multiple directions, making placement less critical.
davewantsmoore speaks the truth. I can't see that the brand of sub makes much difference to 'integration'. I'd say whether you have the capacity for some adjustment in phase (0 or 180 just isn't going to be enough), high pass crossover point, crossover slope and of course gain. Only then will you be able to successfully dial your sub in.
Something like this is what you need at a bare minimum:
Edited by lowpoke
Room is everything with bass...alright 90%....filter slopes helps, as does phase control
I've read this in a few threads recently, and apparently some sales people push it as something beneficial?
I always regarded it as a bandaid when there were no line level outputs available on pre-amp being used.
The speaker level signal just goes through a voltage divider in the sub to bring it back to line level before amplifying it again in the sub amp.
What possible benefit could it have?
Mike
If you are inferring that room is 90% and speaker(woofer) is 10%, then I say absolutely not.    It's important to get the speed right independently of the room.    The room makes a huge contribution to modifying the source, but garbage in, garbage out.
Some prefer this option so that the "character of the amplifier used for the speaker comes though".
It really depends on how the subwoofer amplifier is designed.    If it is designed from the ground up to work this way  (eg. of the opt of my head, Vandersteen) then it can work.
3 hours ago, Chazz said:
Rhythmic Subs are also very good for music
+1!!  :thumb:
I run 2 x Rythmik 12" drivers and 2 x Rythmik amps in a single large tapped horn sub - it sounds great whether it's playing movies or music - but all good subs with good integration sound good.
It's the integration part that's the tricky bit.
If you care about time alignment, then likely you need a solution that can delay your main speakers, as the crossover filters for a sub delay the sub so they "lag" your main speakers in time.
If you don't care too much about "proper" time alignment between mains and sub (and IMHO it's more important to achieve a smooth FR, so a few cycles lag between sub/mains to achieve a smooth FR is OK), then adjust the delay control on the sub to get the smoothest "in room" FR...
...but IMO good integration between sub and mains will always require a measurement rig and measurements - you can't do it by ear.
Mike
17 minutes ago, AudioGeek said:
How much delay do rhythmik sub amps Introduce?
AIUI, it varies with the '@ frequency' chosen for the LP slope.
Thanks Andy. So how much delay would you expect under 80Hz?
Never really heard of timing being an issue with these subs
~zero ... aside from the built in filters (which are just a standard part of making a crossover - all filters have delay, and so should be seen as a "problem")
5 hours ago, Satanica said:
Fact or presumption?
My presumption is the amplifier does not internally use DSP (ie. convert from analogue to digital, then back again).    If it did, not only would they state that, but they would offer features enabled by the DSP (like delay, and many more filter options).
An analogue amplifier (which I've presumed it is) has an input to output delay which is so (very!) small that it can be ignored for a speaker  (so especially for a subwoofer).
Interesting question, as the Rythmik amps incorporate the circuit for the active feedback to better control the driver - I'm not sure how this circuit works, but I wouldn't have expected it to cause additional delay
The presumption is that if the feedback circuit caused additional delay, it couldn't help maintain driver control.
It works more like negative feedback in an amplifier, rather than a filter
Excluding the active feedback control, the Rythmik crossover will cause delay as any crossover filter will - depending on slope and frequency - the maths is solid.
Mike
Edited by almikel
exactly the same as any other filter of the same slope and frequency.
All filters cause delay - it's just that the delay increases with increasing filter slope, and reducing frequency (delay is inversely proportional to frequency), so it makes a bigger difference at sub frequencies.
I'm sure there's delay calculators on the googleweb - but some points to note:
  • for IIR non-linear phase filters (analog and DSP), the delay is variable (non zero Group Delay) depending on frequency, but the variable delay is typically less than FIR linear phase filters
  • for FIR linear phase filters (only possible with DSP), the Group Delay is zero, so the delay across all frequencies is constant, but the delay is more than IIR filters, and requires more compute power (filter "taps") the steeper the filter and the lower the frequency. The propagation delay for the "compute" part is still infinitesimal compared to the inherent filter delay defined by physics
Mike
Edited by almikel
    • By ricky65
      Item: Monitor Audio Gold GX100 with stands
      Price: $1200.00 or $800.00 without stands
      Item Condition: Good Condition
      Reason for selling: No longer used
      Payment Method: Pickup - Cash, Paypal,
      Extra Info: GX100 in Dark walnut colour. Matching Platinum Stands. Pick up only as no packaging.
