Cafad
Technical Brain TB-Zero/int Review
Damn it Terry!  I can get a decent level of clarity out of it but I can't replicate that soundstage that we heard at your place.  2D is OK but 3D is mostly absent and I'm not sure why.  It may be that I have too much gain, or at least that's the way it seems.  It's also possible that the room is just too small, but I don't like that possibility so I'm choosing not to give it much consideration.
I'm going to take a break from audio and do a little catching up on TV.  Maybe after that I'll be able to come up with something.
Interesting mate. As good as the Lenehan’s are they just might not be up to the sound staging that the Vienna’s have. 🤷‍♂️
The rooms do look vastly different as well, could be a massive contributor.
Cheers Dave
I have encountered the problem of "my room seems to be too small for the sound stage to breath" a few times in the past.  That could be the case now as well, it's difficult to be sure.
I'm guessing Terry's room would be somewhere between two and two and a half times the volume of mine.
I have an idea but it's getting late so I'll see what I can find out tomorrow.
Cheers Dave
I agree speakers can make a huge difference to sound stage.
More than just speakers I think.  The Consonance Droplet puts out the usual 2.3V signal, I say usual as that is the usual for Consonance players, they don't use the line level standard of 2.0 volts.  So balanced outputs are 4.6, not 4.0.
That extra gain worked wonders for the Exposure 2010S2D at my place and made for an astounding sound stage at Terry's place but it isn't doing me any favors in my smaller room with the TB.
I improved things massively by shifting back to unbalanced inputs (via adaptors) between the Droplet and the TB but I've still only got about 70% of that 'astoundingness' level.  Now that's a pretty good sound stage but it isn't anywhere close to the sound stage through those Vienna Acoustics of Terry's' and, as I believe many of us have said once something has been heard it cannot be unheard and 70% isn't just a poor second place, it's more of a piss-poor 5th place (no medal, just a crappy ribbon for participation) and that isn't easy to live with when you now know what the amp is capable of.
I've been running the Sansui 907NRA for a bit to compare against and I found that it wasn't a fan of the balanced inputs either, it lost that relaxed feel that I love so much about it.  That's what convinced me I needed to shift back to unbalanced inputs.
The TB is sounding very nice, that impressive clarity is there but there is also just a touch of hardness in the treble and I'm pretty sure it's gain related.  You'd think that could be fixed by reducing the volume on the droplet, but it seems not.
I think it's time to start fooling around with ICs again.
Are you saying the same player, ic;s and  amp +Viennas at Terrys = amazing
and same player, ic's and amp + Lenny's at yours = so so?
Yep!
26 minutes ago, Cafad said:
Yep!
Then doesnt that rule out gain? You are left with speakers, speaker setup, speaker cables? room and yes I am going to "go there" power:blush:
And out of all those I would guess that the speakers probably make the biggest difference. Perhaps Terry could throw the speakers in the back of a car and head to Cafad’s place.
Not the way I hear it.
Room is a big thing here, mine is less than half the size of Terry's so my listening position is much closer.  So in my lounge it sounds like there is too much gain.  The sound is solid and clear but a bit too fast and a bit too hard, particularly in the mid range.  By using the unbalanced in this effect decreases.  It seems like gain is the problem to me.
Or the speakers just don't like the TB, that's another possibility.
Another possibility is difference in the tubes.  Most tubes of the same brand & type can vary considerably in gain and conductance.  There could also be different brands or alternative tubes being used?  It appears the Droplet CDP5.0 uses Sovtek 6H30's as stock tubes.
 this is something I experienced when I had to give up my dedicated music room and move all my gear to the much larger lounge room... it was like a 200% improvement even though a non dedicated space... room makes a lot of difference. things like sound staging ... air... clarity and detail all took a step up...
quite possible a gain or speaker is match as well :)  only ways to know would be to take your speakers as well next time to terry :D
Damn it, I knew i should have bought a bigger vehicle.
So when you say gain, what sort of gain? Is it from the room?
