mloutfie Posted August 10, 2018 Share Posted August 10, 2018 Does anyone know how does Technics SP10 mk2 remote function? I plan to make something to replicate it if possible. It just uses a 2 pole headphone jack to connect to the turntable and doesn't look like it's powered by battery do I assume only simple circuit there. Link to comment Share on other sites More sharing options...
michaelw Posted August 12, 2018 Share Posted August 12, 2018 why would you want one ? it's very limited in functionality - all it does it replicate the start/stop button on the sp10, basically putting the button on an extension cord. you still have to get up to cue/lift the tonearm. Link to comment Share on other sites More sharing options...
audiofeline Posted August 12, 2018 Share Posted August 12, 2018 (edited) By 2-pole I'm assuming you mean a mono jack? If so, all the circuit would do would be to short the jack. Experiment - plug a jack into the socket, and see what happens when you short the jack with a piece of wire. If a short contact turns the tt on/off, then a momentary button would suit. If it requires shorting for the turntable to run, an on/off switch would do the trick. And here is what the original remote control looked like: . Edited August 12, 2018 by audiofeline 1 Link to comment Share on other sites More sharing options...
mloutfie Posted August 12, 2018 Author Share Posted August 12, 2018 1 hour ago, michaelw said: why would you want one ? it's very limited in functionality - all it does it replicate the start/stop button on the sp10, basically putting the button on an extension cord. you still have to get up to cue/lift the tonearm. It's because of my new plinth. I want to rotate the orientation of the deck so the button would be at the back. This is because the possition of my main arm Link to comment Share on other sites More sharing options...
michaelw Posted August 12, 2018 Share Posted August 12, 2018 ah ha Link to comment Share on other sites More sharing options...
mloutfie Posted August 12, 2018 Author Share Posted August 12, 2018 5 hours ago, audiofeline said: By 2-pole I'm assuming you mean a mono jack? If so, all the circuit would do would be to short the jack. Experiment - plug a jack into the socket, and see what happens when you short the jack with a piece of wire. If a short contact turns the tt on/off, then a momentary button would suit. If it requires shorting for the turntable to run, an on/off switch would do the trick. And here is what the original remote control looked like: . Good tips will give it a go thanks 1 Link to comment Share on other sites More sharing options...
audiofeline Posted August 12, 2018 Share Posted August 12, 2018 6 hours ago, mloutfie said: It's [the interest in a remote is] because of my new plinth. I want to rotate the orientation of the deck so the button would be at the back. This is because the possition of my main arm There is nothing like the satisfaction gained by customizing something for your own needs. Link to comment Share on other sites More sharing options...