    • By Lego Man
      Item: REL T9 Black
      Price: $1000
      Item Condition: Perfect
      Reason for selling: no longer required
      Payment Method: Pickup, Brisbane - Cash
      Extra Info: The REL T/9 is the perfect sub for the hifi lover adding to every system. This sub has had little use since moving into an apartment and is in perfect condition, approximately 4 years old.
      I have missed placed the box, so Brisbane pickup only.
      Any questions let me know.
    • By paulie83
      Item: 1 x Silver Centre, 2 x Silver 6 Floor standing speakers (L&R), 2 x Silver FX Surrounds (complete 5.0 system)
      Price: $2000 including donation to stereonet
      Item Condition: Excellent, pristine
      Reason for selling: Moved House decided to sell as complete package.
      Extra Info: This is an entire 5.0 speaker system at an excellent price. It includes the following:  silver 6 L/R floor standing speakers, Silver Centre and Silver FX Surrounds. This is the 5th generation silver series (i.e. the previous model to the current silver series). They are in a luxurious gloss black. They were purchased in 2016 and are in pristine condition (inspection welcome)- they have the balance of the 5 year warranty and I have all receipts. They are great sounding speakers for both music and movies. They have never even been misused or pushed hard. These speakers cost me around $5000 new. They are all tonally matched with matching 6 inch bass drivers and gold c cam tweeters. I am only selling because we have bought a new house and I made a deal with my wife. I would give up the 5.1 setup to fit better in the new house but I was allowed to get an upgraded 3.1 setup. Pickup will be from my address near Wollongong. I am happy to deliver for free though in the greater Sydney or even Canberra area just ask me and we can work something out.
      Buyer will not be disappointed! Happy to take further photos or accommodate an inspection.
    • By paulie83
      Price: $2000
      Extra Info: This is an entire 5.0 speaker system at an excellent price. It includes the following:  silver 6 L/R floor standing speakers, Silver Centre and Silver FX Surrounds. This is the 5th generation silver series (i.e. the previous model to the current silver series). They are in a luxurious gloss black - the finish is spectacular and and monitor audio are regarded as having great speaker finishes. They were purchased in 2016 and are in pristine condition (inspection welcome)- they have the balance of the 5 year warranty and I have all receipts. They are great sounding speakers for both music and movies. They have never even been misused or pushed hard. These speakers cost me around $5000 new. They are all tonally matched with matching 6 inch bass drivers and gold c cam tweeters. I am only selling because we have bought a new house and I made a deal with my wife. I would give up the 5.1 setup to fit better in the new house but I was allowed to get an upgraded 3.1 setup. The sub I use is not included in the sale. Pickup will be from my address near Wollongong. I am happy to deliver for free though in the greater Sydney or even Canberra area just ask me and we can work something out.
    • By Demondes
      Item: 2 x REL T9i (White) includes original boxes and REL cables
      Price: Sold
      Item Condition: Near Mint
      Reason for selling: changed my main speakers and moving to a DEQX based setup
      Extra Info: offering these up for sale as my new music speakers go lower than the previous JBL 4429.  I did consider keeping these but it would require purchasing a second slave DEQX device to incorporate these in the system (the DEQX 5 only has 6 channels).  These were used as a pair for music, not sound effects.
      Happy to sell as a pair or separately, but would give preference to local pickup or drop off and if someone would like the pair.
      I found the REL very easy to tune in by moving the level and crossover frequency up until the sweet spot is found.
      I personally like the look of these in white but understand that black may be more popular.  I found with a lighter carpet or wooden boards these disappear into the room corners more than the black version.
      REL T9i 300W - The series flagship
      The T/9i represents the most of T/i that REL can deliver, and if sheer output alone is a primary requirement for your theater or music system then read no further. The combination of a lightweight, composite 10” driver coupled to a matching 10" T/i passive delivers speed, slam and attack when called upon but also is capable of tracing more delicate passages when necessary.
      Large in sonic scale, the T/9i is ideal for mating up with floor standing speakers and rooms that are on the medium-to-large size. Powerful, concussive, yet beautiful.
      Features
      - Closed Box, Active & Passive Drivers
      - 10" Active Driver & 10" Passive Radiator
      - 300 Watt Class AB Power Amplifier
      - Hi-Level, Lo Level & .1 LFE Inputs
      - 28Hz at -6dB in-room frequency response