I don't really know, possibly caused by my sitting so much closer to the speakers than at Terry's.
Ok is the room very "live" sounding, ie a bit reverberant. Do you have any treatment at first reflection point? If you are getting a lot of sound reflecting off the walls that will usually tend to spoil image depth. If the room is smaller the reflection is closer in time to the original sound from the speakers and that will cause all sorts of problems, too much mid freq energy is one of them.
The reason why I am interested is I have been chasing image depth in my room.
    • By Douglas HiFi
      Item: Cambridge Audio CXA60 Integrated Amp
      Price: $990 - Stereonet Special - Limited Stocks
      Item Condition: Sealed - Brand New
      Reason for selling: Cos we're nice guys
      Payment Method: Cash, Visa, Mastercard, EFTPOS, Direct Deposit
      Cambridge Audio CXA60 Award Winning Integrated HiFi Amplifier
      Cambridge has made a name for itself over the years for making affordable, high quality, award winning HiFi audio products.
      The CX-A series show a great understanding of what people are looking to connect in this modern world.
      Sporting (5x) Analogue inputs as well as (3x) Digital inputs gives this HiFi amplifier connectivity options to share across analogue and digital sources.
      The Wolfson HiRes DAC fitted internally is based on the Award Winning DAC Magic+ stand alone unit and offers a performance that is an improvement beyond many built in efforts at the budget to mid priced end of components.
      Let the experience and knowledge of the Cambridge Audio design team bring your HiFi into the modern world with an award winning performance.
      The CXA60 must be heard to be believed.
      Technical Details
      Power output: (2x) 60W RMS into 8 Ohms, 90W RMS into 4 Ohms
      DAC: Wolfson WM8740
      Frequency Response: <5Hz– 60kHz +/-1dB
      Analogue audio inputs (4x) RCA, (1x) 3.5mm MP3 input (front panel)
      Digital audio inputs: (1x) S/PDIF coaxial, (2x) TOSLINK optical, OPTIONAL Bluetooth via BT100 (not supplied)
      Outputs: Speakers A and/or B, 3.5mm Headphone Output, Preamp Output, Subwoofer Output
      https://www.douglashifi.com.au/products/cambridge-audio-cxa-60
    • By Yngvi
      Item: Absolarè Signature Integrated Amplifier
      Price: $32,500 plus postage - Offers Welcome. Lowballer's hit me up !!
      Item Condition: Very Good
      Reason for selling: Time to try something different.
      Payment Method: Cash, Paypal, COD Only
      Extra Info: Purchased from the  Australian Distributor last year. This is the Signature RCA version. Hybrid design, 200w Solid State amplifier and tube pre-amplifier.  It will travel safely and securely in its original metal flight case and double box. All original packing and remote control provided.  Priced way below its current RRP of $52,500 AUD
    • By memota
      Item: Bryston B135 SST² Integrated Amplifier
      Price: $4,299
      Item Condition: Mint
      Reason for selling: Interested in trying something new
      I'm considering selling this to try something different.
      Putting feelers out there to gauge interest.
      The unit is absolutely mint, black finish, and comes with the optional remote control (which lists for $699 alone!). It was purchased new by me in May 2015.
      The amplifier retails for $7k new so this is a bargain.
      I still have all the packaging so COULD ship, but would prefer local pickup if possible.
      I'm be interested in a trade for a NAIM Supernait 2, or one of the NAIM Uniti Novas, but that's about all.
      Some info
      Brochure is here: http://www.bryston.com/PDF/brochures/B135_BROCHURE.pdf
      135W into 8 Ohms (180W into 4 Ohms) Over 30,000 MFD of filter capacitance per channel Three ultra-low-noise power transformers Separate ground paths for Digital and Analog Gold plated switch, contacts, and connectors Pre-out/main in connectors Computer modelled heat-sink. Convection cooled and housed in a fully aluminium chassis Headphone jack 20 year warranty (16 years to go!)
