Bluesound Owners & Discussion Thread
Hi
Looking at something for easy digital playback and simple iPad control (got an iPad) for CD and above playback..
I like the look of the vault but does it allow you to also put on via USB, hi res files, what bit rates? Does it handle DSD etc?
I want to be able to rip cds straight onto the unit like the bluesound, are there other/better options?
Or can I just get a Mac mini and run an app to control it (without a monitor available) from the iPad and run audivarna or similar?
One last idea is just to set up a small iMac at the other end of the room and run wifi to an Airport express? Would anyone recommend this idea or even with a streamer, can you use an iPad with any to control the music?
Looking to keep it relatively low cost, and simple. Serious listening will happen via the meridian CD player or a nice turntable when I get to buying another one..
Cheers for reading through another ramble :)
  • Replies 398
Popular Posts
Copy and pasted my answer from another thread.     I have had the vault 2i in my system since Christmas and I must say I'm very happy with it. I have never really been that keen on
@rantan I have finally got my stuff together. Today I wired my phono amp to my Powernode 2i with an Audioquest Victoria RCA to 3.5mm jack cable. I haven’t been able to listen to vinyl for ov
Just saw this on the Teddy Pardo Facebook page   There is a new DIY conversion kit so that Teddy Pardo PSUs can be used with the Node 2/2i   Everytime I have used an aftermarket PS
20 minutes ago, Gremrock said:
Hi
Looks like the Bluesound doesn't support DSD, does MQA though. Naim Uniti Core does DSD but it's at least twice the price. The full specs are on both the Bluesound and Naim sites.
Shame Lord Yolk is no longer a member here as he could point you towards the ultra new bit of ripping BT  magic he recently purchased which is a wee bit more advanced than a BS Vault apparently. I'll remember the name eventually and post you a link.
  • 2 months later...
Guest jakeyb77
Well time to pick up the Bluesound Node 2i this afternoon and have a listen.
Though I’d start a thread for like minded users to discuss!
  • Administrators
By all accounts it's a remarkable upgrade in sound quality over Gen2.
Looking forward to your thoughts.
Guest jakeyb77
I promised @evil c I’ll take mine over and make a comparison without external DACs.
Hes worried it will make him ask Santa for an upgrade ?
I promised [mention=116153]evil c[/mention] I’ll take mine over and make a comparison without external DACs.
Hes worried it will make him ask Santa for an upgrade [emoji16]
Grrr - I am Santa ! [emoji1]
Guest jakeyb77
Great initial impressions!!
I really like the BluOs also.
It has a really analogue sound. To be fair I haven’t run it without the Geiseler yet.
Iys like playing a really really good pressing.
The bass in “ The Chain” is kicking me in the chest.
Edited by jakeyb77
Brilliant! Can you keep us in the loop when they add airplay? I dont use apple music but my wife does and can see the appeal of airplay2.
wishing airplay was backward compatible with gen1 but appears not.. santa may sneak a 2i into the racks un announced!
Guest jakeyb77
5 minutes ago, wolster said:
@jakeyb77
Can I ask what you were using as a streamer before?
I’ve used a Yamaha WCX-50, Logitech Transporter, Squeezebox, Pioneer N-50.
I was talking to Clive last night and we were on the same page. Many times I good good sound stage with vocals above the tv in the middle. Good separation between left and right. This has all that but the Vocal now seems way deeper than the TV and it’s like all the gaps are filled between left to middle to right. It’s more holographic if you will.
I find the mid range fast and musical and the bass is solid and not bloated.
As said the Klein and the BS are on in this scenario so a further test without the Klein is needed to be fair to the BS.
Guest jakeyb77
22 minutes ago, wolster said:
Thanks @jakeyb77
Listening now to the Bluesound2 and didn’t think I would have an itchy upgrade finger for a while. ?
From reading reviews they seemed to lean toward the 2i being an improvement on the 2 but possibly for most not enough to force an upgrade.
I was in the lucky position of wanting a BS Node 2 at the time the 2i was released so it was a no brainer as the 2i was only $50 more.
I'd be keen to hear opinions of how the Node 2i's sound quality compares with the gen 1 & 2 Node. I have the gen 1 Node and while it has a nice analogue sound, the DAC could do with a bit more clarity.
@Tone Malone so do i and havnt ever used an external dac. Although i though gen 1 and 2 shared the same dac?
I love mine, use it daily and its only fault to me is its shape. Luckily its currently hidden in a drawer.
I did think that because the gen 1 and 2 where released so close together, maybe 12mths, they kept the same dac in it. I maybe wrong though.
Either way excellent sounding units and id be lost without mine
Guest jakeyb77
6 minutes ago, wolster said:
@jakeyb77
Thanks for the tip ?
Playing it now.
Can I assume you are playing without the Klein involved to get MQA?
Still running into the Klein so whatever that end result is.
Digital hasn’t been my strong suit.
I’ll get some time in the week to remove then DAC and offer a comparison
  • Moderators
@jakeyb77
Not sure of your setup but I have coax out of Bluesound into my DAC for most music. For MQA I have RCA from Bluesound to preamp so it is just a case of switching inputs.
Guest jakeyb77
Yes that’s what I’d have to do also.
Not many DACs work with the MQA but the Mytek Brooklyn is MQA certified and I know they work in tandem and are a common combination.
I was asking on Clay’s pages about it and I thought they said to run it as is. Anyway will try the setup sans DAC
Edited by jakeyb77
  • Moderators
Ok young fella, I think it’s time to bring ya toyz ova.
will play sum choons.
Guest jakeyb77
Will organise some time with you. Sundays are best for me
I believe there's no change in DAC between 1, 2 and 2i. Seems to be just other circuitry that has been changed. Pretty keen on trying one since I have a Node 1 too.
Guest jakeyb77
7 hours ago, barn door said:
So for MQA you need an MQA equiped DAC? (In addition to the 2i) . . . Or will the 2i support MQA on its own (via BluOs)?
BluOs supports MQA. You can play MQA straight out of the 2i. Or you can switch it to external to let an external DAC unfold the MQA.
From what I read with the Mytek Brooklyn they work in tandem in another kind of way. The two companies worked with MQA to achieve a result.
On 17/11/2018 at 7:39 PM, jakeyb77 said:
playing an MQA version of one of my favourite artists and it’s sound magnificent
@JakeyB - Just a note of thanks for introducing me to the wolfman washington. WOW!!!!!!
Guest jakeyb77
Glad you like him. Really has the road in his voice. Not as much on Tidal as I’d like but I have a few of his LPs.
well done mate.  Glad to see it's kicking goals.
On 17/11/2018 at 12:07 PM, Tim D said:
I run my NODE2 into a Klein dac so I wonder if having the 2i would make a difference?
Been trying to figure this out myself. I run an external dac from my sonos and am looking to upgrade to a better streamer.  Really like the look and feel of the BS stuff but would rather buy a BSN2 second hand than a 2i new if there will be no discernible change in SQ between the two when running an external DAC.
Update here if you find any information this!
I run my Sonos into a W4S remedy reclocker into an external dac, not much difference in sound when I ran a mate's BSN2 into the same dac.
Also ran an Auralic Aries Femto into the same dac, not that much difference for the price difference. Changing the dac made the biggest difference.