      This is an incredible amplifier, with a low noise floor and pitch black background. It excels in bringing out detail in recordings without (somehow!) highighting flaws in production.
      Some reviews:
      http://i.nextmedia.com.au/avhub/australian-hifi_reviews_2014_2014-04_bryston_b135sst2_amplifier_review_test_lo-res.pdf
      https://www.soundstagehifi.com/index.php/equipment-reviews/621-bryston-b135-sst2-integrated-amplifier
    • By Cafad
      With a little luck the ATC SIA2-150  review will be completed this weekend.  It has been on hold for several weeks now as things popped up that robbed me of time or energy but it seems at least half of this weekend will be free so I'm going to step on the gas and see if I can get this one finished and written up.  I know there's at least one SNA'er waiting on it.
      It isn't a large amp, reasonably weighty though at 20kgs, but it can pump some serious power.  As demonstrated at Terry's place it was one of the few amps that we tried on those VA Concert Grand speakers of his that took control and made the speakers perform.  This places it in the same category as the Sansui 907 NRA, 907 Limited, ME-240, and Zeus Integrated.  And that is some pretty decent company to be in.
      The ATC suffers a little in my home system in that it doesn't impress as much as it did at Terry's place.  I think this is one of those amps that reacts well to being asked to work harder so it will step up on lower impedance speakers.  Since my Lenehans are fairly benign in impedance I believe the ATC is coasting a little.  Still a very good amp but not quite as "Wow inducing" as it was on those VAs of Terry's.
      Details to follow once my washing machine has finished it's job and quietened down a bit.
      There is more info on the ATC SIA2-150 on page 5 of the thread Terry and I started, link below.  Some rather nice pics too.
      https://www.stereo.net.au/forums/topic/263126-terry-o-and-cafads-integrated-amp-challenge/page/5/
    • By Douglas HiFi
      Item: PrimaLuna Dialogue Premium Integrated Tube Amplifier - ExDemo
      Price: $3680
      Item Condition: Ex-Demo  (around 50-100 hours of use) - Excellent Condition with all Original Packaging and FULL WARRANTY
      Reason for selling: Recently Discontinued Model
      Payment Method:  Cash, Paypal, Visa, Mastercard
      Extra Info: BE QUICK - ONE ONLY AVAILABLE
      Here's a chance to grab a sale price on our ex-showroom model of the PrimaLuna Dialogue Premium integrated Amp.
      PrimaLuna have made quite a name for themselves by making modern tube amplifiers that have the magical warmth and depth of tubes with modern world technologies applied to make them relatively fuss free without impacting sound.
      The PrimaLuna Dialogue Premium Integrated is a beautiful looking and sounding amp... and we really enjoy the lovely, detailed full and open sound that this amp brings to nearly any speaker we have run off it in-store. This Amp has a fantastic amount of drive and saturation to the sound that helps bring a fantastic, real in-your-room sound that normally is only hinted at until hitting some pretty expensive equipment.
      Featuring (5x) RCA stereo inputs, a Sub RCA output (and also with a Home Theatre Bypass mode) the PrimaLuna Premium Integrated is made easy to integrate into a two channel or Surround system.
      The PrimaLuna range is all expertly designed and manufactured to a level that seems impossible for their price.... more importantly the sound has the sublime sound of tubes coupled to a neutral, airy top end without the roll off of many others.
      Don't buy good.  Buy perfect.  Iconic.  State of the art.  Something that will still be relevant ten years from now and that is built to last a lifetime.
      So how do you know if it's simply good or world-class?
      a Stereophile Class A rating.  Class A is defined as  "Best attainable sound for a component of it's kind, almost without practical considerations" with practical considerations meaning at any price.
      The Absolute Sound's Dick Olsher is possibly the most experienced and technically adept writer on staff when it comes to tube amplification. He declared "It is my current benchmark in integrated tube amplifiers."  resulting in a 2014 Editor's Choice Award.
      Pictures: (Pictures are of actual item)
